Question about RIM BlackBerry Pearl 8100
Rim blackberry curve 8310 nothing works after 4.7 update
The only thing that works is the led indicator other than that no keys light up and neaither dose the screen it also has not hooked back up to the copmuter sents then. after i install desktop version 4.7 to my computer and then updated my phone right as it was about to be dont i reboted 3 time in a row by its self then nothing ever sents please help thabks
    Sergeant:
  • 367 Answers
First of all what os were you trying to put on the phone? 4.5 Exact version needed. 4.5.081. You can try to unplug phone then replug phone also unplug battery replug batter. then try installation again. make sure os is correct version for phone.
Posted on Jan 02, 2009
What is the code to unlock the blackberry 8310 curve
Do you need to unlock your Blackberry Curve 8310 from network lock?Blackberry has 10 unlocking tries..So you have 4 remaining unlocking tries.You can get the unlock code from the site
Classicunlocking.com for Blackberry Curve 8310 and unlock it easily using the unlocking instructions below...
Blackberry Curve 8310 Unlocking Instructions
Warning : Do not enter any wrong unlock codes on your Blackberry Curve 8310 mobile phones. If you enter over a certain amount of wrong unlock codes on your Blackberry Curve 8310 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Blackberry Curve 8310 with any Sim card and Turn off all Wireless connections.
2 - Go to Settings.
3 - Go to Options.
4 - Select Advanced Options.
5 - Select SIM Card.
6 - Type MEPD using your Blackberry Curve 8310 keyboard (NOTE: You will not see any text appear on the screen while typing MEPD),
7 - Type MEP then hold 'ALT" key and type number 2.(NOTE: You will not see any text appear on the screen while typing MEP2),
8 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
9 - Your Blackberry Curve 8310 will now be unlocked.
Oct 26, 2012 | RIM BlackBerry 8700c Cellular Phone
I cannot enter the pin code to unlock the blackberry.
Don't worry, try this step to insert your Blackberry Curve 8310 Unlock Code :
1 - Switch on your Blackberry Curve 8310 without any Sim card,
2 - Go to Options,
3 - Select Advanced Options,
4 - Select SIM Card,
5 - Hold the ALT Key while typing in MEPE or MEPD or MEPPE or MEPPD ( not case sensitive ) ( you will not see text appear on screen while typing ),
6 - You will then be presented with a prompt "Enter Network MEP Code". Type in the Unlock Code and press in the track wheel / jog dial to confirm,
7 - Your Blackberry Curve 8310 will now be unlocked.
If your phone still not unlocked, it means you have wrong blackberry unlock code. Don't try it again, and go to get new and correct unlock code.
Mar 07, 2011 | RIM BlackBerry Curve 8310 Smartphone
Green led light stays on,there is no messages or missed calls
I think it's there to tell you that you're within network coverage.
You can turn it off by going to Options, Screen/Keyboard, and set 'LED Coverage Indicator:' to "Off".
Hope this helps!
May 03, 2010 | RIM BlackBerry Curve 8310 Smartphone
My blackberry 8310 died and wontt turn back on..i charge itt and the lcd red light just comes on
can u c the battery sign after the led light goes off with a red line or with a charging line?
Apr 25, 2010 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8310 gaming problems
Some games or apps are not well optimized for the 8310, try using a combination of keys with the Alt key at the bottom right (Alt +Q or Alt+P) or simply the trackball. If this does not work I suggest you delete the app or game to free the internal memory.
Mar 13, 2010 | RIM BlackBerry Curve 8310 Smartphone
My keypad does not work on blackberry curve.
my keypad on my 8310 don't work. well some of the keys do but not all
Aug 04, 2009 | RIM BlackBerry Curve 8310 Smartphone
Blackberry curve 8310 fatal error during backup
I would connect the device to a PC and update the OS using Desktop Manager. If you recently installed any application, I would uninstall it as this may cause this type of behavior.
Jul 21, 2009 | RIM BlackBerry Curve 8310 Smartphone
BB Curve 8310 keys and trackball not working
is there a way to navigate thru options with no trackball
May 30, 2009 | RIM BlackBerry Curve 8310 Smartphone
At &t rim blackberry curve 8310 nothing works
Try here: First, download and install the latest version of BlackBerry Desktop Manager software from: https://www.blackberry.com/Downloads/contactFormPreload.do?code=A8BAA56554F96369AB93E4F3BB068C22&dl=DA5FB46338C8C0DCB1039F7898184FC5
Once installed, connect your BlackBerry to your computer via the USB sync cable. Open Desktop Manager, and click the Application Loader. On the right, you will see Update your device software. Click the Start Button, and if your BlackBerry is not on the latest Handheld Software, an update will appear. Select the update, and run the install. Be sure to select the option that backs up and restores your data. Once started, do not shut down your computer, or disconnect the USB sync cable as this could damage the device.
Once completed, your BlackBerry will restart and you will have the latest version available. This version has been known to correct various issues.
Dec 28, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
722 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
