Question about Kenmore 24 in. 17032 Built-in Dishwasher
The "spinner, 3rd level wash" kept falling off. Ordered new part, no instructions with it.
The spinner kept falling off and didn't stay in place when I snapped it back in. Did order a new part, and the package came with the spinner and a small pointed plastic piece that I guess the spinner snaps on to. Package stated 'easy to install' but no clues on how or where this little pointed plastic plug goes! Do I have to remove the feed tube assembly to remove the old pointed piece and insert the new one?
  • 1 more comment
  • bwepp Jun 08, 2008
    I had same problem and ordered part as well. When I saw the comments I took the assembly a part and removed the plastic "male" end whihc is inserted from the top of the tube. It looks worn and that is why the spinner comes off when wash cycle is used. I get my part tomorrow but before I put it back together I turned a stove burner on and when it was getting hot I just touched the end of the plastic to the burner to cause it to "flatten" out a bit. It now snaps in to the "female" part quite firmly. If it works I will just save the new part for a later install. (Note: if you loosen the single screw on the feed tube the tube gives enough that you can easily get your finger behind it).
  • Jessica Roland Jun 14, 2014
    OK, that is just brilliant. I was about to order the part, but I tried heating up the plastic instead (used a candle and the side of a scissor blade. I almost shortened it too much, but I reinstalled it and so far it works great. It is a very poor design, but this is a good short term solution.
    Very smart repair solution! I used a candle and the side of a scissor blade instead and almost shortened it too much, but I reinstalled and it is working for the moment! The part is a poor design, but this is at least a good short term repair!
I had the same problem, the 3rd level spinner falling off. Without getting into my saga story, save yourself some $$$.
-You will need a screw & washer to replace the plastic thumbtack. The screw will have to be able to screw into the female part of the spinner; the washer will keep the screw from falling out of the hole in the flat hose on the ceiling of the dishwasher.
-If you look closely at the spinner(the part that keeps falling off), you will notice it comes apart. With a flat head screwdriver, separate the 2 parts. (there are 3 parts all together; Keep the round center piece sticking out of the top peice)
--Remove the top drawer of the dishwasher to give you some room to work
-Remove the screw on the "ceiling" of the dishwasher(it is located further back from where the spinner goes) to allow the flat pastic tube to come down low enough for you to get in behind it.(set that screw aside in a safe place; you will put it back later)
-Remove the pastic thumbtack from the hole in the flat plastic tube if it is there & replace with a washer and screw.
-Take the top 2 peices of the spinner, together as assembled & screw the screw into the female portion of the spinner.
-snap on the 3rd piece of the spinner
-replace the screw you took out earlier, securing the flat plastic tube.
-place top drawer
Voila, you are done!! You just saved yourself $20+
Posted on Mar 16, 2009
Yes, this worked, once I figured out that the "flat water feed tube" is not a round tube in the middle of the hole, but is the whole flat piece (about 1.5 inches wide) that has the hole in it. That piece does bend down enough for a finger to get in there, and pushing up through the hole with a toothpick revealed that the old thumbtack-like pin was still in place (above the flat piece), but I replaced it with the new one that came with the kit. Then I kept my finger on top of the thumbtack-pin while pushing the new cone-shaped piece up though the new spinner until it snapped into the pin (it took a fair amount of force to make it snap in). Thanks for the advice!
Posted on Jun 21, 2008
I came here today looking for the solution to this same problem! However, I might be able to help a little...in searching the bottom of the dishwasher, I found the pointed plastic piece for mine. To put it back in, here's what I did -- the 'vanes' of the spinner face the top of the dishwasher, align the center hole of the spinner with the hole in the 'ceiling' of the dishwasher. Push the small plastic piece (pointed end up) up through the center of the spinner and snap it into place, attaching it to the dishwasher. However, whenever I put mine back in, it comes out in the next wash. I'm assuming that my spinner keeps coming out because my plastic piece is worn(?) I was wondering if there was a screw involved to hold it into place, but from your description of the parts bag (spinner and plastic snap) perhaps there is not. I'll order my replacement part and see if that fixes it. Anyone who knows about this for sure -- please post for us! Thanks!
Posted on May 14, 2007
  • Eric Wylie May 14, 2007
    I think I just figured it out.
    Grab a toothpick. Slowly and carefully bend the flat water feed tube away from the ceiling of the dishwasher. Put a finger or two above the feed tube. Using the toothpick, push the small 'pin' up and out into your hand.
    I'm guessing the that plastic piece in the parts bag is conneted, but can be separated into two parts. The small pin (looks a little like a plastic thumbtack) and the cone-shaped piece. Separate those two pieces if my guess is right.
    Place the new pin into the top the way the old one came out (bend the feed tube down just a bit and place the pin over the top, with the point facing down into the dishwasher), line up the spinner with the top hole. Keep a finger up above the feed tube on the back of the pin and then push the cone shaped piece up through the spinner into the hole, snapping into the pin.
    Now that I can see all the parts -- this makes sense. I hope that helps.
I received a box today that I didn’t order it has no return label
Take it back to the post office...do the right thing, you would want someone to do that if your package was delivered to there address by mistake. At least there someone can track their package because that is the first place people would go to for missing packages.
Dec 15, 2017 | BOX Computers & Internet
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
Thanks.
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
Thanks.
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
How do you install part# 8193768 spinner for kenmore dishwasher model#66517364300?
You should have 3 parts. The spinner, a cone shaped insert and the snap pin. The cone shape insert is the first part to install. Look at the upper spray feed tube in the top of the dishwasher where the old part used to be. Place the cone shaped insert on top of the spray tube through the hole with the flat part on top. Now take the spinner and snap it into the cone shaped insert from the bottom of the hole. Be sure that the swirling vanes are facing upwards. It should snap in. With the snap pin, push it into the insert underneath the spinner. This is what holds the spinner to the insert. Good luck.
Jun 20, 2011 | Dishwashers
Where can replacement parts be brought for the Crayola Magnetic Double Easel
n order to make the art trays stay on the easel (several people have complained that they easily fall off), you have to reach behind (inside) the easel and snap them on. You don't just sit them on; they snap in place. Do this and they won't keep falling off. : ) if thats the problem....there are no replacement parts...
May 18, 2011 | Crayola Toys
Kenmore 500 series dryer heating element stays on when dryer cycle complete
Element shorted to frame most likely. Remove and inspect the element. themobilian_2231.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Apr 24, 2011 | Dryers
My washer had stopped spinning about two weeks ago, we replaced thecoupler and it worked fine but today it stopped spinning again
5
6
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Washing Machines
Kenmore 24 in. 17032 Built-in Dishwasher Logo
1,985 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
