Question about RCA R52WH73 Projection Television
Colors are not lined up
Convergence does not show up on the setup menu how do i fix?
  • 10,594 Answers
If it is RCA R52WH73 TV then it got convergence out IC defective so Convergence Menu doesn't appear.
You need to replace convergence out ICs or board.
Posted on Dec 28, 2008
Fixing color convergence red and blue lines
most TVs have an adjustment for convergence in your on screen menu, go into convergence of service menu & try to adjust; it it is still too far out of convergence contact a service technician as convergence issues can be very difficult to resolve unless you are very sure of what you are doing.
Dec 26, 2014 | Televison & Video
At the top of TV there is a color line that is bowed it will not show a picture and another problem is the color. For example when it says menu on the screen you can see it in red, gren and blue not just...
Ur tv have a problem known as a convergence picture problems it is dead.Tv have any colors lines R,G,B mis alignments,have colors shadows picture or 3D pictues look alike?Yes.The tv convergence board it dead have to be fix like replacing 2 STK convergence ICS and some or all of it resistors too.Fixed the convergence board to solved tv convergence picture problems.The tvs shops will cost u like $300-350 for parts and labors.
Aug 25, 2011 | RCA HD52W59 HDTV Projection Television
Red,blue,green lines in screen....sound is fine. How can I converge the colors back?
Go to Menu then Setup Look for Convergence, If you do not see Convergence in the menu, then you have a blowed Fuse on the Deflection board.
Dec 23, 2010 | RCA R52WH73 Projection Television
The red color seems to be sperating itself from the actual picture. The logos on screen are showing up as double image. pls advise what could be the problem
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Aug 14, 2010 | Sony KP-51HW40 51" Rear Projection...
My set is showing a kinda warped display where the colors won't line up. I tried the resets in the menu and it didn't help...
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
  • Screen looks 3D
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
May 14, 2010 | GE 46GW947 46" Rear Projection Television
Red color convergence issue; Red lines are curved
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Nov 24, 2009 | Televison & Video
Panasonic hdtv projection colors will not line up
If only minor convergence issues, the setup menu has user controls for 9-point convergence. If it's major misalignment in just one color, you may have a blown convergence amplifier chip. Big bucks repair, unfortunately. Chipsare about 30-40 dollars apiece but labor will kill you if they'll even fix it on-site. Most try to order $700+ board which is no longer available. Teh they send yours out for -10 weeks at similar prices.
Jun 04, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Convergence
if you cant converge from menu. your convergence ic is going bad.
Jun 02, 2009 | RCA R52WM24 52" HDTV Projection Television
I have a zenith pvr5263dt projection television.when I turn it on the color is out of alignment, I go to the menu and in one section of setup cross hairs come up with the colors misaligned but it does not...
This is a convergence problem and is either bad connections at the convergence ICs or defective ICs. If you can solder, you can fix this yourself. Please let me know if you wish to do this and I'll provide more detailed instructions.
Dan
Sep 09, 2008 | Zenith Televison & Video
55pp935217 Way too much blue
No sounds like the blue CRTs coolant has congealed and thats whats giving you the trouble. the blue tube get congealed and will cause the blue to not even show up properly in the convergence menu
May 18, 2008 | Philips 55PP9352 55" Projection Television
RCA R52WH73 Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
