Question about Maytag Neptune MAH5500B Front Load Washer
Had power outage and now the Neptune Washer won't even light up. Washer was not in use at the time. Checked the breaker and outlet and all live and functioning. Is there a reset button that will reset the washer display and make the washer work again?
    Sergeant:
  • 311 Answers
No! did the porew surge when it came back on,like the lites in the house went briter than normal/may have damaged main control board in top console.you will also fine a tech sheet up there.see if you can get some glues their.God bless.tom
Posted on Jan 01, 2009
After power outage, my Affinity dryer will not power on. I have power from outlet but no output and no lights on display
Cause of the power outage? Some possibility a power spike surge did it's work on electronic circuit board and controls.
Feb 27, 2015 | Dryers
Maytag neptune drying center has no power mcg8000aww
Could be a bad thermal fuse, a bad drum belt, a door switch a loose wire , one of the computer boards or the user interphase. Time to call a qualified technician. This machine is a complex machine to disassemble and diagnose and if reassembled wrong could prove to be dangerous to operate.
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
How do I open a locked lid on Kenmore elite top load washer 796.2927 that has no power?
That washer is actually built by LG even though it has the kenmore name brand on it most all are the same for opening the lid when its stuck like that below is a video that shows how to get it open and then if you need more detailed help you can visit the link below the video.
Fixing an LG Top Load Washer DOA and Lid Stuck Locked
Appliance Repair Help With Live Chat
Mar 26, 2017 | Kenmore Washing Machines
Electric problem
Is it a FAV6800a or FAV9800a machine?
Have you checked the 120VAC outlet for power. Plug a desk lamp or other device into the washer outlet and make sure 120VAC is present. If not check the breaker/fuse load center for a tripped breaker or blown fuse if a old house......Rich
Jun 22, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune will not start.
""The circuit breaker is okay."" that is a good 1st check.
""I may have burnt out the wall outlet. "" Plug a 120VAC device to the washer outlet and see if it works. Why do you think you burnt out/damaged the outlet?
""Turned it off for a while and will try again later."" When you power up the washer do you have any Console indications that the machine is on. I will assume your machine is a FAV6800A TL. Do you have any LED display indicators turned on?
That is all I can help with for now. I'm a technical owner of the FAV6800A machine and will try t help if uour machine is a FAV6800A or FAV9800A.
Most important what is the model number of your machine. This forum fails big time to ask members for Model# and Serial # of their machine.
Here is the Service Manual for the FAV6800A/FAV9800A
Rich
May 30, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will not restart
There is a main control board on top which may need to be replaced,
if you remove the back top panel there is a tech sheet with a lot of information tucked in there, Suggest you plug something else into outlet to make sure outlet has power, and breaker is still ok,
good luck
May 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
My Neptune Top Load fills the water, the motor doesn't start.
If i understand correctly you are stating the breaker shut down which means the house breaker for the outlet power kicked out. You might try plugging something else into the outlet to see if it also kicks out, say a vacuum cleaner of a drill.
You need a amp clamp to test for something shorted or grounded (or ohm out windings) which requires trained service........you do not want to get a shock
Jan 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
Maytag Neptune MAH5500B Front Load Washer Logo
652 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
