Question about Dryers
Dryer startup dryer motor did not start when start button pushed but did make humm ; opened and closed door 1 or 2 times then it worked
  • 91 Answers
Motor is going out ,, repl/ check door switch is it in good shape should make cliking noise ,,,when good
Posted on Jan 04, 2009
WHEN I PUSH START BUTTON DRYER HUMMS BUT WONT START
check the push start switch, the door switch and the thermal shut off fuse
Jun 24, 2014 | GE DRSR495EGWW Dryer
My dryer initially makes a buzzing sound and will not begin the cycle until I give it a few turns manually...
you have a bad motor,if you open the door,hold the door switch in with one hand and spin the drum with the other and have someone else push the start button on and if by helping it to spin it starts usually the motor is bad but i did find on the maytag neptune style dryer that the belt cut into the belt pulley and was holding up the drum and the motor was buzzing like it was bad but like i say usually it's the motor.next time send the brand name and model number and i can help you out better.
Jan 25, 2014 | Whirlpool LER5636P Electric Dryer
Whirlpool dryer makes a buzzing sound whey start button is pushed. sometimes it will turn on for a few seconds but most of the time it just buzzes.
The buzzing is probably the relay trying to start the motor. See if the motor has a capacitor, have it checked. If the motor is all clogged with lint, the start/run switch can get blocked. Clean out all that lint with a vacuum cleaner.
Check the tub bearing, and make sure the drum spins freely.
Nov 29, 2013 | Whirlpool LER4634J Electric Dryer
I bought an amana dryer, the tumbler does not turn, it just humms.
What is the complete model number of your unit?
The start relay on the motor is bad. Open the door, hold the door switch in and spin the drum as someone else pushes the start button and post back your results.
Dec 07, 2012 | Dryers
Maytag Performa dryer blows fuse after clothes get hot. I cleaned a large buildup of lint from inside the dryer all the way to my roof. I then replaced the hi limit thermostat, thermal fuse and dryer...
their are two possiblities causing that
1) while cleaning the lint from the motor a wire accidently got pulled of of the motor switch
2) to me the buzzing when start button is pushed and may or may not start,the motor is bad
When trying the trick to start the motor by hand the door switch also must be pressed in
Gene
Aug 05, 2011 | Maytag PYE2200 Dryer
I have a whirlpool dryer and when you push the start button the motor just humms and the tumbler doesn't spin. i opened the door spun the tumbler and push the start button and closed it quick and it...
You need to test it, but when the drum doesn't spin on its own, that more than likely means the motor is going bad. If you remove the belt from the motor pulley and run the motor with no load on it for a few minutes and then reattach it see if the motor runs this way, you may get a few more runs out of it. You can usually access the belt pulley form the rear compartment of the dryer.
May 12, 2010 | Dryers
Our DLG0452W dryer will not start occasionally, I then open the door and push in the door switch and rotate the drum and quickly close the door and 1 out 4 times it will keep running. Next time it may be...
The problem is with the centrifugal switch on the dryer motor. This switch connects the start winding of the motor which provides additional torque at startup. Once the dryer is up to speed, the switch disconnects the start winding. If it malfunctions, the dryer will not turn and the motor will hum. By spinning the drum, you are providing enough torque for the start winding to be able to take over and bring the dryer up to speed.
You may be able to correct this by simply lubricating the centrifugal switch which may be sticking. I am not sure if the centrifugal switch is replacable, or if a new motor is necessary if lubricating does not solve your problem.
Mar 14, 2010 | LG DLG0452W Gas Dryer
WILL NOT START WHEN YOU TURN THE START SWITCH, THE MOTOR JUST HUMMS
two possibel reasons for this
1, you have something stuck in the blower moter
look down the lint trap you may just be able to see it
2. your motor is going bad
open the door and hold the door switch with tape or something like it
push the button and try to spin the tumbler while you hear the buzz
if it starts up and the buzz goes away,,,, your motors start wionding is gone and you will need to replace the motor
Oct 21, 2009 | Dryers
Dryer just sits and hums
if you push the start and it just humms it is a bad dryer motor to weak to kick on,to confirm this have sombody hold the dryer door button in and turn the drum when you push the start button,if it jump starts you know it's a bad motor-mike
May 05, 2009 | Dryers
Must hold start button to run. no heat
disconnect power and remove lid. Test the door switch w a volt meter do so opening and closing the door not pushing switch if circuit stays open try pushing switch with finger. If pushing closes circuit then adjust switch.If circuit stays open replace switch. If switch operates with no problems then it is the motor. Check all connections and vacuum lint from motor
How old is this dryer?
Dec 30, 2008 | Kenmore Dryers
Dryers Logo
Top Dryers Experts
