Question about Compaq Presario sr1403wm AMD Sempron 3000+ Computer PC Desktop
When turning the power on get a beep a pause a beep
No video
  • 1 more comment
  • 1950jrs Dec 28, 2008
    Tried 3 different video cards, still have the same beeps
    I also replace dthe memory with no change. I do not have documentation on this computer, have no idea which jumpers to reset the bios
  • Eric Ramirez
    Eric Ramirez May 11, 2010
    Are there any lights on the laptop (power, HDD, etc)?
    Do you hear the cd or hdd spinning?
    Have you tried to hook to an external monitor?
    President:
  • 1,179 Answers
Sounds like the graphics card has either come unseated or has went bad. Try reseating the card but be prepared to replace because that is the common fix. Hope this helps & please remember to rate my answer.
Posted on Dec 28, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 28, 2008
    Thanks for the terrible rating even though my answer was correct for the original problem you posted.
    President:
  • Compaq Master
  • 1,314 Answers
If your monitor plugs directly into the motherboard, then you need to purchase a video card and install it in your system. The computer will bypass the built in video and use the video card. If your monitor plugs into a separate video card already installed in your system, then that card needs to be replaced. That is what the beep code means when you turn it on -- the computer can't find the video. Oh, and please take a moment to give this solution a fixya rating. Thanks! :c)
  • Kevin Shafer
    Kevin Shafer Dec 28, 2008
    Well it would have been nice to have known that in your original question before you gave a bad rating.
    Have you tried resetting the BIOS through the motherboard jumpers first?
    Beep codes can also indicate bad memory, which would stop the computer from dipsplaying video also.
I'm trying to recover my system, but everytime I push F11 to get to the System Recovery Manager, I get a repeating Beep.
That sounds like it might be "POST" code beeping out at you. If it goes beep beep beep (pause) beep beep (pause), or something like that, etc.... then it is definitely a POST code. It can be anything from a bad or unseated video card, to a loose memory DIMM card.
The computer's BIOS chip is hardwired to a dedicated speaker, if something goes wrong (like your video card is roached), it beeps out a series of beeps (not unlike Morris code). Check the manufacture's website, see what BIOS your model is using (AMI, PHOENIX, ETC..), and then look up their website to interpret the code you are getting. The computer Mfg.'s manual might also have that BIOS POST code information in it too.
Please give more detailed information about the beeping sequence. Like, does it ONLY beep after pressing the F11 key once, or because your holding it down (keyboard buffer is full then). Are the beeps continuous, or are their pauses between beeps (if pauses, count number of beeps between pauses until it repeats, usually has a long pause before it repeats if BIOS POST CODE). Also, did something happen just prior to your computer going belly up, or did it just not want to turn on one day? Give as much information as possible (make, model, OS, etc) about your computer, and what its symptoms are. The more info I have, the better I can help you.
Jul 29, 2011 | Computers & Internet
Computer will not start
It all depends how many beeps there were.
From http://h18000.www1.hp.com/products/quickspecs/12253_div/12253_div.HTML
Diagnostic LED Explanation Table Number of 1-second red LED blinks followed by 2-second pause, then repeats:
2-processor thermal protection activated
3-processor not installed
4-power supply failure
5-memory error
6-video error
7-PCA failure (ROM detected failure prior to video)
8-invalid ROM, bootblock recover mode
I have only really come across 4 beeps = order new Power Supply or 5 Beeps = reseat the memory and hope it works
Regards,
Oli
Apr 15, 2010 | HP Compaq dc7600 Small Form Factor PC...
Hp Pavilion a6500f Pc. When you turn it on, all it does is beeps. Key board does not lite up, or nothing.
depending on the beeps, you cand determine from where the problem is.
beep pause beep pause and so on its from ram disks
long beep pause beep beep its from video card
try cleaning the ram and video slots with a dry toothbrush not to hard though
Jan 02, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
When I go to turn on the computer, it just makes a beeping sound.
Beeping sound leting you something is wrong with some hardware. As for what,, listin to the beeps.. also depends on motherboard... here is a link http://www.pchell.com/hardware/beepcodes.shtml
But best way is to open up machine and make sure all the hardware is hooked up tight. If that does work look at the code list then go from there.
Sep 09, 2009 | Acer Aspire X3200 PC Desktop
My Pioneer AVH-P4100 DVD just beeps...
could it be a ground or is the ant. plugged in
Aug 20, 2009 | Pioneer AVH-P4100DVD Car DVD Player
Computer will not come on
beeping 4 times in a row is a hardware problem
repalc motherboard if video is intergrated
Mar 26, 2009 | IBM ThinkPad T30 2366 Notebook
Dell precision 3100 machine will not boot up
If your computer is beeping at you, 9 times out of 10 its going to be an issue with the memory or video. (more often the memory) Try re-seating both. If your still hearing the beep fest, below is a list of the most common beeps and what they refer to. This will help you to find out what needs replacing.
Long beep followed by 3 sequential short beeps. This issue is linked to your Graphic card configurations
Short beep followed by three sequential long beeps You are facing a system memory problem
Beep- PAUSE- Beep- PAUSE- Two sequential beeps This error is linked to your CPU
Three beeps-PAUSE-Three beeps-PAUSE-Four beeps You have an issue with the video memory
Three beeps-PAUSE-Four beeps-PAUSE-Beep This is linked to an error with your Graphic Card
Four beeps-PAUSE-Three beeps-PAUSE-Beep You have a system memory problem
Five short beeps You are facing a problem with your CPU
Long constant beeps It’s a system memory problem
Short constant and high-pitched beeps The temperature of your CPU is too high
Jan 05, 2009 | Dell Dimension 3100 PC Desktop
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Aug 27, 2008 | HP Compaq dc5100 PC Desktop
PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Dec 15, 2007 | HP Compaq dc5100 PC Desktop
Computers & Internet Logo
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
