Question about Sony Playstation 3 (PS3) Console
Playstation 3 How do i hook up play station 3 80 gb to internet?
Who to connect the ps3 to internate
At the moment the Play Station Network is down. There is no guaranteed time when it will be brought back up. In the mean time to connect to the internet you can use this guide: http://uk.playstation.com/ps3/support/network/detail/linked224956/item97816/Use-a-Wireless-connection/
Apr 25, 2011 | Sony PlayStation 3 (120 GB) Black Console
I can not sign into play station network. internet connection and IP address are good. when I try to sign in it will say An error has occurred. You have been signed out of play station network. (80710A06)...
Happening all over the world
Hi there, unfortunately there is nothing you can do at the moment. The playstation network is down worldwide. We just have to wait till sony fixes this http://kotaku.com/#!5794265/is-the-entire-playstation-network-down or http://kotaku.com/#!5794440/sony-playstation-outage-likely-to-last-days or http://blog.us.playstation.com/2011/04/21/latest-update-on-psn-outage/ or http://blog.us.playstation.com/2011/04/20/update-on-psn-service-outages-2/
Check the links for updates
Apr 22, 2011 | Sony PlayStation 3 (120 GB) Black Console
How do you set up playstation 3 to play playstation 2 games
One Surefire WayThe only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can’t, and there’s not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won’t help you out much here.
However, if you do have the correct console model, then there isn’t much to know for learning how to play PS2 games on PS3. Simply insert the game CD or DVD (many original Playstation games are also supported thankfully), and the game will start up. Sometimes, it will tell you that you can’t play the game, but simply hook your PS3 up via wireless or ethernet connection and update the firmware (which also provides improved compatibility with newer versions of Blu-ray discs). Often, this will fix the problems, but not all PS and PS2 games are supported (although most are).
There you have it. Learning how to play PS2 games on PS3 is easy, but if you just randomly picked a Playstation 3 model out at your local retailer, you might have a model lacking in backwards compatibility. One reason they didn’t include such compatibility with all models is an issue of cost, as it saved Sony some money to not include such a feature on all of the models. When they first started selling PS3s for $400, they were losing several hundred dollars (although they are at least breaking even now). Unfortunately, both the new 80 Gb and 160 Gb PS3 models are lacking in such compatibility, so you’ll need to find older models to support your older games.
Please rate my solutions! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Sony Playstation 3 (PS3) Console
My play station 3 80 GB
try taking it back to the store
Mar 16, 2010 | Video Game Consoles & Games
Ports not open for playstation home , all other internet usage on playstation is fine, sony saying that there is a problem with my router and has given me various codes to check with port checker all...
Hi Joan,
How are you?.I will guide you stepwise to open the ports numbers for the play station
Step 1:Open an internet explorer and type 192.168.2.1
Step 2:You will be able to see the belkin router setup page
Step 3:On your left hand side,click on firewall,it will ask for password leave it blank and click on submit
Step 4:Disable the firewall and click on Apply Changes
Step 5:On your left hand side click on Virtual Servers
Step 6:Check the first check box,in the "description" type "PS3" ,Inbound port type 80, in Type select TCP,Private IP : get the IP address of your play station and type here and in the outbound port type 80
Step 7:Follow the same steps for all the ports which is given by Sony
Step 8:After completing all the ports click on Apply Changes
Step 9:Now check in your play station,you will be able to access the PS/3
If you have any clarification,feel free to reply
Regards,
Ayyasam
Mar 14, 2010 | Belkin (F5D7230-4) Router (587009)
How do i get ps2 games to play on my ps3
The only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can't, and there's not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won't help you out much here.
Aug 18, 2009 | Sony PlayStation® 3 (80GB) Console
Having A problem with playing Blue Ray DVD's on my Playstation 3
change the bd setting to 24. make sure you download irmware 2.52..it has new bd settings features
Nov 01, 2008 | Sony PlayStation® 3 (60 GB) Console
Play station 3
you can reset the region code for playstation either by your disk that came with your playstation or by hunting down the code on the internet to reset region code
May 28, 2008 | Sony Playstation 3 (PS3) Console
Playstation Network help
Have you tried pulling up the command prompt and typing "ipconfig" (omit quotation marks)?
Mar 08, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
78 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
