Question about Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera 3900 dn, is there a way to speed it up?
  • 40 Answers
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Posted on Jan 10, 2009
I am recieving machine failure on kyocera 4200 dn
The most common machine failure codes is CF---. For example CF248, CF000. In the most cases the printer is need to be upgraded to the latest firmware.
Jun 10, 2014 | Kyocera FS Office Equipment & Supplies
Kyocera 1750 error 6000: 0002930
6000 error is a fuser error. Check connections; make sure the back door/cover where the fuser is located is closed. Turn the machine off, unplug, plug back in, and turn printer back in; if you are still getting the error the fuser will need to be replaced.
Jun 09, 2011 | Kyocera FS-3900 DTN MONO LASER PRINTER
FS 3900 "Unknow toner istall" shows in display?
The message is indicating that you do not havea real Kyocera toner installed in the machine.
Apr 04, 2011 | Kyocera Mita KYOCERA/MITA - FS-3900DN Mono...
Call for service error 7410:0112053 on Kyocera FS3900 DN
most likely the drum popped out.
open the left side cover and remove the waste toner bottle..seated just above the waste toner bottle..press on the drum unit that sits above it..you will here it pop back into place .. if you hear it snap back it simply power off than back on printer....
if the drum is seated correctly.. than you need to replace the drum unit
Jan 12, 2010 | Kyocera FS-2000D Laser Printer
Change drum kyocera fs-3900
open printer front cover and remove drum unite ,two side screw open two side spring **** two side open drum
if you are not possible it then buy a new one unite in your service authorized delar
Aug 27, 2009 | Kyocera FS-3900DN Laser Printer
Wrinkling envelopes in FS-3900 Kyocera Printer.
try chaning the quality of the envelope, some do not respons well to heat.
Jun 23, 2009 | Kyocera FS-3900DN Laser Printer
6000 error on a Kyocera FS-2000D laser printer
a fuse it is blown within the FUSER UNIT - replace that fuse or call a technician to do it for you.
May 01, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Kyocera FS-3900 DTN MONO LASER PRINTER Logo
505 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
