Question about Microsoft Windows 98 for PC
AVG 7 detecdted Virus Hurri on partition table. How do I remove ?
AVG 7.5 Detected Virus Hurri on my Partition table. M running old machine with Windows WIN XP with Intel Celeron 2400Mhz.40GB. RPM 6600. How do I remove it?
  • 51 Answers
You will need to fix the master boot record with the Windows XP Recovery Console. To do this, you will need a Windows XP install CD.
Here are the steps to use the recovery console:
To run the Recovery Console from the Windows XP startup disks or the Windows XP CD-ROM, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
  4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the command prompt, type the appropriate commands to diagnose and repair your Windows XP installation.
In this instance, the correct commands are:
The type exit after finishing then remove the Original OS CD.
The machine will reboot properly.
This will fix your boot sector
And All should be well
Posted on Dec 28, 2008
How To Recover Lost, Deleted Or Missing Files And Partitions
1. If TestDisk is not yet installed, it can be downloaded from <a href="">TestDisk Download</a>. Extract the files from the archive including the sub-directories.<br /><br />2. To recover a lost partition or repair the filesystem from a hard disk, USB key, Smart Card, etc., you need enough rights to access a physical device. <ul> <li> <img src="dos.png" /> Under DOS, run TestDisk.exe </li> <li> <img src="win.png" /> Under Windows, start TestDisk (ie testdisk-6.9/win/testdisk_win.exe) from an account in the Administrator group. Under Vista, right-click testdisk_win.exe and then "Run as administrator" to launch TestDisk. </li> <li> <img src="linux.png" /> Under Unix/Linux/BSD, you need to be root to run TestDisk (ie. sudo testdisk-6.9/linux/testdisk_static) </li> <li> <img src="macosx.png" /> Under MacOSX, if you are not root, TestDisk (ie testdisk-6.9/darwin/TestDisk) will restart itself using sudo after confirmation on your part. </li> <li> <img src="os2.png" /> Under OS/2, TestDisk doesn't handle a physical device, only a disk image. Sorry. </li></ul> 3. To recover partition from a media image or repair a filesystem image, run: <br /> <ul> <li> testdisk image.dd to create a raw disk image </li> <li> testdisk image.E01 to recover files from an Encase EWF image </li> <li> testdisk 'image.???' if the Encase image is split into several files. </li></ul> 4. <img src="linux.png" /> <img src="macosx.png" /> To repair a filesystem not listed by TestDisk, run testdisk device, i.e. <br /> <ul> <li> testdisk /dev/mapper/truecrypt0 or testdisk /dev/loop0 to repair the NTFS or FAT32 boot sector files from a TrueCrypt partition. The same method works with filesystem encrypted with cryptsetup/dm-crypt/LUKS. </li> <li> testdisk /dev/md0 to repair a filesystem on top of a Linux RAID device. </li></ul>5. Choose Create to instruct Testdisk to create a <a href="">log file</a> containing technical information and messages, unless you have a reason to append data to the <a href="">log</a> or you execute TestDisk from read only media and must create the <a href="">log</a> elsewhere.<br /><br />6. Choose None if you do not want messages and details of the process to be written into a <a href="">log file</a> (useful if for example Testdisk was started from a read-only location).<br /><br />7. Press Enter to proceed.<br /><br />8. All hard drives should be detected and listed with the correct size by TestDisk:<br /><img src="moz-screenshot.png" /><img src="pctech1.gif" /><br /> <ul> <li> Use up/down arrow keys to select your hard drive with the lost partition/s. </li> <li> Press Enter to Proceed. </li></ul> <img src="macosx.png" /> If available, use raw device /dev/rdisk* instead of /dev/disk* for faster data transfer. <br /><br />9. TestDisk displays the partition table types: <span><img src="Partition_table_type.gif" /></span> <ul> <li> Select the partition table type - usually the default value is the correct one as TestDisk auto-detects the partition table type. </li> <li> Press Enter to Proceed. </li></ul><br />10. TestDisk displays the menus:<br /> <span><img src="Menus.gif" /></span> <ul> <li> Use the default menu "Analyse" to check your current partition structure and search for lost partitions. </li> <li> Confirm at Analyse with Enter to proceed. </li></ul> 11. Now, your current partition structure is listed. Examine your current partition structure for missing partitions and errors: <br /> <span><img src="Analyse.gif" /></span> <ul> <li>The first partition is listed twice which points to a corrupted partition or an invalid partition table entry.</li> <li>Invalid NTFS boot points to a faulty NTFS boot sector, so it's a corrupted filesystem.