Question about DEI Python 1400XP Remote Start/Keyless Entry System
While driving the engine dies
I have a 1997 Pontiac Grand AM with a Python alarm. Intermittently, the car dies while driving. It has started up normally immediately after the the engine dies.
When the engine dies, all lights on the dash go out and I hear the door locks cycle (unlock to lock) several times. This occurred twice yesterday within about 15 minutes. I had been driving about 10 minutes in light city traffic. This problem has existed for several months.
I have been trying to figure what could cause these symptoms and am considering the alarm.
Any ideas??
  • Anonymous Jan 11, 2009
    My python remote start was just installed in my Colorado and it isn't working properly. A few times it started right, but a few times it didn't. And when it didn't, I was unable to even start the vehicle manually with the key!
    Now it didn't start again today, and I just went outside to try & start it manually, and it seems like the battery is dead!! I'm really pissed & I am taking it back to the place I had it installed to be repaired or removed before it causes damage to my new truck!!
  • carsrus629 Jan 12, 2009
    1995 grand prix i hear a click but the remote wont start the car, at times it does the same thing with the key when i try to start the car ?????
If engine dies while driving and locks trigger then program your remote not to lock/unlock when turning on/off ignition. My car did that for a while before i figured it out and now my car actually runs 100% better and I've had no problems since.....
Posted on Apr 19, 2012
  • 34 Answers
The problem is in the connections with the unit to the car. check all wires make sure tight and connected. if no problem then let me know.
Posted on Jan 09, 2009
My car wont start once its hot and dies when driving it i have a pontiac grand prix 1997
on certain models wires--modules--relays gain resistence from wear-then heatup--try driving no more then an hour-then coolit a few hrs--get to a electric specialist soon n lettum run a data stream to pinpoint
Sep 02, 2012 | 1997 Pontiac Grand Prix
Battery keeps dying in 1997 Pontiac Grand AM. I've
There is a voltage draw from your battery while engine is not running.to prove this loose any one of your terminals.with all switches turned off including engine, disconnect and re-connect the loose terminal.if you get a spark then there is a voltage draw, find the wire and replace it
Feb 04, 2012 | 1997 Pontiac Grand Am
When you try to start it the alarm goes off. It starts, then dies.
Sounds like the alarm is shutting down the engine. Try disabling alarm system but depends how it's wired in what it effects.
Sep 02, 2010 | 1998 Pontiac Grand Prix
Car dies after driving through some water (it has been a week)
I believe you have a motor from GM where your distributer is on the bottom and therefore your wires are wet as well as the distrib cap
Jul 31, 2010 | 1997 Pontiac Grand Prix
I would have the control module tested. Some parts stores can test them. If that's ok, you might have some bad injectors.
Apr 24, 2010 | 2002 Pontiac Grand Prix
1997 pontiac grand prix GTP that will die while im driving
Mar 08, 2010 | 1997 Pontiac Grand Prix
Engine stalling out while driving
It could be that your fuel injection system is failing, try putting some fuel injection cleaner (gas additive) into your gas tank, you should notice a difference after the first full tank. If not it will be time to get your system checked-out at a garage.
May 18, 2009 | 1997 Pontiac Grand Prix
1997 pontiac grand prix with major issues
check all fuses for turn signal and brake lights.change fuel filter . first. do a little tune up change spark plugs and wires . if changing fuel filter dont help. have fuel pressure check first before buying a new fuel pump .they run after taxes 400.00 dollars. your fuel pressure should be 41 to 47 psi. replace fuel pump relay also.
Mar 16, 2009 | 1997 Pontiac Grand Prix
Open Questions:
See all DEI Python 1400XP Remote Start/Keyless Entry Questions
DEI Python 1400XP Remote Start/Keyless Entry System Logo
326 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Joe Taylor
Joe Taylor
_-__-___-_
_-__-___-_
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
