Question about Dometic Rooftop RV Air Conditioner
Dur-therm furnace heat controll with Dometic remote
With the Dometic remote the heat will not stay constant. I have to keep clicking the remote temp controll up to make the furnace restart. If it does restart on it's own it is only after the heat has dropped 10 degrees or so.
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 9 Answers
I would suggest that you look at your thermostat,it may be to close to the furnace keeping in mind that all thermostats have a certain tempreture drop (or gain) before restarting john
Posted on Jan 15, 2009
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
My dometic duo-therm thermostat is no longer showing an option for my furnace.
I assume it's remote control. (comfort control) Have you tried following procedure for selecting "Mode"?
Nov 06, 2010 | Dometic Rooftop RV Air Conditioner
Crazy Heat
I think that I would change out the thermostat only due to the symptoms you are describing. Think the control board may be fine however, the thermostat sounds as if the internal componants are going out. Good luck on your repairs
Dave
Sep 22, 2009 | Dometic Rooftop RV Air Conditioner
Suburban RV Furnace
make sure fan is set auto its just seeing fan motor now
Jul 06, 2017 | Dometic Rooftop RV Air Conditioner
Ruud air to air heatpump intertherm propane furnace honeywell th5220d non programable thermostate.fan on furnace will not turn off in aux.mode even though the furnace heat kicks on and off. thank you for...
Make sure fan relay is wired correctly (G) wire. Ensure the fan on therm is not on, it should be on Auto or off.
If your furnace is short cycling because it has to keep heating your home, the delay in the control board may be staying on to compensate for the exchangers getting hot. If it heats normally, then put your attention to your thermostat.
Set the heating system on aux heat only. Fan should not be on, if it does stay on after a heating cycle, see if the furnace is heating normally, and reaching temp as desired before the heat comes off. Then check the therm wiring, pull the face of the therm, disconnect green wire (fan) and try the heating again.
Dec 06, 2008 | Intertherm Heating & Cooling
Will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Jun 03, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
283 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
