Question about JVC AV-48WP30 48" Rear Projection Television
I keep getting a black retangle box on the screen and can't
Rember how to get it off
Its your close caption on the tv or the cable box
Posted on Jan 02, 2009
Black box on screen
That sounds like a text box. Press the cc button and keep pressing it. You will see different closed captions options on your screen each time you press the button. Finally when it says cc off stop pressing the button and you should no longer get the black box. If you have a cable box connected you may also have to disable the captioning on it.
Feb 12, 2010 | Sharp LC-19SB14U 19 in. LCD TV
A black squire in in the middle of my picture
Go into setup and turn off CLOSED CAPTIONING
Dec 07, 2009 | Sony Televison & Video
Convergence
sounds like closed captions is turned on go in menu and turn it off or if you have cc button on remote you can turn it off with it.
Aug 12, 2009 | Toshiba 42H81 42" Rear Projection...
Big black rectangle JVC tv
turn off your closed caption
Mar 20, 2009 | JVC AV-36260 TV
HOOKING UP MY HP DESKJET D1560 TO MY NEW LAPTOP.
The gray cable is most likely is th USB cable, take alook at the 2 end. one end is in A configuration (retangle) and the other end is B configuration (square).
the B end is connected to the rear of the printer. the A is connected to the laptop A plug (same retangle plug).
Jan 13, 2009 | HP Officejet 5610 All-In-One InkJet...
Need to replace heater core in 1988 Ford Crown
i too replaced the heater core on my 1988 ford cv. the important point to rember is not to get overwhelmed. i ended up removing the whole dash, but not the stearingwheel. lable everything you remove....best to keep all parts seperated. mine looked like a nascar when i finaly got to the black plastic box where the core lives. i had to also remove some of the heating duct. once you open the box up, youll see the core. just sits in there. remove in and out hoses. very simple, but alot of work, thats why you must keep track of everything you remove. your engine coolant may be low, so add more when compleated. its been about 4 years now since i replaced mine.....i dont rember if the black box was rivited togeather or screwed togeather. if rivited, get a dremel tool with a grinder wheel, this will remove the rivites in good time. but the duct work was stapled togeather, i used 1/4 inch sheet metal screws to hook back up, works just fine.
Dec 06, 2008 | 1988 Ford Crown Victoria
Retangle black box
Ve al menu de la tv y checa si esta activada la funcion TEXT si es asi desactivala suerte.
Apr 09, 2008 | Daewoo DTQ-25S3FC 25" TV
Black Box?
my tv was working fine. somebody hit the menu button on the tv or the remote and i get the black box appearing in the middle of the screen. and also the pip is staying on my tv it keeps showing "a snowy picture of pip sjpwomg channels 2 through 18 i cannot figure out how to get this off of my screen.
Feb 08, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Green or black and white retangle checks no piture
. Check for proper seating of connector DB between the DM PCB and Signal PCB. 2. Suspect the FMT PCB part # 930B924002
Jul 26, 2007 | Mitsubishi WD-52525 52" Rear Projection...
JVC AV-48WP30 48" Rear Projection Television Logo
21 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
