Question about Samsung YP-T8 Digital Media Player
Added 2GB micro SD to Sansa e280, computer doesn't recognize
Background:
I got this mp3 player for my husband because of its expandability. He drives a lot and I got him a good radio/ cd player (with a built-in mp3 player jack) for his car, but he always ruined his CDs because they sat in his car in heat and cold.
I filled it with part of his music collection and wanted to use the expansion slot to add more songs.
Problem with micro SD card:
I first bought another brand of micro SD card (2 GB) which wouldn't work, then bought a 2 GB Sandisk micro SD to see if that would. (I read in a forum that it might not take a card bigger than 2 GB). So far I have not found any action that will let my computer recognize it, although the Sansa itself ackowledges it is there. I have tried this on 2 different computers, one using XP SP2 and the other using Vista.
General problems with my computers recognizing the sansa:
The XP sometimes recognizes the sansa, sometimes doesn't. I have had to fiddle with the USB settings to get it to recognize it. I was able to add music to the mp3 player using this, and pretty much filled it up. Now I can't add more, nor can I create playlists.
On the Vista machine, the device shows up but only shows these folders:
Photos (empty)
Record (0 bytes
tmp (empty)
Video (empty)
version.SDK (512 bytes)
VERSION (512 bytes)
It doesn't show my music folder at all! Obviously, I can't add to a music folder if it is not there, and the micro SD isn't recognized either.
Another issue:
The only other problem is that every time we turn it on, it takes 10- 20 minutes to "refresh database." I'd obviously like to whittle down that time!
What does work:
The player works and has great sound through my husband's car speakers and earphones.
What we want:
I'd ideally like to set this up so that he could have a main collection, with his perennial favorites, and several 2 GB micro SD cards with other collections that he could swap out. I don't know how to do that. Would it work to fill the cards through my computer's card reader and put them in the Sansa to play?
I'm not very tech-savvy although know some basics and can follow directions. I appreciate any help you can give me. Thank you!
  • noahdela Feb 12, 2009
    i have the same problem with mine the sansa doesn't recognize it nor the comp when it is in the sansa
There are 3 ways to solve your problem, but all of them are rather kludgy. This is an old player and the integration of the microSD card is not done very well. I believe with the newer players these sorts of issues are not problems. Anyway, here are your 3 possibilities:
1) You can load your music directly onto the card before you put it into the player. Most cards come with an adapter that lets them fit into slots that are for regular SD cards. So if your computer has a slot for an SD card (or if not, you can plug the card into a card reader and then plug the card reader into the USB port on your computer) then you can copy and paste mp3 files onto the card. This is a drag because you can't use Windows Media Player to do this, but instead need to open the folder where the MP3 files are and then copy and paste them onto the card. But it works
2) This is slightly easier. Before you connect the Sansa player to the computer go to the settings part of the main menu and then select mode. You should see two choices. One is MTP and this is the setting you want if you are using the player with Rhapsody service. The other setting is MSC and this lets your computer recognize the Sansa player AND the microSD card. Once you have selected the MSC mode, then you can connect the player to your computer. When you look at the drives on your computer, you'll see 2 new drives. One is the Sansa 280 and the other is the microSD card. Once you see those, you can copy and past MP3 files right onto the card (and/or onto the Sansa). Again, you have to go the folder where your MP3 files live and cannot use WMP to do this
3) I haven't tried this, but others say that a free program called rockbox (www.rockbox.org) let's all this work much better. It sounds complicated, as it puts kind of a new operating system on your Sansa and it may not be reversible, so proceed with caution, but some people love it.
Hope that helps
Posted on Jan 10, 2009
I have a 4gb sandisk card and my computer wont read it. I wanna fill it up with songs but when i put it in my computer and try to drag and drop files it freezes. is there any way i can put the songs on here? im trying to get it before i go to work so i can rock out..please someone help me. i need it done before 9
Posted on Jul 09, 2009
I added a 2gb mirco SD card to my Sansa e270 6.0gb player, but the memory is still only showing 10mb of the original 6.0 gb available for use. How do I get the Sansa to recognize and use the 2 gb mirco SD...
Hi,when you purchase a new micro SD card before use, youwill need to format the memory card so that you will be able to know the actual size of the Micro SD card by checking the details after formatting it.
After formatting the micro SD card and checking the details, if you still do not see the accurate size which is about 1.88mb or the about, that means the micro SD card you bought needs to be replaced. Not a good one.
Have a nice day.
Feb 18, 2011 | SanDisk Sansa e270 MP3 Player
I added a 8GB micro SD card to my e200 MP3 player but the player won't recognize the card. What do I do?
You need to use microSD cards, 2GB and smaller. Your 8GB card is actually a microSDHC card (the HC stands for High Capacity). While a microSDHC card will fit into the slot, they are incompatible with the Sansa e200 series.
Sep 23, 2010 | SanDisk Sansa e200 MP3 Player
Micro SD Capacity
The e260 will not recognize any microSDHC cards. It will only use microSD cards, which are limited to a maximum of 2GB in size.
Apr 14, 2010 | SanDisk Sansa E280 MP3 Player
My device does not recognize a 2gb micro sd I install. Is there a procedure for installing this?
Glad to have been of help.
Cards bigger than 2GB won't work. The Sansa works with microSD cards. Cards bigger than 2GB are actually microSDHC (the HC stands for High Capacity) and use a different protocol. Newer Sansas such as the Fuze will use them but the e-series won't.
Apr 06, 2010 | SanDisk Sansa E280 MP3 Player
2gb Sansa Fuze won't recognize 2gb Micro SD
place the blank card into the SanDisk player
go to SETTINGS press "enter"
go to SYSTEM SETTINGS press "enter
go to FORMAT press "enter"
it will ask "are you sure you want to format this device"?
select YES
dowload songs to REMOVABLE DISK drive F, at least that is what my PC assigned it to. You will overload your MP3 PLAYER if you continue to download to the Sanza Drive.
Hope this helps.
Aug 27, 2009 | SanDisk Sansa Fuze MP3 Player
Not recognizing the memory card
if the micro sd is HC the sansa will not read it because it does not have the right firmware and connection to read an 8 GIG if you want that get a sansa view
Nov 13, 2008 | SanDisk Sansa E280 MP3 Player
How can I use 8GB micro sd card on my Sansa e280
I believe if you upload rockbox http://www.rockbox.org/ to your sansa it will fix this.
Oct 02, 2008 | SanDisk Sansa E280 MP3 Player
Micro sd card
Does your computer has an internal card reader?
Aug 14, 2008 | SanDisk Sansa E280 MP3 Player
Micro SD support
Yes it should be able to...
Jan 03, 2008 | SanDisk Sansa e200 MP3 Player
Sansa e250 won't recognize sd card.
Try charging your mpr player first. -is your SD Card brand new and with warranty? I think its deffective. Return it for replacement.
Sep 14, 2007 | SanDisk Sansa e250 MP3 Player
Samsung YP-T8 Digital Media Player Logo
1,932 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
