Question about Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Burner Problems- Unique, needs help
I have a hotpoint RGB745. 2 of my burners were not working unless i lit them with a match- a third burner worked, but had really weird, violent flames that sounded like wind. I cleaned around the electrode with a q-tip, and i used a twist tie to make sure the small holes in the burner heads were clear. I also used the twist tie, gently, on the holes where the gas comes from. I did this to all of them. Now, i've run out of matches. So, i turned on the broiler, and lit a small wooden stick, and i've tried lighting each burner that way since the ignitor is not working. What this has accomplished is the following; two of the burners light when lighted with this makeshift "match"- but, when i turn the knob from the ignition to high (or medium, or low) the flame goes out. no more than one will stay lit at once. I see sparks at the ignitor when i try to ignite but it won't ignite the flame. And, when i light it with my "match" as described above, the flame is thin and about 6-8 inches high. Kind of like a taper candle. Also, when i shut the door of my oven (broiler was on, remember?) the flame went out. Help?
  • Anonymous Mar 09, 2008
    my burner will not light the fire come out of the bottom of my burner
Burner not working
Posted on Jan 05, 2008
    Problem Solver:
  • 14 Answers
Not sure, but sounds like you may have a gas pressure problem or the stove is set-up for the wrong type of gas.
SOURCE:
Hotpoint gas range rgb745 electric igniter not working
Make sure igniter is getting power before you replace it. Also check the switch that feeds the igniter.
For parts go to attached. Search Over 2 1 Million Appliance Parts
Oct 07, 2015 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint propane model rgb746hed2wh oven burner will not turn off, Digital reading f-2
F2
During BAKE, Control senses oven temperature above 615F-630F
f actual over temperature condition occurred: Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC). Here is the part to order.
Dec 16, 2013 | Hotpoint RGB745 Gas Kitchen Range
My hotpoint. Has burner activity. The electronic oven will not light, makes no sound when the temp knob is depressed, nor with a match under the burner will it light. Makes no sound through trying each...
Ok
Is your igniter glowing when oven turned on.Look for bright orange glow near burner.If yes ,and no ignition,then igniter is weak and needs replacing.No glow at all,then a voltage test at the igniter needs to be done to see if it might be thermostat problem. Very common for igniters to go.Most likely cause.
Was this helpful?
Aug 18, 2011 | Hotpoint RGB745 Gas Kitchen Range
I have a hotpoint stove and the burner in the oven won't come on, the heat element lights up but the burner won't light whats wrong with my oven? susan
Even though your igniter is lighting up it probably needs replaced. They become weak and wont pull enough amps to open the gas valve.
Oct 09, 2010 | Hotpoint RGB745 Gas Kitchen Range
The lower burner does nor ignite
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Sep 16, 2010 | Hotpoint RGB745 Gas Kitchen Range
How to turn on oven?
mam please check the gas line is open and if the unit is idle for long time the gas line may choked so first you check the gas line.
Sep 07, 2009 | Hotpoint RGB745 Gas Kitchen Range
Top right burner on hotpoint gas range doesn't light
there is a spark ignition in the middle between the front and back burners....one for the left side and one on the right side. When it was cleaned i bet that the spark ignitor was slightly bent towards the front burner...now the gap is too big to fire the rear burner...the ignitor is very similar as the spark made in those push down lighters. so its safe to play around and adjust them as needed to make them work...Go ahead and take it apart and tinker with adjusting it...until you get both front and rear burners running again the way it was before.( peek at the otherside as a reference and try to make it match)
I hope this helps you out a little bit 8-)
Jun 06, 2009 | Hotpoint RGB745 Gas Kitchen Range
Gas burner not igniting on Hotpoint RGB745, can smell gas
check to see if any of the port holes are clogged.. usually where the ignitor comes into the burner head
Jan 20, 2009 | Hotpoint RGB745 Gas Kitchen Range
Hotpoint RGB745 Gas Kitchen Range Logo
376 people viewed this question
Top Hotpoint Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Sal De
Ismael Rodriguez...
Are you a Hotpoint Kitchen Range Expert? Answer questions, earn points and help others
