How to remove headlight switch in 1994 ford ranger located left of steering wheel
SOURCE: Replacing a Cruise Control Switch
Ford Taurus/Sable 1996-1999 Repair Guide
Steering Wheel
Removal & Instalation
Fig. 1: Remove the access covers for the air bag module retaining bolts
Fig. 2: Remove the air bag retaining bolts and...
Fig. 3: Carefully remove the air bag from the steering wheel to access the wiring connectors
Fig. 4: Detach the connectors...
Fig. 5: ... from the air bag module
Fig. 6: Remove the center bolt from the steering wheel
Fig. 7: Install a suitable puller and tighten the forcing screw to...
Fig. 8: ... remove the steering wheel
CONTINUE...
SOURCE: How do I remove and replace headlight switch 95 Suzuki Sidekick?
steering wheel off ,airbag removed first to get to retaining nut.best advice unless you have a mechanics toolkit to hand is to entrust it to agent ,as they will know quickest way to do it.
SOURCE: 1996 ford ranger headlights not working
I had the same problem 1998 ford ranger. left headlight very dim. right head light worked normal. pull back for high beam flash left dim headlight would go out. put on high beems left light got even more dim. trouble shot wires and replaced blinker/high low beam/whiper unit didn't fix. replaced headlight didn't fix. looked at wireing harnes connecter that conects to headlight bulb and center (black Wire) female contacts was open more than the others. (was making weak contact (ground)
FIX:::: SLIGHTLY BENT BLADE ON HEADLIGHT TO MAKE BETTER CONTACT WITH WIRE CONECTION WITH WIDER FEMALE CONTACT RECPTICAL. HEADLIGHTS BRIGHT AS EVER AGAIN. PS ALSO PUT DIELECTRIC GREASE IN CONTACTOR.
HOPE THIS HELPS
headlights and radio no t working 2010 ford ranger
