Sometimes my document I have selected to print out doesn't print. Or it prints out but some jumbled symbols print out on the same sheet or extra sheets print out with symbols or ReadBreak with symbols print out on the top of another sheet.
SOURCE: PRINT command
uninstall ink with printer on and turn off then back on when printer says install ink do so if that doesnt work clean contacts with rubbing alcohl on ink cartriges.
SOURCE: Prints extra nonsense pages
this is a printer driver issue. so, here's where you get those fresh new ones.
http://support.dell.com
SOURCE: Extra Line when printing from a dos-based program
well..that EOJ line, is possibly farther down in the program settings, and is like a page break. the Dell is only doing what it's reading, so the answer is in the programming of the application. Perhaps you might query that company about how well that program interfaces with the Postscript quality printer you have?
check your computer warranty here for FREE
SOURCE: Dell 922 All-in one ink jet printer paper feed
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this, is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
SOURCE: Printer prints first page with strange nonsensical characters
I would move the printer to another computer. See if the problem follows. I have seen the issue a few times with issues in normal.dot but also in other office applications.
Problem I'm fighting with on my 1720 is its printing extra pages between pages. basically print a 5 page document and get an 8/9 page final with the extra blank pages. Think its a user error but could be machine related. going to try it on another PC and see what happens.
