Question about Whirlpool SCS3014LS Gas Cooktop
Ignitor's won't ignite on built in whirlpool gas cooktop
Our ignitor's have quite working, we can hear a faint clicking noise when we turn them on however they won't ignite the flame. We can't get the cooktop apart to look inside. Can we replace the ingnitor ourselves? If so how hard is it. Model # SCS3014GS3 Seriel #XM1208003
2 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: cleaned gas cooktop and spark ignitor started sparking on its own
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
Posted on Aug 19, 2010
What wood cause a burner to ignite and will not turn off.
Is there an orange glow in the burner area when this happens? If so then the thermostat is not shutting the ignitor off and needs replacing. If there is no glow then the gas valve is not shutting off the gas and needs repalcing
Oct 10, 2014 | Whirlpool Kitchen Ranges
What causes gas igniter to keep clicking when gas is off
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Also, install the new switch harness (if that's what you do) starting from the left front valve then clockwise. The original unit installed from the right front valve, then clockwise. Hope this helps.
Jun 20, 2010 | GE Profile JGP636 Gas Cooktop
Cleaned gas cooktop and spark ignitor started sparking on its own
heatman101
Apr 07, 2010 | Whirlpool SCS3014LS Gas Cooktop
The igniter on the right front burner of my GE Gas cooktop does not work....I must use a lighter or match to ignite....What can I do? There is no clicking sound when I turn on the burner?
the very first thing i would do here is to check the ignitor itself
under the head cap you should see two screws, once those are out you will be able to lift the burner plate, lift the burner plate, you will see, or should see the ignitor, and the wire.
i check this for voltage by unplugging the ignitor and olding the wire close to a ground, the metal body is good. Turn on the ignitor, becareful it is live. yhou shgould see a spark comming from the wire
if not check to make sure that wire is in position and on the spark module
if you do see a spark this way, just order the replacement ignitor
and install it when it arrives
appliancepartspros.com
part number AP3191250
Oct 17, 2009 | GE 30 in. JGP328 Gas Cooktop
One igniter won't work right on my gas cooktop.
If you're not getting the ignitor sparking (you should hear it) when you turn the burner knob on for that burner, it could be that either the ignitor is dirty or caked with some gunk and needs to be cleaned.
The other issue could be that the ignitor is faulty and needs to be replaced. If you want to confirm a faulty ignitor before ordering a new one, you can swap it out with one of the other ignitors on the cook top. Be sure to unplug the cook top from the outlet thou, to prevent getting a shock, as those little sparkers can give you a pretty good jolt!
Just remove the grates and burners to get at the ignitor for cleaning it. To get at the ignitor, youll need to go under the cabinet or counter that the cooktop is installed on in order to remove the ignitor and swap it with one of the other ones. You'll see that these are held in place with a retaining clip you can remove with a flat bladed screwdriver, etc.
If you find that the one that isn't working is faulty, you can order one from your local appliance service store, or get one online. www.searspartsdirect.com lists parts for almost every appliance there is, just enter in the full model number to get a parts list, etc.
Hope you find this Very Helpful and best regards!
Sep 09, 2009 | GE 30 in. Profile JGP932 Gas Cooktop
Ge jgp337 ignitors continue to click after gas ignites
You have a bad ignitor which will have to be replaced. Unplug one ignitor at a time until you find the faulty one.
Jul 24, 2009 | GE 30 in. JGP337 Gas Cooktop
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Igniters are not working right
when you turn any burner control to lite all ignitors should click this is normal industry wide. the ignitors are controlled by switches that are placed over the valve shafts they are wired up together so thats why they all click when you only operate one valve don't worry about it. the ignitor stays on untill you back the valve off a tad this is also normal.
Apr 15, 2008 | Cooktops
Clicking noise on cooktop even when all burners ignite
I have a viking gas cooktop. The ignitor on one of my front burners wouldn't stop clicking even after the flame ignited. I swapped that ignitor with the ignitor from a back burner, expecting that the problem was with the ignitor and that the back burner would start to click incessantly, but at least I'd have my favorite front burner for use. Instead, the front burner was then only clicking 50% of the time and the back burner was fine, suggesting the problem was related to the burner not the ignitor. I pulled the front ignitor a bit away from the burner and now it is working normally. Hope this helps.
Dec 01, 2006 | Viking 37 in. VGSU161 Gas Cooktop
Whirlpool SCS3014LS Gas Cooktop Logo
43 people viewed this question
Top Whirlpool Cooktops Experts
vince
Timllfixit
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
