Question about Stanley Pneu Roof Stapler
I have a ridgid brad nailer. I am running about 100 psi. It will not fire. I hear it try, meaning the I hear air coming out, but not a fire. I tried my other gun ridgid finishing nailer and it is doing the same. It worked before. any ideas
  • steve_meckle Dec 29, 2008
    Thanks. Believe it or not, it turned out to be the "air hose/couplings" Funny, I could inflate tires and blow dust with the "faulty hose/couplings" and compressor set up, but somehow, I guess the hose/couplings was not putting out enough to run the nailer.
    Luckily I had spare hose and couplings and the gun fired. I knew it could not be the gun, meaning what are the odds of 2 guns going out at once. I think I might go back and replace the couplings on the other hose to to know for sure if it is the hose or not. Things are working great, thanks for replying.
    Sergeant:
  • 359 Answers
Insert a open fitting adapter into the connection end and make sure you are getting a good air flow with open ended connector hold away from face and eyes while doing test and be sure the fitting is well seated into coupler before releasing . let me know result
Posted on Dec 29, 2008
  • Allen Neal
    Allen Neal Dec 31, 2008
    good so i was on it
16 g brad nailer... Brand new... Fired 100 nails then stopped. Air goes phssst at trigger assembly when fired
There is big O-ring which is fly away - required to be disassembled and fixed. Bring to repair shop
Oct 07, 2013 | Porter Cable 16 - Gauge Finish Brad Nailer...
Ridgid brad nailer Pull trigger n it sounds like a little lizards hiss
replace the orings around the trigger, or buy a oring kit and replace all orings
Sep 30, 2012 | Ridgid Air Tools & Compressors
When I pull the trigger, the nailer just goes "futz". no brad coming out. no jam. not used over 100 psi. two nailers have given me the same problem
The first thing that comes to mind is they are not being oiled properly. Follow the directions for the number of drops of air tool oil to put in daily. If they have been run dry, this makes quick work of the Orings and requires rebuilding the nailer with new Orings.
The second thing is if contamination has gotten into the cylinder bottom thaat can happen if a jam has ever occured.
Dis-assemble the nailer and inspect for these conditions.
Jun 11, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
Brad nailer not firing properly
need to rebuild. the kits are about $15
Jan 15, 2010 | Senco FP18 FinishPro 18 - Gauge Brad...
Makita AF503 Brad Nailer won't fire nail
Take head off of tool. Clean and lube orings on the head valve . Do not use wd40 use air nailer oil.
Apr 11, 2009 | Makita AF503 2'' 18 - Gauge Brad Nailer
Nails won't shoot
18 guage nailer has a very thin driver and plastic cylinder which bends or breaks easily. Remove the head noting all the parts in the head and remove the piston which should be at the top of the cylinder. Check for broken or bent shaft. Most likely broken and jammed in cylinder. Parts are not expensive. Check WWW.toolpartsdirect.com for diagram and parts
Nov 17, 2008 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
Stanley Pneu Roof Stapler Logo
104 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
