Question about Linksys Wireless-G Broadband Router
Adding a password
Hello, What are the steps needed to put a required password in my wireless router. I want to keep others from using my internet connection. Thank you.
    President:
  • 80 Answers
The normal method of accessing the LinkSys router is by going to your computer browser (IE or FireFox) and where the web address goes put http://192.168.1.1 Hitting the link in this post should actually bring it up.
The default setting for the LinkSys is blank for the user name and "admin" without the quotes for the password. That should bring up your router configuration application in your browser.
Click on the "Wireless" tab first, and then the "Wireless Security" sub-tab second.
There you should find your security key and the type of security setup on the router. This would be what you need to duplicate for your Netgear wireless phone.
If your settings aren't as they come by default, you can defualt the entire unit and reset it up, but hopefully that won't be necessary (only would be required if you just flat can't get to the admin panel of the router).
Hope that helps!
Posted on Dec 28, 2008
We need this router manual. It is very slow
Hello. What is the exact model of your router? If you have internet connection speed problem with your wireless try with the following steps,
  • Reset the wireless router by using the power switch on it or by unplugging it and plugging it back in.
  • Place the wireless router in an ideal location. The higher it is, the better, but don't put it near metal objects.
  • Get as close as possible to the router with whatever device you're trying to connect.
  • Keep the router and your connecting device away from other electronics. You should especially keep away from phones, fax machines and microwaves. etc.,
  • Adjust the Wifi antenna if it has one.
  • Change the router's channel, especially if other wireless routers are nearby.
Following these steps would give you stable internet connection and also increased speed in connection. You can check your internet speed from ScanmySpeed.com before and after following these steps.
Feb 18, 2015 | Computers & Internet
Drops connection slow when downloading and opening web pages
It can be various reasons like..
Insufficient Wi-Fi Network Range and Power
Unknowingly Connecting to the Wrong Wi-Fi Network
Network Driver or Firmware Upgrade Required
i think you should reset your router and check the all physical connection and modem light status..
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
Feb 25, 2013 | Belkin Surf N300 Wireless N Router
How to put password so the neighborhood couldnt access my dlink router
All you have to do is connect to the router and change security key/ secure the connection. Just follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (Default router settings are written under the router)
(unless you've configured otherwise, the default username is admin and the password "leave it blank")
Lookup for the options to do the following: -
Next step is to secure it (adding a network security key):
1.On the left-hand side, under Setup, click "Wireless Setup" Click on Setup at the top and then click Launch Wireless Security Setup Wizard. Select your desired encryption method (WEP
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Save Settings.
Also, do the following changes: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password
(The above steps would prevent unauthorized access to your router)
Now your router and your connection would become secure and the user has to provide the network key to access the internet. Please note down the settings such as SSID Key, User Name/Password and Security as in case you loose this information you cannot recover it back)
You may also download and refer to Page 60 onwards of the PRODUCT MANUAL DIR-625 for further information, if required
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 04, 2011 | D-Link DIR-625 (790069292637) Wireless...
How to put in different password
Welcome to FixYa
Login to Router Page and Change your Password.Follow Steps
  • Launch a Web browser (Internet Explorer, Firefox, Safari or Google Chrome) and enter "192.168.1.1" in the URL bar. You will be prompted to enter a user name and password; enter "admin" for both. If the user name and/or password has been changed by a previous user or the URL doesn't bring up the Linksys login page, reset the router
  • Change the wireless network password by clicking on the "Wireless" tab and then the "Wireless Security" tab on the row below. Select "WPA-Pre-Shared Key" to create your own password for the wireless network; choose "WEP" from the pull-down menu to have a random password generated for you. Record your password and keep it in a safe place.
If you cant Enter in to Page or any Error RESET it by Pressing RESET key in Backside..Then Follow above steps.You can also look this Link...
If this Helped you-Dont Forget to Rate ME..Thanks for Contacting FixYa..
Jul 01, 2010 | Linksys Wireless-G WRT54G Router
My Netgear WNDR3300 just quit putting out a wireless signal. I just bought a new Compaq notebook and the wireless internet was working for like three days and now nothing. And it is running windows 7 and...
It seems that router wireless setting need to reconfigure,please follow steps to resolved issue
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
2. Access the router, usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. If WPA is selected in Security mode, then check the Password that show up in the passphrase box.
now try to reconnect wireless
May 14, 2010 | NetGear WNDR3300 - RangeMax Dual Band...
How do i put a password on my connection
please write your address box the below link,
http://192.168.1.1
Then, it opens your user interface of the modem.
You can manage your modem now.
Find your Wifi Protected Access (WPA) and Pre Shared Key (PSK)
Choose one of encryption techniques. I use TKIP.
Wireless Protected Access with a Pre-Shared Key: The key is a password, in the form of a word, phrase or series of letters and numbers. The key must be between 8 and 63 characters long and can include spaces and symbols. Each client that connects to the network must use the same key (Pre-Shared Key).
Put a password to your connection settings and save it.
I hope this will be helpful.
May 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Internet connection not working right compaq evo n1020v
Hello
First you will need to have the install disc for your card.Install driversoftware from cd or dvd, following directions.Once installed you should see a new hardware device has been found notification.
Next you will need to configure your card with the routers wep key or wireless security key.I am assuming wireless is activated on your router.Should see a light on the router lit under wireless,or a symbol.
1 start pc then start internet explorer.
2 Type in the top bar of ie 198.162.1.1 or 198.162.1.0 hit enter.
3 This should bring you to the routers home page.usaername=admin password=password or admin
4 Find your wireless tab or settings page looking for security area.
5 Find your wep or wireless security code,write this down.
6 Log off of router.
7 Go into network cards configuration program and put this wep code into the area provided.
8 Software may have found it automaticly, it just needs this code.
If you cant connect to router at step one use a ethernet cable from your pc to the router to log on.
Hope this helps.
Jan 23, 2010 | Compaq Evo N1020V Notebook
Hello, Can you tell me how I set up my internet wireless connection please. I have tried using the step by step guide in the manual but without success. When It asks you to enter the wep code it tell me no...
are you putting in the password for the wireless internet
make sure that the password that you enter in the ps3 internet settings is the same password for the wireless router
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
I am trying to connect with another computer to the Internet, and for some reason I can't. I might have forgot my password/ key.
Did you use the setup adviser to add another computer? Linksys has the step by step with photo's for adding more machines to the router, and if your other machine is wireless but has a ethernet connection also you can plug it in and set it up that way.
Sep 15, 2008 | Linksys Wireless-G Broadband Router
Router Password
try admin and admin again for password. If that is not it try leaving the password box blank. Good luck Are you sure you did not change the password when you set it up the first time. If you did you have no other option than reset.
Jan 29, 2008 | NetGear WGR614 Wireless Router
Linksys Wireless-G Broadband Router Logo
52 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
