Question about Grohe 24'' Relexa Shower Bar with Swivel Hand Shower Holder - 28666/Choose
Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
The acrylic shower head holder on the slider bar of my new (less than one year old!) 24" Grohe Relaxa Shower bar broke so now I can't hang up the shower head on the bar and must hold it in my hand to take a shower. It was made of acrylic instead of metal and I could see stress fractures in it after only one month and have been looking for a replacement since then. Now that it has completely broken I need a fix immediately. Thanks!!
  • 2 more comments
  • amsnare
    amsnare Jan 11, 2012
    The acrylic is OK for light and gentle use, IMO.. As I recall, we have NOT had any problem, we are on the second one, which is several years old), BUT, that does not mean that the acrylic is not junk.... IMO, what does need to be improved is the design.
  • Dee Kita Mar 03, 2013
    The same thing happened to my Relaxa. I called Grohe and they are sending me a new part free of charge, In the meantime, I bought some Epoxy Putty for about $5 from our local Home store (Lowes) and stuck it back on. it back on fo
    The Epoxy putty is like working with clay. Just use glove when kneading the putty.
  • Anonymous Mar 24, 2014
    Put new battery's in remote controller just won't work
    Problem Solver:
  • 14 Answers
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
Posted on Dec 29, 2008
Soap holder came of the bar/holder
go to grohe web site put in modle number download parts pic and call grohe for replacement
Feb 10, 2013 | Grohe 24'' Relexa Shower Bar with Swivel...
Install grohe shower bar
After removing from wall by unscrewing long screws after removing cap, look inside and you will see a white translucent plastic with 4 wide, flat hooked ends. Take a small screwdriver and gently push each 4 plastic hooked ends and it will come unhooked from the small groove. Push it far enough that the bar will slide out. No need to remove the plastic hooked piece. To replace, push in each hooked end and push in from the opposite end to reinstall.
Oct 14, 2012 | Grohe 24'' Relexa Shower Bar with Swivel...
I have a Grohe 28917 Relexa Ultra Five 24 Inch Shower Set, and it is not mounted well to the wall so that it is loose. Also, the slide bar also goes up and down too easily. Can you help me?
the 2 mountings have caps on them, pop them off to get to the screws. If the plugs in the wall are busted you can use spring toggle bolts and it will give you a very strong mounting. Just don't over tighten to the point that you damage the wall.
The slide bar may need rubber cleaned since soap scum will make it slippery. Do this while you have the bar off the wall.
Jun 05, 2010 | Grohe 28917 Relexa Hand Held Shower -...
We installed a Grohe Relaxa Plus 10 years ago.
Likely a blockage in the line. Corrosion or other damaged parts. Try cleaning the filter screen first. Check for normal water flow without the shower unit attached to the spout. If OK, then the unit is the issue.
Aug 24, 2017 | Grohe 24'' Relexa Shower Bar with Swivel...
Exact same problem.
if you call grohe they will probably send you a free one if it hasn't been over their warrenty period
Aug 01, 2009 | Grohe 24'' Relexa Shower Bar with Swivel...
Leak where Grohe shower head attached to the threaded pipe
Hello, Many shower heads have similar problems. (Very frustrating as you now know) The problem is the threads at the end of the (cheap plastic) shower neck are not flat. They are tapered (has an edge) - so it does not seat flush with the base of the shower head. Actually cuts around the rubber washer causing a leak.
What to do about it?
File the end of the neck some to create a flat surface. However, go slow. Be sure you can still screw on the shower head. Add a flat rubber washer in the shower head and plumbers tape on neck threads too.
Or Purchase a new shower neck that has a better design. The neck should unscrew from the front. Check and make sure you have an access behind the shower just in case you need to access the plumbing.
I replace the shower neck myself if there is an access.
Rob
Jan 17, 2009 | Grohe 28.275.AV0 Relexa Plus Top 4 Spray...
Grohe 24'' Relexa Shower Bar with Swivel Hand Shower Holder - 28666/Choose Logo
1,336 people viewed this question
Top Grohe Home Experts
Mike
Oloyede Monsuru
Are you a Grohe Home Expert? Answer questions, earn points and help others
