Question about Miele Ovens
Miele delux 609 oven - does not work
The fan and light still work but the actual oven does not heat up. Could you please enlighten me as to what could have gone wrong.
  • J David Zubas
    J David Zubas May 08, 2014
    I am having problems with the lower oven in my wall unit in that when the oven door is closed, the light goes off, and then later comes back on. The oven will stop cooking when this happens. There is a mechanical problem with the switch position plunger relative to the oven door which is out of sync. Anyone have any ideas how to fix this?
  • Miele Master
  • 3,463 Answers
If there is no heat in fan oven , then it is 99.9% certain that the fan element is faulty..if your oven has a removable rear panel inside, take it off and you will see the element, Replace as req'd.
Plz rate this solution.
Thanks.
Posted on Dec 28, 2008
Chef Norfolk Deluxe fan forced oven. Oven, lights and separate grill - all lights went out, lost heat and stopped working.
there is a fuse inside the plug,unplug it to check it,please report the other posts
Jun 15, 2015 | Ovens
Simpson Harmony Nova electric oven heating problems (oven heats but no fan and light)
The Fan has ,in most cases, two functions - to maintain the oven temp and to clear any condensate or smoke coming from items being cooked. If your oven is over heating it could be the thermostat sensor faulty and giving a faulty reading to the fan. If you set you oven at 350F then sensors control the heat by kicking the heating elements off and in some models and makes the fan aids cool down. Make sure it is at a temperature that would trigger the fan to cool it down. It mostly relies on the regulation of the heating elements to control the temp. Only if it were to get hotter than the elements kicking off can control should the fan kick on. Not being at the site and actually seeing the stove it is hard to determine but if the fan is working every where else it should work when the oven is heating. Again check and see if there is a seperate sensor that monitors the temp of the over and triggers the fan. Not much help but that's where I would look first. Hope this was of some help.
Col. Dana Gillespie
May 11, 2014 | Ovens
Miele 310 oven griller works but not the oven. why?
Remember that some parts of a 240 volt stove require two live wires and most of the controls or elements being only 120 volts require just one live wire. Hence the double pole 40 amp breaker must have tripped but does not appear tripped. Just turn it off and back on to reset
Nov 17, 2013 | Miele Ovens
Oven manual for a Miele Deluxe H 818
Here is a direct link to download your manual (free) from the manufacturer:
Click link and download will start
http://www.mieleusa.com/manuals_pdf/Residential/Ovens/H814_818_868_gb.pdf
Please rate this solution if you find it helpful. Thanks.
Oct 16, 2010 | Ovens
Information for Miele oven DeLuxe H618 and timer. Thank you.
I have found the manual in German :
<a href="http://www.manuals.help/document_order_init.php?search=MIELE%20H%20618&doctype=1&lang=de">Miele H 618 Bedienungsanleitung</a>
Sep 21, 2010 | Miele H326-3 B Electric Single Oven
Miele Oven H387. Oven does not heat up. Everything else seems to work fine. All troubleshooting ideas in manual are exhausted. Thanks
If the fan is working o/k, then it is more than likely a faulty element, this is located at the rear of the oven compartment behind a removeable cover.
Sep 09, 2010 | Miele H387-1B Electric Single Oven
Replacement Door Hinges Miele Oven
hi the only place to purchase Miele spare parts is through Miele directly or from a Miele authorised service agent
Jun 14, 2009 | Miele DG 4080 Stainless Steel Electric...
Fan oven wont heat up
If fan is workintg, but no heat, then replace oven element.
If no heat or fan, then make sure timer is set on manual and not on auto
Please rate my solution.
Thanks.
Apr 05, 2009 | Belling XOU252 Electric Single Oven
H348 B2
turn of at mains, wait 5 mins and turn back on then consult your handbook to set clock. i suspect you have the oven on automatic by mistake. if this don't work, you may have a problem with the clock itself. you can bypass the clock by connecting together the two contacts adjacent to the clock relay
May 17, 2007 | Miele H348 B2 Electric Double Oven
Ovens Logo
700 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
