Question about Mitsubishi WS-65511 65" Rear Projection Television
Mitsubishi WS-65511 Red and fuzzy picture
All of a sudden my TV has a deep red hue on the screen and the picture is not well defined. I tried the convergence reset (to factory settings and a manual reset) but no change in the picture. Any suggestions? Thanks!
  • ldbrick Jan 01, 2009
    No, I do not see any blues or greens and would not call the fuzziness in the picture 3-D effect.
  • ldbrick Jan 03, 2009
    Problem turned out to be anti-freeze from the red tube that dripped onto the ckt board. Tech cleaned off the ckt board, removed/resoldered 3 capacitors to make sure all anti-freeze was cleaned off, and put a small plastic shield over the board to prevent any future drip from hitting the board. Fixed all in less than an hour. Thx for help.
    Genius:
  • 1,011 Answers
Sir,
First u look for bad connections on the convergence ICs. These are large black ICs attached to a heatsink. They will have 15 pins or so. Resolder all of these pins and report back with your results.
Also Sounds like you have cold solder joints, or solder joints on the mainboard which have cracked over time due to thermal expansion and contraction of the circuit board.
Repair is to find and reflow the cracked joints. You may want to consider hiring the services of a reputable repair professional to deal with getting your set back into normal operating condition.
In the meantime, stop using that TV in its current condition! Continued use in that state could make the problem worse or create new headaches that may only allow for a more expensive repair bill.
thanks
good luck
Posted on Jan 01, 2009
  • 10,594 Answers
Let me know do you see Green and Blue colors in picture or they just disappeared?
Does picture give 3D effect ( 3 pictures) If yes, its convergence failure.
  • Shahid Electronics
    Shahid Electronics Jan 01, 2009
    OK, Its issue of over gain of red picture tube in this TV.
    Let me know, do you want to repair it by yourself? If yes, you should have TV repair experience, knowledge of electronics and good soldering skills.
    upon then I will provide you service manual of WS-65511 to carry out repair.
    Shahid Electronics Jan 03, 2009
    hummm, its not anti-freeze, it calls coolant oil and its very necessary in rear projection CRT to keep its surface cool.
    You need to put coolant oil again at CRT surface and TV tech will do the job. Please do not use TV mean while as it can damage red crt permanently.
Convergence bad on Mitsubishi WS-65511
if you are not handy with soldering you might damage tv more if you tray to do it yourself,but you guys can send your board for repair to us for professional convergence repair with new Parts,3 month warranty.
just go to ebay site and look for TEXAS TV PARTS,or texasgreatdeals4you,then when inside store just type convergence board repair service,if you don't see repair service for your tv just ask via ebays mail,Thanks,
Jan 10, 2014 | Televison & Video
My picture getting dark red and moving slowly to the left. My manual is missing and I can't remember what to do.
Ok I have found you a user manual. http://www.retrevo.com/support/Mitsubishi-WS-65511-TVs-manual/id/276ci860/t/2/
Below is the service manual. http://www.eserviceinfo.com/index.php?what=search2
I cannot be sure, if that is something that simply needs resetting or some problem. However I suspect that there may be a problem with the Color Wheel or Alignment. Of course it may be a filter. have a look through the service manual and run through the set up again. This may fix the problem. But I wonder if it will be that simple, we can only hope.
Mar 12, 2010 | Mitsubishi WS-65511 65" Rear Projection...
No Picture after Wii Play: 65'' Mitsubishi HDTV 1080 (WS-65511)
mmm try this.... do u guys have the yellow white red cables hooked up to the front of the tv from the wii console? try loosening them up. worked for me. let's see how long it lasts .... !!!!
Dec 27, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Double picture on Mitubishi WS-65511, Year 2002 TV
Your tv requires replacement of STK393-110 as it creates convergence problem and its available Parts Store here. If you want to do the job at your own, you need to know good soldering skills or get service of nearest TV repair shop.
Sep 13, 2008 | Mitsubishi WS-65511 65" Rear Projection...
Sony KV-20FS120
You need to replace its Picture Tube (CRT). Its CRT's defect.
Jul 29, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
