Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Ignitors won't work
I removed all the parts on the top for a good cleaning. Now 2 ignitors don't work in front. Everything is clean, nothing is clogging the grooves. How can I fix this?
    Novelist:
  • 112 Answers
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
Xl44 top burners light
There are a few things that can do this... First check the burner top to make sure the holes are not blocked. 2nd, Are the other ignitors sparking? If so then try rotating the slack in the burners left and right - this works sometimes. If not then try placing a screwdriver (you holding the handle only) and touch the burner and lean the screwdriver towards the ignitor... making the spark gap smaller. If you have used the ignition without a burner in place the ignition pack will short out inside it and there will not be a spark until the gap is very small. 3rd, are the ceramic part of the ignitors cracked at the base... take care when washing as they break easy if caught on the cloth. The ignition pack works in pairs so having one work suggests the pair of this one is something in the lead if there is no spark... A huge spillover causing a short or a bad earth... check the burners are firmly in place. There is more but too much detail to post here. Good luck
Jan 02, 2014 | Kitchen Ranges
Two burners on jenn air counter top make sparking sound but burners won't ignite
turn electricity off to ignitors. remove grates and clean up the burners good, they might have a clogged up hole. gas may not be coming out of burner holes. good-day !! if all else fails, just use a wooden match to light that burner.
Jul 11, 2011 | Microwave Ovens
Electronic ignitors won't stop clicking
Pull the burner caps, etc off the stove and completely dry the area ..Be sure to inspect each ignitor contact for cleanliness as well. If the ignitors have soapy buildup or water, around them, they can act like this.
You should be able to pull the burner caps and flame diffusers off and clean with a paper towel, and if needed, a light scouring sponge. Be careful not to scratch the surfaces, but scour the top of the ignitors carefully if you need to clean them.
Jul 31, 2010 | Maytag MGR6772BDS Gemini Gas Kitchen Range
The electronic ignitor on front right burner no longer works.
All ignitors should fire regardless of which burner is turned on. See if the right front will light up if you turn on another burner or look for a spark. If not, the ignitor is probably fouled and needs a good cleaning. If the right front burner will spark or ignite when a different burner is turned on, it is the right front control switch - not an easy fix. When cleaning the cook top, if you remove the knobs, any liquid that gets into the switches will short them out. Found that out the hard way.
Dec 20, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
G.E Profile gas cook top #JGP640 ignitor.
It is sparking because the module does not sense the heat which would normally cause the sparking to stop.
It can be caused by a poor ground, make sure the ignitor at that burner is clean and free from any obstructions. If it is then it could either be a defective ignitor or spark module.
Mar 12, 2009 | GE Cooktops
No ignitors on gas range top
Pull out the bottom drawer and look for a cover over the spark ignition module. The ovens have glowbars and they have nothing to do with the top( different circuit).40a0b9a.jpg
Mar 11, 2009 | Maytag 30" Self-Cleaning Freestanding Gas...
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
If they ignitors worked properly before you aunt cleaned them, the problem could be with the way they were cleaned and what they were cleaned with. Please tell me how she cleaned them and with what. Also, had she cleaned them before without incurring any problems, or was this the first time she had cleaned them?
Dec 03, 2007 | DCS RGS-486GD Gas Kitchen Range
Stove top [gas] JENNAIR
Try carefully cleaning around the ignitors. Also clean hole in burners. Clean the holes closest to ignitors. This can be caused by a crack in ignitor, this requires replacement.
Nov 05, 2007 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
You have water left over from cleaning and it is shorting out the igniters at the knobs, not the burners. I guess the solution is to wait until it dries out unless you can open the top and maybe use a hair dryer.
Sep 21, 2007 | Frigidaire FGF326AS Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
232 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
