I have cdj1000 was working fine one min then after moving it ligths cut off centre display and top display other ligths work cd gos in and plays but no sound comes out please would be thankfull for info or anywhere to get it sorted am in sw london
On mk2's zener diode (D1221 - surface mount on JFLB pcb) quite often goes short circuit and blows fuse / circuit protector IC106 - N10 400mA rating http://www.technicsdjuk.com/
On mk2's zener diode (D1221 - surface mount on JFLB / center display pcb) quite often goes short circuit and blows fuse / circuit protector IC106 - N10 400mA rating http://www.technicsdjuk.com/
CDJ 1000 mk 3 freezing while playing tracks and sometimes freezes when a cd is inserted. The orange cue light comes on but the green play doesnt. Any ideas?
removed top cover and there is a power supply that you will see on the top left side of the main chassic, check f1 fuse as that may be bad.The complete power supply board part number is DWR1344
Had the sam problem... Turn te player upside down, take off the bottom cover and check the semiconductor fuses located near the supply connector on the top of mainboard. The one that is responsible for display is marked as VLOD (-40V). Worked for me :)
What version CDJ1000 do you have?.
Mk2s' have a known problem / issue with the flexi PCB that connects the main board to the top board - It can crack and become intermittent if it's not folded and installed correctly.
