Question about Toshiba Satellite M55-S135 Notebook
Will not booth up with battery
Just recently my laptop stopped boothing up with the battery. So, I brought a new battery and it still will not booth.
Hi ,i have s type jaguar. my battery gone flat and i cannot openthe booth at the back ,manualy or by electric. how to open the booth please ..help?
You can use one of the plugs that go into the power point/cigarette lighter. Cut the end off add wire to reach a good 12 volt battery. Plug it in. This should give you power to open the boot with the switch.
Aug 07, 2016 | 2002 Jaguar S-Type
Is it important to clean the seamless spray booth after each use?
It is important to keep your booth clean after each use. This is why seamless booths are so special; they cut down on the difficult cleaning that comes with booths that aren't seamless.
Feb 03, 2013 | Crafts & Hobbies
What is a seamless spray booth?
A seamless spray booth is a booth that artists who spray glaze or anything else that may be toxic use to help cut down on over-spray of the chemicals used.
My router does'nt read the modem, it never stop boothing!
Remove ALL cables, verify connections , connect cables, Unplug the Modem, remove battery, unplug the Belkin. Install battery in Modem and plug in, let it run a selftest, when finished, plug in Belkin allow it to selftest. Reboot computers.
Dec 12, 2012 | Belkin F5D8236-4 Router
Squeaking noise in front end of 2006 Dodge Dakota - both sides
Could be ball joints or lower control arm bushings.
You can try soaking the bushings with wd40 and see if the squeak goes away temporarily.
Jul 06, 2012 | 2006 Dodge Dakota
Is it possible to record using a USB interface with a red and white RCA ******** a djm 500 to a laptop as it has no rec out
yes just use the booth out as your record out..... then you can use the booth volume as another recording level also......... if you need the booth and the master use the XLR master out for your master and then you can use the other RCA master out as you record out .................
hope this helps
Jan 18, 2011 | Pioneer DJm500 Professional DJ Mixer...
I cant find 'photo both' on my mac laptop please help?????
photo booth is downloadable from www.apple.com its also on the operating system cd. Someone might have dropped it into the recycle bin on accident.
http://www.apple.com/macosx/what-is-macosx/photo-booth.html
thanks and please do reate your solution.
Jan 24, 2010 | Apple MacBook Mac Notebook
What are the game rules for junior monopoly?
EQUIPMENT
MONOPOLY® JUNIOR game board
"Monopoly" brand money
l Deck of 24 Chance ("?") cards
4 Car movers
l Die
48 Plastic ticket booths (4 sets of 12).
SETUP
Pick a car mover and place it on "GO!" Put any extras aside, out of play.
Each player takes 10 (or 12 in a 2-player game) Ticket Booths that match the color of his or her mover. Put any extras aside, out of play.
Shuffle the deck of Chance cards (with the "?") and place them face down on the marked place on the board.
Choose a player to be the Banker. The Banker separates the money into the different denominations and gives each player the following:
five $1’s, four $2’s, three $3’s, one $4, and one $5.
The Banker also plays the game-but always keeps the bank’s money separate from his or her own!
Roll the die. High roller goes first.
GAME PLAY
On your turn:
Roll the die and move your car mover that many spaces along the Boardwalk then..
Follow the instructions on that space.
Note: During the game, if you don’t have the exact bill to pay what you owe, the Banker will make change for you!
SPACES ON THE BOARD
If you land on...
An Amusement without a Ticket Booth:
YOU must pay the Banker the amount shown on the space, then put one of your own Ticket Booths on it.
You’re now in charge of this Amusement, and anyone who lands on it must pay you the entrance fee shown on the space!
An Amusement with a Ticket Booth:
Pay up! YOU must pay the owner (the person whose Booth is on it) the dollar amount shown on the space.
And if that person owns both Amusements of the same color, you must pay double the amount shown!
GO!:
Every time you pass GO!, collect $2 from the Bank.
Don’t forget to collect, because if you do, you’re out of luck!
A Railroad:
Roll again, move, and follow the instructions on the space you land on.
Fireworks or Water Show:
Pay $2 to see the show. Put the money on the "Rich Uncle Pennybags’ Loose Change" space.
Rest Rooms:
If you land here by a roll of the die, you are "Just Waiting."
GO to the Rest Rooms:
YOU must put $3 on the "Rich Uncle Pennybags’ Loose Change" space then move your mover immediately to the Rest Rooms. Do NOT pass GO! and do NOT collect $2.
On your next turn, roll and move as usual.
Rich Uncle Pennybags’ loose Change:
If YOU land here and there’s any money on the space, you get to take it all!
Chance-?:
Draw the top Chance card, follow its instructions, then discard it face up next to the Draw pile.
If you use up the Draw pile, turn the Discard pile over and use it again.
THE CHANCE-"?"-CARDS
"Go To" or "Take a Ride" Spaces:
Move your mover immediately to the space indicated, then do whatever you would ordinarily do on that space.
If you pass GO!, collect $2.
Free Ticket Booth:
Do not move your token. Place one of your own unused Ticket Booths on either of the unoccupied Amusements of the color shown on the card.
If both Amusements already have two different colored Ticket Booths on them, you may remove either one of them and 1 replace it with your own Ticket Booth. Give the booth you remove hack to its owner.
However, if both Amusements have the same color Ticket Booths already on them, you’re out of luck: You cannot replace either one.
In this case-and only in this case-you may discard this Chance card and draw a new one.
Follow its instructions.
STRATEGY HINT:
When you draw a "Free Ticket Booth" Chance card, replace a Ticket Booth of the player who is farthest ahead in the game.
Remember, it’s to your advantage to have your own Ticket Booths on both amusements of the same color so they cannot be taken away when another player draws a "Free Ticket Booth" card. Also, owning both means you collect double when someone lands on either one.
WINNING
As soon as one player runs out of money, the game ends, and all the other players count up their money.
The player with the most cash on hand wins!
Oct 09, 2009 | Monopoly Games
Photo booth doesn't work
this is not from office mac 2008 check either you have install iglasses or another software for chating or other purposes try uninstalling that . then restart. rate this
Jun 06, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Toshiba Satellite M55-S135 Notebook Logo
87 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
