Question about Malber WD1000 Front Load Washer/Dryer
No hot water flow
Hi I have a Maber WD 1000. I changed the washer of the hot water pipe and now the machine tries to pull hot water but it seems as though it is blocked. hot water will run through the pipe when it is not connected to the machine. please help!!
  • Anonymous Apr 16, 2008
    The water not heating
Take the top cover off the machine. You will see 2 wires connected to the hot water valve inside the machine. With the machine unplugged, carefully remove the two wires and connect them to an electric voltage meter. Then plug in the machine and run through a cycle. See if the voltage at the meter is about 110 volts. If it is, then the control board is OK and the problem is a faulty hot water valve which is relatively easy to replace.
Posted on Jan 24, 2008
    Problem Solver:
  • 13 Answers
The hot water valve may be broken.
Posted on Jan 07, 2008
Water hammering after disconnecting a washing machine. I have just replaced our old washing machine that took a hot and a cold feed, with a new washing machine that only takes a cold feed. I have turned...
You can use a water hammer arrestor and hook it up to old washing machine hot valve by use of a standard washer hose. This type of aresstor is basically. a shock absorber. You will needtonget pipe adapters to go from hose thread to pipe thread.If you can mount the hammer arressror higher then the washer valve. Hook everything up and turn old hot water valve back on. This shoulg take care of your problem. Thank you.
Jun 02, 2011 | Plumbing
Washer will not spin, filled up with water and stopped. When turn back on, it just humms then stops
The most likely cause is a blocked pipe or drain motor. This could be caused by an obstruction, such as a screw, hair clip or coin jamming the impellor inside the pump. Firstly, try to manually empty the machine of water. Take the drain pipe and lower it to a position below the machine itself. This should cause a syphoning action. Uou may have to give the end of the pipe an initial **** to start the flow. Remember to give the pipe a clean first with hot water and don't swallow any of the water.
Jul 31, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Washing machine doesnt seem to be heating up the water
Hi. Washing machines are dependent on the water supply for their heat. If it isn't getting hot, it's from lack of hot water. Put the machine on a setting requiring only hot water for the initial fill, and start the machine. If the water is at a low or no flow rate, proceed as follows: Unplug the washer, close and disconnect the hose from the hot water faucet. Inspect the inside of the hot water hose; there is usually a screen in the end to catch scale and sediment. If you see anything there, remove the washer and screen, and clean it. Reinstall the hose, and disconnect the hose at the washer end of the hot water hose. Open the faucet, and discharge some water into a bucket. If there is no water, you may have a plumbing issue, so I'd back up to the faucet and check. If you do have water there, inspect the solenoid valve inlet (where the hose connected) for another screen. Clean as before. If debris was found at either location in a sufficient quantity to obstruct your water flow, reconnect the hose, and try to get hot water into the machine again. If no hot water will enter the machine, the issue is probably with the solenoid valve. If you have an electrical test meter, you can test the valve, or replace it. Any appliance parts supply house will have your part.
Best regards, and good luck. --W/D-- Please feel free to rate this solution, and let me know what you find out.
Jul 26, 2009 | Washing Machines
Why is my warm water is cold? The hot is hot and cold is cold but warm is cold.
There is too much pressure on the cold feed, reduce the pressure on the cold by partly closing off the tap on the cold.
Or ensure the hot feed is fully open and not blocked, check if there are filters inline - remove the feed pipes at the washer end and look into the inlet valves - clear if blocked.
The inlet valve is common to hot and cold water with only a small pipe to fill the machine, the cold water is being forced back up the hot water pipe due to the pressure you can feel the pipe cool down after running hot then go to warm, if hot water is flowing the pipe will stay hot, if not then cold is going up the hot pipe.
Jun 28, 2009 | Admiral AW22 Top Load Washer
The wash liquid does not empty after the wash is finished
hi, it sound like your waste outletis obstructed or the pump is not working, to empty the machine pull the easte pipe out of the stand pipe ,get a bowl, keep the pipe above the level of the drum! slowly lower pipe into bowl the water should run from the machine to stop the flow lift the pipe above the drum level, continue until machine empty! if the MACHINE EMPTIES THIS WAY THERE WILL NOT BE A BLOCKAGE AND YOU SHOULD CHANGE THE PUMP, hope this helps you
Nov 11, 2008 | Hotpoint WD62 Front Load Washer / Dryer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
Only hot water pipe going in
Don't know that particular make, but if there's only one water inlet available the machine should use its own electric heater. A "Wash Temp" setting switch should be available.
Jan 14, 2008 | Bosch Classixx WFC 2465 Front Load Washer
I have a creda simplicity 1000 front loader washer.
Maybe the pipes are not connected to the heater on the wall. You could heat your water in the machine, if there is a provision; most machines have it.
Dec 01, 2007 | Creda W100FW Front Load Washer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
83 people viewed this question
Top Malber Washing Machines Experts
Jason Harris
Jason Harris
Android Man
Android Man
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
