Question about Helman Group Nostalgia Electrics MMA-600 Margarita Mania Margarita & Frozen Drink Maker Single-Speed Blender
I purchased the Margaita Manin machine and it leaks
When placing the liquid in the blender, it pours out. The manual is hard to read, is there 2 gaskets one on top the blade and one below?
  • 30 Answers
We are under new management.
Please contact us at 1-920-347-9122 and we can help you with your Nostalgia Electrics product.
Also, please visit our new website at www.nostalgiaelectrics.com
We are more than happy to assist you.
Posted on Jun 17, 2009
How it is done so that the axes of a blender or mixer, and especially the ones of the propeller of a submarine, under great pressure, not leak the liquid?
Good question.
Axles are generally left with cars and trucks.
That's because an axle transfers energy to more than one place by means of gears and cogs, like to a pair of driving wheels at right angles to the power direction..
What you refer to are spindles, prop shafts and other things.
For the sake of simplicity, the seals you speak of are made of rubber rings held by metal bands around the spindle squeezed very tight with oil trapped around the joint. That keeps the water out most of the time.
In bigger machines, the oil seal is often made from a tough kind of leather (true !) ...leather is a really good water proof material under heavy pressure and heat providing it's kept "wet" by oils or waters.
Blenders spindles tend to use rubber "O" rings around the shaft because there's not much pressure, it's enough to keep your milkshake from leaking into the blender.
Oct 17, 2016 | Blenders
What can I do about my Vita-Mix Blender which leaks at the bottom?
You will need a special wrench to remove blade assembly.
then the gasket/seal is inexpensive.
you can check here:
Contact Us Customer Service Vitamix
or check here:
Vitamix Wrench
Apr 25, 2014 | Vitamix 34000 Blender
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Apr 14, 2014 | Montel Williams Living Well Healthmaster...
My breville blender model#bbl600xl leaks every time I put liquid in it, the gasket is in place and it is tightened as much as possible, what is the problem.
It leaks if you over tighten it. So try to just do it finger tight. I was having the same problem, once I eased off on the tighten if stop leaking. I assume you are getting it correctly aligned as that can be the other issue.
May 14, 2011 | Breville BBL600XL. 5-Speed Blender
When I use the blender it is difficult to get it tight enough on the bottom so that the liquid does not pour out from the bottom. The ring is not cracked. I have had this problem for a long time and it...
Try tightening the ring by (unplugged), align and tighten the base ring, rubber touching glass, then the blade plate assembly, then the ring....Then place on the machine, press down and tighten more...
I find that you cannot sometimes get enough tighening by hand, due to the dimention of the ring and the human hand...
Oct 27, 2010 | Back to Basics Smoothie Elite Work Top...
My Cuisinart blender start leaking after a few months of use.
Here is a list of things to check for:
1. Make sure the blender base (black plastic) is tight to the jar.
2. Make sure you have installed the rubber washer between the blender blade assembly and the jar.
3. Make sure your rubber washer is free from any crud that may have accumulated and dried on. You may have to soak the washer and gently scrub with a scrubber sponge. If it's really cruddy you may have to repeat as necessary.
4. Make sure you have not caught any water (or other liquid) when filling it between the base and the jar. When you pour out the contents it will appear as if it is leaking.
Mar 22, 2010 | Cuisinart BFP-703 SmartPower Work Top...
Blender container leaks even though gasket is in place
Hey, I know this is an old thread but just had the same problem and solved it. With the blender container upside down, place the gasket on the jar hole, put the blade through the hole on top of the gasket, then screw the plastic base on top of that.
The way I had done it before was to pop the blade into the bottom of the plastic base first then screw it onto the gasket and jar but it goes on the gasket, not under the bottom of the base. Hope that helps anyone else in the future.
Also just read the manual instructions like I didn't, clear as day right there but I never bothered to read them ha
Oct 18, 2009 | Cuisinart CB-600 Blender
Missing manual
Here you go
http://useandcares.hamiltonbeach.com/files/840166701.pdf
You will need the adobe pdf reader to veiw and or print this.
If you don't have the reader you can dload it here for free.
http://www.adobe.com/
Have fun with your new blender.
Sean
Feb 24, 2009 | Hamilton Beach liquid blu 5-Speed Blender...
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
Helman Group Nostalgia Electrics MMA-600 Margarita Mania Margarita & Frozen Drink Maker Single-Speed Blender Logo
110 people viewed this question
Top Helman Group Blenders Experts
Mike
Michael Vincent Cruz
Tom Chichester
Are you a Helman Group Blender Expert? Answer questions, earn points and help others
