Question about Directv HR10-250 DTV Receiver
Hr10-250 dtv HD receiver
I have one with no lnb voltage out.The outputs are not shorted like a bad zener,just no voltage. Thanks
First, verify the oscilador circuit of the power.It´s normal the IC is damage or the mosfet.
Second, desconect the principal board and verify if has tensions on secundary part.If positive,the problem is on principal board.
Walter.
Posted on Feb 12, 2008
What does lnb short mean
the cable may have went bad or receiver, but check or replace the cable first
Jul 28, 2016 | Televison & Video
Dish 625 with legacy lnb
Hi beltone669,
Our 625 receiver uses DP technology. A legacy LNB would not work with the receiver. You would need either a DP Dual or a DPP Twin. If you have any other questions, let me know!
Tommy Faust
DISH Social Media Representative
Mar 31, 2012 | DISH Network DVR-625 DTV Receiver /...
Emerson LD195EMX wont turn on. When plugged in has a high pitch sound.
Got the same problem. Foud:
Zener D648, 5V6BSB, was open: Resulting in very high output non regulated voltage
Zener D668, 20BSB, was short, due to the output voltage being too high.
Jul 03, 2010 | Televison & Video
Even Transponderds Zero
Typically that indicates a bad LNB or connection to the LNB. Try moving the line to one of the other three ports on the LNB and if that doesn't work then you will need to replace it
May 18, 2017 | Directv HR10-250 DTV Receiver
Hello, i have dream box DM 800 HD PVR
Hardware. Check the power source, the 18v is used only for the LNB.
Feb 12, 2010 | RCA DISH Network(r) 311 Satellite System
It won't aquire signal
You need a service call as there are to many possibilities that could cause this issue- bad diplexer, seperator, LNB, dish moved and is out of alignment, etc. Thanks for using Fix Ya.
Sep 27, 2009 | DISH Network 322 DTV Receiver
DTV H20-600
I do not have an schematic for this receiver. This receiver might not use LM317 or TIP42C but a different voltage regulator, try to locate where the 20 volts line from the power supply and follow it to anywhere near the LNB tuner circuitry. This type of IC is normally mounted on a heatsink.
Lastly if you are a subscriber, give you satellite service porvider a call to get a replacement.
Nov 08, 2008 | Philips DIRECTV H20 DTV Receiver
DTV H20-600
You could check the voltages yourself to see if they are low. The horizontal polarity needs about 19 volts and the vertical polarity about 14 volts to work properly. If those voltages are lower by 25%, the receiver might failed to scan and that is when it locks up because is trying to find signal. The other issue could be a defective power supply if the receiver does not work after that 4 hours. There could be some capacitors that lost their dielectric strength causing the drop in voltage.
Let me know if you need further assistance.
Nov 01, 2008 | Philips DIRECTV H20 DTV Receiver
Satellite dish receiver error LNB Drift detected
that's not true i work for dish network if u have an LNB drift of -8 or +8 you can get a free lnb service call and they can come out n fix at no charge
Apr 22, 2008 | DISH Network 301 DTV Receiver
Directv h20 receiver has low volyage to the lnb.
Check inside the receiver for a defective LM317 IC or a TIP42C transistor, but before that you should check for proper voltage from the power supply to that IC.
LM317/TIP42C control the switching of voltages that power up the LNB, you should be getting 14 volts for vertical channels and 18 volts for horizontal.
Good Luck.
Mar 08, 2008 | Philips DIRECTV H20 DTV Receiver
Directv HR10-250 DTV Receiver Logo
107 people viewed this question
Top Directv Televison & Video Experts
David Ritko
David Ritko
Tom Chichester
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
