Question about LG GCC-H21NK Burner
DVD+RW will not recognize a blank dvd and will not burn a dvd
My cd dvd+rwgsa-h21n will play cd's and some dvd's but will recognize or burn a dvd. the error the comes up is 'please insert a blank, writable cd into drive E:\
  • 32 Answers
  • Start Registry Editor Click Start, click Run, type regedit, and then click OK. On Vista systems just type regedit in the Start Search box
  • The Registry Editor starts
  • In the Registry Editor, Expand (click the + sign to the left) My Computer
  • Expand HKEY_LOCAL_MACHINE.
  • Expand SYSTEM
  • Expand CurrentControlSet
  • Expand Control
  • Expand Class
  • Under Class, click (Do Not Expand) the entry {4D36E965-E325-11CE-BFC1-08002BE10318}
  • In the right pane (topic area), click UpperFilters
  • On the Edit menu, click Delete
  • You will receive the following message: Are you sure you want to delete this value?
  • Click Yes to confirm the deletion of the UpperFilter
  • In the right pane (topic area), click LowerFilters
  • Click Yes to confirm the deletion of the LowerFilters
  • un-install the dvd drive in device manager and restart pc
  • Posted on Dec 28, 2008
    Sony DRU510A, will burn CD fine, but not DVD, will play DVD
    Same thing is happening to me. Does anyone know of a solution to this problem?
    Feb 06, 2010 | Sony DRU 510A DVD±RW Burner
    Will burn cd-r but kicks the disk out whe I put in a blank DVD-r
    Sorry but your burner is a CD-RW/DVD-ROM
    this means you can burn CDs and play DVD
    you cannot Burn DVD with this device.
    info link here
    http://www.cdrinfo.com/Sections/News/Details.aspx?NewsId=7470
    Please don't forget to rate me : )
    Oct 01, 2009 | Toshiba SD R1312 CD-RW/DVD-ROM Burner
    Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
    right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
    It should work.
    Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
    Samsung SM-352F will not recognize blank dvd when trying to burn
    Samsung CDRW/DVD SM-352F is a CD-R,CD-RW burner not a DVD Burner
    May 16, 2009 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
    DELL laptop does not read blank DVDs
    the combo drive you listed above is a cd-rw/ DVD-ROM....meaning that it will play and burn cd, cd-r, and cd-rw disks. the dvd rom will only be able to play dvd-rom and dvd-r disks providing they are in the proper format. check that the disk in question is not a dvd-rw or (+2) disk. the drive will not recognize that a disk is in the drive if the disk isnt compatable. try a dvd movie, if that works then a dvd-r, if that works then try a dvd-rw +1. if the last option doesnt work then you will have to stick with the dvd-rom and dvd-r, or purchase a dvd-rw drive to install.
    GOOD LUCK AND DONT FORGET TO RATE MY POST!! :D
    Mar 18, 2009 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
    Won't recognize blank dvd
    Chek wtat is written on front panel
    If it DVD-RW it can record only DVD-R blank, if it + so only +R
    or DVD-RAM. If it is DVD +/- RW or RAM it can record any disk.
    Also chek the speed for you DVD and disk you using.
    If you dvd maximum speed for recording is for example 2.7, 4, 8 you should use only DVD with max speed 2.7, 4, 8 or 1-8, 1-16 etc. So they should be labeled the same as you DVD
    Good Luck
    Jan 10, 2009 | Microsoft Windows XP Professional With...
    LG LS50 DVD/CD-RW DRIVE won't recognize blank dvd-r
    Yes does not read DVD-R because if your LS50 Labeled like this (DVD/CD-RW) means that can read only all DVD Disc and cannot write on DVD blank only CD blank.
    You can burn only on the blank CD-RW or any blank CD.
    Jan 17, 2008 | LG X-Note LM50 Notebook
    Dell Cd/Dvd burner not working properly
    I have a Dell XPS 400 that's about 3 years old. I have a DVD reader and a DVD-RW device. The former works - the latter takes forever to read discs (particularly DVD data discs.)
    I'm starting to think some of the generic DVD-RW devices Dell uses in its computers are prone to early failure. The DVD-RW in my XPS-400 was called "HL-DT-ST DVD+-RW GSA-H21N".
    I'm going to try cleaning it, and then just swap it out for a better device.
    Jul 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
    Blank disc not recognized
    Sorry no solution, but why burn with mediaplayer/realplayer? you get better results with nero, or other burn dedicated software. Hope you work it out
    May 18, 2006 | Sony DW-Q28A (DW28Q) DVD±RW Dual...
    LG GCC-H21NK Burner Logo
    82 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
