Question about Linksys WRT160N Wireless Router
I just hooked up my router.. it says the ethernet is not working
Someone said i need a code to put in? where do i find this?? i have gone thru steps 1-4 a million times and still says ethernet not working ...
  • gregpratt62 May 11, 2010
    how do i change from secure to unsecured
  • Linksys Master
  • 4,338 Answers
Router setup
You do not have to use the cd. Go to the control panel and un-install the program that the cd installed. then:
Shutdown your PC. Unplug the power from the router and the cable modem.
Wait 30 sec. then plug in the power to the cable modem, wait 30 sec. then plug the power to the router. Wait till you have "Internet" light then restart your PC. The PC should pick up an IP address and you should be able to get on-line. This is if you have a cable service provider. If you have DSL, the router needs to be configured with PPOe.
If you want to clear the code (key and make unsecure):
Linksys reset
The easiest method of resetting your Linksys router’s password is to reset your router back to the default factory settings. This is done by simply holding down the reset button located on the back of the unit for at least 30 seconds. Once the router has been reset, it must be reconfigured. Using your web browser go to URL address http://192.168.1.1. You will then be prompted to login to your router. A log-in screen asking for the password will automatically appear. At this time enter the default password “admin”, in lower case letters into the password field. The username field may be left blank at this time. (Note: both the default username and default password are set to “admin” on some of the newer Linksys router models).
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 01, 2009
I want to hook up netflix to my computer ,thru a wireless router.My computer is running of a land line .Do I need a two way spliter to run my Ethernet cable to both the computer and router,to run properly?...
Does your computer have a Wireless Adapter? This would allow you to pick up wireless transmissions from your wireless router.
If you don't have a Wireless Adapter, you'll need to buy one, or, you can connect your computer to the router with an Ethernet cable and then connect your Router to the socket in the wall.
Either way, as long as you have internet access on your computer, you will be able to hook up Netflix.
May 04, 2012 | Nintendo Wii Console
WHERE DO I FIND THE WPA CODE FOR BELKIN N WIRELESS ROUTER. I DONT HAVE THE MANUAL AND IM TRYING TO CONNECT TO MY PS3
goto Google and put in name (Belkin N Wireless Router) and model number (_________), manual. Push enter. Down load the manual; it is a PDF file. WPA is a security code made up of hexadecimal numbers. zero thru nine and A thru F. 0123456789ABCDEF SIXTEEN SYMBOLS O-15
Nov 27, 2010 | Computers & Internet
I NEED TO ENTER MY CODE FOR NEW HOOK-UP WHERE?
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Jan 07, 2010 | Innocom Technology Computers & Internet
My wireless on my f5d7230-4 won't work but when i hook up a ethernet cable from the wireless router to my laptop the internet works but my wireless will not work
With the ethernet cable , it is working, Ok the router wired part is working but the wireless part is not working.
on your laptop , does it say connected to your wireless network ?
If it is not then try to connect to the wireless network .
Make sure that you have the correct wireless settings of the router .
Click Here for step by step solutions
Nov 12, 2009 | Belkin (F5D7230-4) Router (587009)
Pc not finding network ...internet working (going thru router) but not finding network. cant get to login screen for router to adjust any settings. Ps3 cant communicate with wireless router either....
I think you will need to check the wireless settings of the router.
try changing the wireless channel on the router.
make sure that the SSID broadcast is enabled.
for this you will need to access the router set up.
Nov 03, 2009 | NetGear WGR614 Wireless Router
I have a NetGear WGR614 Wireless Router and internet through Mediacom with a Motorola SB5100 SURFboard cable modem. I have gone thru the setup process three times now, and the internet has hooked up twice...
Follow the below steps to reconfigure the router:
Connections:
1. Connect a Ethernet cable from the modem to the WAN port of the router(isolated port).
2. Connect the computer to the router using any one of the 4 available ports. Please make sure that THERE IS NO DIRECT CONNECTION BETWEEN THE MODEM AND THE COMPUTERS (either using Ethernet cable or USB cable).
3. Power off the modem and the router after making the connections.
4. Power on the modem and wait for the lights, then power on the router.
RECONFIGURE:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the username and password is case sensitive).
4. Click on 'Basic settings' from the left menu and select 'Use Computers MAC Address' from 'router MAC Address' section.
5. Click Apply.
6. Once it updates the settings then power off the modem and the router. Power on the modem and wait for the lights, then power on the router.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Oct 08, 2009 | NetGear WGR614 Wireless Router
Trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Ethernet won't reconise modem for xbox live
Once you have everything hooked up:
Ethernet cord going from modem into wireless router in port labelend internet or wan, and an ethernet cord going from the router to the xbox you should try these steps:
Unplug the power cord on the modem and plug it back in- once all the lights come back on
Unplug power cord on router and plug it back in-
Hope this helps.
Apr 07, 2009 | Linksys Wireless-G WRT54GS Router...
I was given a linksys wireless-g model wrk54g router but it didn't come with an installation disk. I have a Thomson speedtouch modem ST530 V6. Right now I am hooked up thru ethernet and getting internet...
was the router used by previous users? or did you buy it? if it was used then it was probably configured for different ISP. You don't need any CD. Just connect to the router via your browser (probably http://192.168.1.1) and adjust settings in WAN section.
Mar 15, 2009 | Linksys Wireless-G Broadband Router
Linksys WRT160N Wireless Router  Logo
62 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
