Question about Powerware 9120 UPS System
Doesn't start and shows "Failure..." on display
After taking the UPS to the nearest Technical Support aviable, they changed the batteries and returned the equipment with the new batteries uncharged. After charging the batteries as supposed (and widthout unplugging the UPS from the socket), I try to turn on the UPS but it doesn't provides power. Also, displays "Failure..." on the display. Any suggestions? Is there any start-up sequence that i should know about? Thanks a lot !!
    Brigadier General:
  • 6,966 Answers
Hi, a couple of things you can do but may I first suggest you bring it back to the Technical Support people who replaced the battery and voice your issue. The new battery might have to be replaced (don't be surprised) and you may have certain warranty claims that may be void if you try opening the UPS yourself. If for some reason you want to do it yourself, then you have to open the UPS and check the circuitry including the new battery. You need to be familiar with the use of a multitester (VOM), working with HOT circuits and general electronics. You have to start with any fuses, circuit breakers, relay, SCRs, transistors, etc. If you are not that comfortable doing so, guess were back to the first paragraph. Hope this be of some help. Good luck
Posted on Apr 26, 2007
I have Numeric 1000 Hp Digital Ups .now i have a problem With it .Always it is giving short beep sound, and displays shows "Warning 22".Battery back up is also not giving. During power failure instrument...
Replace the batteries in the UPS - that's your problem. Everything should work after that :-D
If you need UPS, Surge, or Power Related help don't hesitate to contact me!
Daniel • daniel@psihq.com • Power & Systems Innovations • 800.260.2259 • www.psihq.com
Aug 24, 2013 | QVS NetStar (UPS650A) UPS System
I have a GS-1500U geeksquad battery back up, when its plugged in, the power light blinks. when I push the display button, it shows the battery level as fine, but after 3 seconds, the UPS shuts off
Hi and welcome to fixya
the symptoms that you are telling are of battery ! the problem is with the battery change your battery or take to an expert then your problum will be surly solved
Dec 06, 2012 | Computers & Internet
DURING STARTUP MY COMPUTER IS SHOWING FAILURE OF CMOS BATTERY AND IT GET S/W OFF AUTOMETICALLY. I ALREADY CHANGED THE BATTERY. WHEN I SWITCH ON UPS THE SYSTEM AUTOMETICALLY START BOOTING I NEED NOT TO...
When the system is running you need to set the date and time. or set it in the BIOS. Access to the bios varies from board to board but is usually "f2", "del" or sometimes "f10" the relevant button is displayed on the splash screen. The reason it auto starts can be cahnged in the BIOS as well.
Feb 12, 2012 | Intel Computers & Internet
Ups 6 KVA power ware 9120 indicate the problem of (charger failure) ,please provide circiut diagrame of relevant UPS or help to point out the particulare section of circuit with component numbers in...
Here is the 9120 documentation page but Eaton generally does not publish circuit diagrams for smaller UPSs like this. Some people may be technical enough to take a UPS apart but most aren't and it can be very dangerous. I suggest you contact the Eaton hardware support forum.
Jul 15, 2011 | Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
Sir, My PC is starting problem, 1.Starting UPS - ON the system starts automatically without swith ON. 2.After Starting the keyboard & Mouse get stuck 3.after Restart the the keyboard & Mouse...
The UPS may not be sufficiently stable on power-on to run a PC immediately.
Try going into the BIOS setup after the restart and look for the option that has the computer "Start up automatically after power failure." Turn this off. That will take care of problem 1.
If this also takes care of problem 2, you may want to check whether the UPS has a problem. Start by plugging a couple of lamps with 100 Watt bulbs into the UPS outlets instead of the computer. Turn it on - the lamps should behave normally, not flicker or change brightness. With the lamps and UPS still on, unplug the UPS. The lamps should stay on with little or no change, and the battery warning light should not come on right away. If the UPS fails this test, its battery may need to be replaced or it has a regulator problem.
Apr 08, 2011 | Intel DG965RY Motherboard
How to reprogram my Woods N1506 Timer
Manual and image for Woods/Noma N1506 outdoor timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#N1506
SETTING NOMA N1506 TIMER
Plug in timer - The letter C will Flash
TO SET CURRENT TIME:
Press Time Button - It will advance to 1 a.m.
Continue pressing until right time to the nearest hour.
Timer is only set to nearest hour.
(NOTE: A dot at the bottom right corner of the display indicates P.M. hours).
TO SET ON AND OFF TIMES FOR TIMER OPERATIONS:
Press Mode button - Letter P will flash inviting you to set the program
Press Time button repeatedly until required staring time appears in the window. (starting time is now displayed).
Press Mode button again - the letter E now flashes.
Press time button repeatedly until required ending time appears in the window. (Note: a dot at the bottom right corner of the display indicates P.M.hours).
Press Mode button and the display returns to the current time.
Programming is now complete. You may now plug in whatever needs to be turned on. The device will turn on and off automatically every day at the times you have just selected.
TO REVIEW THE PROGRAM
Press time button - Displays successively, for 1-2 seconds each: P, starting hour and E, ending hour. Then returns to show the current time..
TO CHANGE YOUR PROGRAM
Unplug the timer, which will discontinue the current program. After 10 seconds, plug it in again and proceed to set current time. Then continue with the programming steps as above.
FOR MANUAL OVERRIDE
Pressing the Mode button at any time will turn on the devices plugged into the timer. The display will indicate the letter O. The devices will remain on until the ending time of the daily program. To return the timer to the automatic mode prior to that hour, press the Mode button again. The display will return to show the current time.
AFTER A POWER INTERRUPTION/FAILURE
The timer will return to displaying a flashing C and the devices plugged into it will be off.
Dec 13, 2010 | Woods Outdoor Lighting Timer
How to program my Woods N1506
FOR MANUAL OVERRIDE
Dec 13, 2010 | Woods Hardware & Accessories
Microtek dual ups battery
yeah, you need to replace the battery with the same kind of battery installed in it or you may consult with the technical support of microtek nearest you.
Sep 12, 2009 | Computers & Internet
Powerware 9120 UPS System Logo
123 people viewed this question
Top Powerware Computers & Internet Experts
Marvin
Marvin
geekyshrink
geekyshrink
Level 1 Expert
Joe Lamb
Joe Lamb
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