</li> <li>Only one logical partition (label Partition 2) is available in the extended partition. One logical partition is missing.</li></ul>12. Confirm at <i><b>Quick Search</b></i> to proceed. <span><img src="Vista_check.gif" /></span> <ul> <li> Confirm according to your OS and created partitions to proceed. </li></ul>13. During the <i><b>Quick Search</b></i>, TestDisk has found two partitions including the missing logical partition labeled <i><b>Partition 3</b></i>. <a href=""><img src="First_results.gif" /></a> <ul> <li> Highlight this partition and press <i><b>p</b></i> to list your files (to go back to the previous display, press q to Quit).</li> <li>If all directories and data are correctly listed, Press Enter to proceed. </li></ul> 14. Save the partition table or search for more partitions?<br /> <span><img src="Search_menu.gif" /></span> <ul> <li> <i><b>When all partitions are available</b></i> and data correctly listed, you should go to the menu <b>Write</b> to save the partition structure. The menu Extd Part gives you the opportunity to decide if the extended partition will use all available disk space or only the required (minimal) space. </li> <li> <i><b>If you are still missing a partition</b></i>, highlight the menu <i><b>Deeper Search</b></i> (if not done automatically already) and press Enter to proceed. </li></ul>
on Feb 20, 2011 | Computers & Internet
Want to restore previous "Windows.old"
you deleted the partition C that the windows old folder was on, you may try a windows restore, however....the files can be retrieved they are still there, you need YODOT HARD DRIVE RECOVERY PROGRAM to scour the old partition that was there previously and restore the folders that you wish to recover onto a new area of the new partition. PLEASE NOTE THE MORE YOU FORMAT OR CREATE AND DELETE NEW PARTITIONS ON YOUR OWN THE MORE THE RECOVERY SOFTWARE WILL FIND IT HARD TO RETRIEVE OLD FILES, SO BEST NOT TO TRY ANY MORE ATTEMPTS ON TRYING TO RECOVER THE LOST ARCHIVE YOURSELF LET YODOT RECOVERY DO IT FOR YOU FIRST. CHEERS
How to Recover Deleted Files using File Recovery Software
May 02, 2017 | Computers & Internet
Lost NTFS partition on my WD1600BEVT, how do you restore so I can use again?
Depends on what you did to "lose" the partition-table.
Download the free 'PTEDIT.ZIP' file -- it is a "partition-table editor".
UNZIP it on a different computer, and extract the 'PTEDIT.EXE' program.
Run PTEDIT on your computer, and update the partition-table.
Jul 14, 2011 | Western Digital WD1600BEVT 160 GB SATA II...
Doesn't show any files and folders when drive opened
Congrats, You got a nice virus. Its better you backup your drivers and data from ur root partition format it. reinstall your operating system and install avg 8.5 before browsing any of the other partition. I can surely tell u your task manager, registry editor or show hide folder won't be working. There is no permanent solution to this other than format. But beware don't browse other partition before installing avg 8.5. Your earlier installed antivir has given its way to virus its of no use. You won't be able to install antivirus or visit any malware removal virus site. welcome back.
Jun 14, 2009 | Western Digital Passport WDXML800UE...
How do i remove a virus from my computer?
You need to get a good anti virus program and install it on your computer.
it will scan initially, which will check the boot partition and main windows files.
then once the program is installed run a full scan on your computer.
I use Panda Anti Virus,
you can get a free version of AVG anti virus at the link below.
You will find if you think you have one virus, you may have a huge amount of spyware or virus in your computer. Don't wait, get a good antivirus now.
Jun 10, 2009 | Microsoft Windows Vista Ultimate Edition
Hurri virus
might want to reformat the hd and reboot it using your reboot disk
that virus might i been on a program up allowed on your computer or you where hacked
Sep 25, 2008 | Microsoft Windows 98 for PC
Reinstalling Problem
Once you disrupt the partition table by introducing a new linux partition the recovery program is unable to identify the recovery partition. The only success I have had is to boot from a program called partition table doctor and using it to rebuild the master boot record and partition table structure, you can download it here: partition table doctor
of course there is no guarantee it will cure your problem but it is a very powerful tool I have used with some success. Please rate my assistance as we depend on your rating to carry on giving FREE advice.
Mar 29, 2008 | Compaq Presario Notebook
Hurri Virus
Try this free anti virus trial from E Trust it should fix your problem
Nov 20, 2007 | Microsoft Windows 98 for PC
Microsoft Windows 98 for PC Logo
351 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
