Question about Toshiba 57H84 57" Rear Projection HDTV-Ready Television
Toshiba 57H84: problem description below...
My TV is three years old, Toshiba 57H84. The TV started just abruptly shutting off occasionally. The power light would blink, and we would have to unplug the TV to get it to come back on. Then, when we would plug it back in, the screen would be a bright blue for about two seconds, then the TV would cut off again.
I got online, being a technical-type, and looked for a solution. I found some ideas, and took the front of the TV off. To make a long story short, I adjusted the tube voltages manually, and the TV worked for a couple of days. Now, the blue tube is bright even when turned completely down. I turn it up, and something started popping and flashing inside right before it turned off again. I figured the tube was going out. But after seeing that the other tubes will shut off the TV when turned up, and after giving it some electrical thought, I realized that the tubes are probably fine. (except for whichever one is leaving the inch-wide yellow "hole" in the middle of the screen.) The box-type thing that all the tubes connect to with the "sparkplug wire" looking thick wire is probably bad, or the thing that THAT box is connected to. I think that if there is a voltage regulator of some sort, that it is malfunctioning.
OK, realizing that this is all coming from a non-TV repairman; what do you think is my problem? I can be reached at csapamplin@yahoo.com, or at 843-270-0086. Thanks in advance.
In His service,
Wes
  • William Rayburn
    William Rayburn May 11, 2010
    At this point it could be damaged even further by turning up the G2 on the focus block, including but not limited too damaging the focus block itself... What I believe you may have had at first is an overvoltage shutdown - usually when a regulator, diode, resistor or any cobination thereof begin to fail and load the circuit too heavy causing shutdown..
    You might try replacing Q306 Part# 23085588 A Ta7590pg and put in a new focus block. Check F840 200ma Pico Fuse, Toshiba # 23144704, And Q840 Mip280 Standy Power Supply Smps Controller, Toshiba # 23906133... And let me know if it will power on following that...
    Bill
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: toshiba 65hdx82
The STKs are common and if you have an experienced electronics tech around they can replace them for much less money but the tech must have advanced soldering and IC exchange experience.
The STK ics, two of them, can be purchased on line for around $20 to $40 each.
http://www.partstore.com/GetModel.aspx?MfgName=Toshiba&BrandName=Toshiba&ModelNu...
Partstore has two models available - one for around $40 and another for around $55.
The part number is STK392-110 and if you google you can find them for as little as $6/each but I don't recommend the cheap ones as they are not reliable.
It takes a good tech around 3 or 3 hours to take the old ones out and solder in the new ones. Also, it is likely one or two resistors are burnt and will need replacing as well.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 18, 2007
Slinteriors
  • 8617 Answers
SOURCE: Toshiba 61H70 Weird Convergence Issue?
They may have gotten some cheap convergence ICs, thats a real possibility. I would recommend switching the two origional STK392-110 with some STK392-150 they will run alot cooler and last alot longer. Just use a good coating of heat sink compound on the back of the ICs. I will post a link where you can get top quality Convergence ICs and they provide free instalation instructions with pictures so you can do the job yourself in under an hour and save quite a bit of money. Heres the link.
http://servicemanuals.vstore.ca/
Posted on May 22, 2008
eagle338
  • 4889 Answers
SOURCE: Thosiba TP61H95, when I power
Since you have sound if its not HV then its gotta be the deflection ICs and/or the HOT(horizontal output transistor). Its not gonna be very hard provided you know how to use a multimeter and know how to solder. Let me know if you think you can do it yourself so that I can tell where the ICs and the transistor are located so that you can replace them , along with the resistors that are faulty(we can test using the ohm-meter feature of the multimeter and the original value of resistance can be calculated from the color codes on them).
Posted on Jul 10, 2011
No picture, the little red light on the power button just flashes. I'm not sure if this is something relatively simple, like a bulb replacement, or if it's shot and I need to buy a new tv. Help! Toshiba...
Your power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Hope this help in solving the problem.....
Dec 31, 2010 | Toshiba 57H84 57" Rear Projection...
My five year old Toshiba 57H84 rear projection TV has a pink tinted screen when you first turn it on, then after it warms up, the colors are all fine but then the picture has evenly spaced blue tinted...
Hi,Yes your problem sounds like the DMD board.This is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Here's a video that will help you find where the DMd chip is located : http://www.youtube.com/watch?v=0jr_9A5Xd2Q Have a blessed one!
Apr 30, 2010 | Toshiba 57H84 57" Rear Projection...
The TV started turning itself off occasionally a
Most likley what it could be is an interferance in the TV. Modern TV's have a feature that will shut itself off when it is not receving a picture. For instance, after so many minutes of "snow" it will shut off.sometimes this can make the TV think there is no signal at shut itself off.Anyway, I suspect its an interferance issue. Perhaps moving the TV further from the source of the interferance might help.
Sep 17, 2009 | Televison & Video
Flashing Power light
Ur power board ic inverter is dead.
U need a new board.
Aug 19, 2009 | Toshiba 57H84 57" Rear Projection...
Model 55X70 Toshiba Projection tv
dont know about warranties but horizontal lines means your horizontal frequency which runs about everything has drifted off sync and if too high or low it will activate shut down circuits in high voltage and power suppy, even causing HOT transistor to short. good luck and call a tech.
Sep 01, 2007 | Toshiba 55HX70 55" Rear Projection...
Will not power on.
Your blinking red power light is indicating a problem with the set. It has read an error code. With my experiance with Toshiba I found that a dead set or blinking red light can be a whole bunch of diffent conditions. One common problem though, and I would check this first, is your convergence circut. It is very common that the the convergence IC's themselves and or some resisters in that circut have failed. Also check all the pico fuses on the power and sub power supply's. Hope this helps and good luck
Jul 21, 2007 | Toshiba 57H84 57" Rear Projection...
Toshiba 57H84 57" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
