Question about Philips Audio Players & Recorders
No recording occurs when in record mode
Philips classic 388 mini recorder is not recording voice. red light is on and it appears to be functioning but when played back no recording has occured.
  • Anonymous Mar 26, 2014
    How do I unlock the DSS 9360 recorder? The machine doesn't record or play items I have already recorded.
  • 145 Answers
If the red light does not blink while you speak, then the internal microphone is bad or a wire has broken off. If it is blinking, the record playback changeover switch is bad. This part is difficult to replace. Repair cost should be around $75.
Posted on Jan 01, 2009
Where do I download a driver for Philips Speechmike Classic 6264 that can be used with Windows 7?
Unfortunately I cannot find any references to driver installation for versions of Windows beyond Windows XP. The possibly means the hardware is not natively compatible with Windows 7. You can try installing the Windows XP driver using either compatability mode or if push comes to shove you can use the XPMode virtual machine to run the device in a true Windows XP environment with Windows 7 Virtual PC. I would contact Philips customer support for more information.
Feb 26, 2015 | Philips SpeechMike Classic 6264 Handheld...
How do I turn it on
There is two red lights, one means you are recording and the other is low batt. which one you are talking about?
If it is Low batt light,there is dirty or bad contacts at battery compartemt. clean it with alcohol and a piece of cotton.
The other light is you are recording.
also you are in VOX mode, disconect.
VOX means voice operated without hands.
Sep 22, 2014 | RCA RP5010 Digital Voice Recorder
How do you record on a Lanier p-164
Turn the main power button "on" first, it is located on the skinny side of the recorder opposite of the function knob. Press eject to open the cassette door and install a microcassette tape, with the tape facing the function knob side. close the cassette door and that should load the tape and allow the tape head and pinch roller to move into place for recording or playback. pull the function knob down or push it up to record. If you go into record a red light should come "on" the top, to indicate good batteries and the record function is initiated. After recording pull the function knob all the way down to rewind the recording,when you release the button the unit goes into the play mode automatically. Make sure that the button that reads (off--- vor/fplay) is in the off position.
Jun 06, 2014 | Audio Players & Recorders
Phillips Pocket Memo 381 The button you press in when recording will not press in! Any ideas tThe machine plays back tapes OK
You cannot push it in without a recordable tape in the unit. The mini cassette tapes have a removable erase prevention tab on each side in the front. If removed, you cannot push record. Try another tape. Otherwise the recorder needs repair.
Aug 16, 2011 | Philips Pocket Memo 381 Handheld Cassette...
How do I delete old recordings off my RCS digital voice recorder?
Press Menu,with the down arrow,scroll down to "folder",press red button. A list of folders will appear.Scroll down to the folder you want, press red button.Now scroll to "file" , push red button.A list of files will appear pick the file you want to delete, push red button.A list will appear with "select" on top, scroll down till you get to "delete" , push red button. A message will ask you are you sure. Use the arrows again to go to "yes" then push the red button again to finalize your delete.
Nov 27, 2010 | Zoom H2 Digital Voice Recorder
How do you get the voice recorder to work on the go gear vibe? Do I need a little microphone to record messages?
From the manual...
This is how you can record audio/voices with the built-in microphone (see section Overview for location of built-in microphone):
1 From the main menu, select to enter recordings mode.
2 Select [Start voice recording].
• Press to toggle between pause and record.
3 Press to stop.
»» The screen prompts you to save the recording.
4 Press / to select [Yes] / [No].
5 Press to save the recording.
»» Recordings are saved on the player.
(Filename format: VOICEXXX.MP3, where XXX is the recording number that is generated automatically.)
Tip
•• You can find your recordings under [Recordings library] > [Voice].
Jan 12, 2010 | Philips Audio Players & Recorders
LFH 720 - Does it record?
This machine is a playback-only model. You will need a hand-held recorder using Philips mini-cassettes.
Oct 13, 2009 | Philips LFH-720
Go gear will not operate in recording mode
The Go Gear SA52XX series is only capable of recording FM in Europe - the US versions, even though they have the same manual, will not allow FM Recording. I haven't heard that won't do voice recordings, but it doesn't surprise me - update the firmware - the directions are on Philips website. If it still won't record voice recordings, get a different mp3 player, because this is not the one.
The Philips SA6045, SA5125, and a few others will do FM and voice recordings. Ironically, the newer Philips GoGear's will not.
-Tha Mp3 Doctor
Mar 08, 2009 | Philips GoGear SA5285/37 Digital Media...
303 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
