2000 Mercury Villager Logo
Posted on Sep 27, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is code 325
Engine light went on and I put my ob2 on and it read PO325 and PO139, my car turns off whenever I come to a stop sign of light. what could this mena
Marvin
Level 3:
Top Expert:
  • Mercury Master 85,242 Answers
  • Posted on Sep 28, 2012
Marvin
Mercury Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29059505
Points
266281
P0325 - Knock Sensor Circuit Malfunction
Possible causes- Faulty knock sensor
- Knock sensor circuit short to ground
- Knock sensor circuit short to power
- Knock sensor circuit open
- Faulty Engine Control Module (very unlikely).
P0139 - O2 Sensor Circuit Slow Response Bank 1 Sensor 2
Possible causes- Rear Heated Oxygen Sensor Bank 1 harness is open or shorted
- Rear Heated Oxygen Sensor Bank 1 circuit poor electrical connection
- Faulty Rear Heated Oxygen Sensor Bank 1
- Inappropriate fuel pressure
- Faulty fuel injectors
- Intake air leaks may be faulty
- Exhaust gas leaks
1 Related Answer
Anonymous
  • 124 Answers
  • Posted on Mar 11, 2009
SOURCE: engine light on when slow running or reverse car
you could have a bad torque control switch.it should on the front of tranny behind radiator. unplug it and drive around if you have power then that switch needs replaced.
1helpful
2002 mercury villager code po325 code po138 code po139
P0138 O2 Sensor Circuit High Voltage (Bank 1 Sensor 2)
P0139 O2 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0325 Knock Sensor 1 Circuit (Bank 1 or Single Sensor) -Circuit Malfunction
think you just need a new o2 sensor
1helpful
Engine/Transmission problem. Rough-running engine
Get the codes read. you will get a better idea of where to start testing to repair this one. Most auto parts stores will do this for little or nothing. Please get back to me and we can trouble shoot this together.
Engine codes po325 po442 and air bag light
Determine what the code descriptions of errors are. Then check and replace as needed.
Airbag light indicates problem with airbag system. You must visit the dealer to have analyzed and diagnoses given. Do not attemp to fix yourself. The airbag system, can cause severe injury or death.
Po325 code on 97 nissan maxima
P0325 NISSAN - Knock Sensor Circuit Malfunction
- Faulty Engine Control Module (ECM)
Read more: http://engine-codes.com/p0325_nissan.html#ixzz29K4BM3th
3helpful
2answers
DTC - PO340, PO325
My Nissan micro 2004 model just stopped in the middle of the road one day then the engine management light came on, anyway took it to my local garage TWK Thomas who said it was a cam shaft sensor problem. OK so sensor was put on, engine management light went off for two days only. So went back to the garage they said that another sensor should be fitted on the opposite side. And then the problem should be rectified, but i had given the £160 for this problem to be fixed the first time. I decided it was time to take it to another garage Nis Tec they put it on the computer and a code po340 came up would this mean another sensor or the cam chain has stretched please help. ...claire
1helpful
I have 1998 Nissan Frontier with an engine light on. I paid a mechanic to put in a speed sensor and the light came back on the day after he put in the new part. The codes before he worked on the truck were...
the PO 325 code is for VSS vichicle speed sensor and PO500 is for a knock sensor,so you will need to see what the new code is to be able to help you, the engine power manegment is controled by both get it scanned by autozone or the mechanic that did the work and see if it's the same code, if it is you may have a short or an ecm going bad. let us know what codes you find.
2helpful
Diagnostic codes
744 is to do with your torque converter clutch circuit, intermittent malfunction. 325 is knock sensor malfunction. Has vehicle been shifting different, probably at highway speed? (cruising) Have you noticed engine "ping"/"rattle" on acceleration? These would be common occurences with these codes.
Top Mercury Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Mercury Expert? Answer questions, earn points and help others
