Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheem water heater flashes seven times ,it is in lock out mode
  • Rheem Master
  • 5,353 Answers
You have Honeywell electronic gas control valve, and error code is 7 flashes.
Probably you have power vent model.
One manual from different company says: "Reset gas control using on-off button on front of control, replace flammable vapor sensor, replace gas control thermostat.
But with Rheem you also need specific steps: Remove gas burner and look for broken glass vial, and then blow out arrestor screen air intake using compressed air, clean burner parts, check for unobstructed venting, you will need new glass vial from Rheem depending on year and model number of water heater that appears on label on side of unit, or they may not have a repair kit for that model, and you might need a new gas control valve depending on model and how extensive problem was
You have Rheem water heater.http://waterheatertimer.org/How-to-repair-Rheem-FVIR.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Posted on Sep 28, 2012
SOURCE:
SOURCE: I painted the floor & my hot water heater (Reehm
The water heater is locked out. The following process should reset it.
1. Reapply power to the water heater and wait for 3 seconds for the system self-diagnostic check.
2. Within the first 30 seconds, the temperature dial must be rotated back and forth crossing the 120
degree mark at least six (6) times. This will reset the control and display a normal flash code
(slow blinking).
Posted on Apr 20, 2009
gary1121
  • 332 Answers
SOURCE: the water heater will cycle 5-6-7 times with no
there is a screen around the bottom of the unit? if so take it off and clean it,, does this unit have a self ignitor, or is it piliot? make sure your flue is clear so the unit is not over heating,, make sure on the power vent that the filter is clear also,, does the fan come on before the gas ignites, if not the circuit board is going bad the fan should start first to omit the gas fumes
Posted on Jun 06, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • 13 Answers
SOURCE: rheem model 41vrp40n power vent water heater won't
"Pres sw open" means there is insufficient air flow. either the vent if blocked, or the blower turns too slow/ or died.
Posted on Feb 12, 2010
  • 494 Answers
SOURCE: Rheem Power Vent 2 water heater is flashing 4
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
Posted on May 15, 2010
My rheem 40 gallon gas residential water heater turn off n i smelled gas i relite the heater n its red light is flashing 7 times slowly but it is on now
Seven (7) blinks every three (3) seconds
Combination Gas Control failure Contact a qualified service technician.
Nov 21, 2016 | Rheem Water Heaters
Rheem model 41vrp40n flashes twice and stops working
Error code means that you have electronic gas control valve.
Copy following link to identify gas control valve, read error code meanings for each, and download service manual relevant to each gas control, but not specifically Rheem since rheem does not post service manuals.
The fact that water heater restarts, means that water heater is getting gas, getting sufficient air for combustion, thermister is ok, gas pressure is good, etc.
The fact that you unplug and replug water heater and it works, shows that you have power vent model.
Since water heater worked correctly before, 2 flashes with Rheem power vent model could mean that pressure switch has failed.
Jul 29, 2012 | Water Heaters
My Richmond tankless water heater is flashing the error code 76 and C8
Richmond is Rheem.
Following links are meant to assist resourceful do-it-yourselfer solve long term maintenance issues that tankless pose.
Error 76 is communication fault with remote control.
Check following links for Paloma 'Rheem" error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
Best place to start is your manual. Following link show typical Rheem manual with the words troubleshoot and maintenance throughout manual.
Read manual several times before buying product to see yearly maintenance requirement and complexity of tankless water heaters.
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
Contact Rheem: they will usually kick you back to local service technician.
http://www.rheem.com/Contact.aspx
Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
Rheem website is not easiest to navigate, but manuals appear for current models.
Read other Rheem questions at fixya to gain wider experience with potential problems and solutions.
http://www.fixya.com/tags/rtg_74pvn
Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Post question on pro water heater forum: This is where I go to catch up on latest info in fast-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Pay for answer at fixya:
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 17, 2011 | Rheem Tankless Hot Water Heater...
Rheem Power Vent 2 water heater is flashing 4 times and there is no hot water. Model # 41VRP50NT What can I do to fix this? Do I need to call a plumber?
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem model #GP40T6PF00 lp hot water heater Will
sounds like one of the saftey relays might be going bad. or the ingniter might be cracked or need cleaning
Mar 08, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
(slow blinking).
Mar 22, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
9,218 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
Steve Allison
Steve Allison
Sean Lavelle
Sean Lavelle
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
