Question about Uniden BC72XLT Handheld Scanner
Want to program scanner pro 91 for washougal pd
  • 120 Answers
Www.radioreference.com has all the frequencies for you area in the data base. just click on your state, then your county, and a list will come up of them all.
Posted on Jan 02, 2009
I need info on how to program radio shack pro-91 scanner
Try Googling (radio shack)(pro-91)(manual) without parens.
Sep 07, 2017 | Radio Shack Radio Communications
Need owner/manual for a PRO Handheld Trunking Scanner 91
Could you please confirm this is a Radio Shack Pro-91?
If so:
Manual available from Radio Shack: Click Here
Jun 17, 2011 | Radio Shack Pro-96 Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Listening in since the 60's
Nov 11, 2010 | Radio Communications
I cleared my scanner pro-82 now how do i program the channels back. the bank1 is blinking and is on channel 1. i do not have any scan codes for local fd/pd in the 78801 area zip code.
For a comprehensive database of active frequencies in your area (they're really NOT codes), visit:
To program known frequencies into your scanner,
1. Press PGM. PGM appears. Then enter the channel number (1-200) where you want to store a frequency, then press PGM again.
2. Use the number keys and DELAY/. to enter the frequency (including the decimal point) you want to store.
3. Press ENT to store the frequency into the channel.
Your scanner automatically rounds the entered frequency down to the closest valid frequency. For example, if you enter a frequency of 151.473, your scanner accepts it as 151.470.
Press DELAY/.if you want the scanner to pause 2 seconds on this channel before it proceeds to the next channel after a transmission ends. The scanner also stores this setting in the channel.
To program the next channel in sequence, press PGM and repeat Steps 2 and 3.
Need the full manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
BillB
Jan 19, 2010 | Radio Shack Pro-82 Scanner
Codes to reprogram
Do you mean the frequencies to listen to, or how to program it. Radio Shack has the programming directions, but the frequencies are local to you. This is not a digital scanner nor a trunked scanner, in which case, if your local PD/FD switched to a trunked system or digital trunked system you will need a new scanner. You should be able to program in your local weather radio channel, like 162.550 to test the unit though.
Dec 29, 2009 | Radio Shack Pro-2018 Scanner
I forgot how to reset my pro 99 scanner any
This link to the owners manual should contain the info you are looking for:
support.radioshack.com/support_electronics/doc72/72815.pd
Jul 16, 2009 | Radio Communications
Froze on WX scan
Reset it with a papclip inserted into the little hole on the left side of the scanner facing you.
May 28, 2009 | Radio Shack Pro-82 Scanner
Does my scanner trunk???
Your scanner does not do trunking. However, you should be able to monitor Dallas PD using it, since they are not using a trunked system. Richardson PD is using a EDACS system, which is trunked. You may still be able to pick up the frequencies used by Richardson, but the PD channels will be mixed in with all other users of the system.
Mar 27, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Pro 91... no luck on washougal pd codes
Here are the talk groups from Radireference.com. this is the best reference I have found on the web. The talkgroups are for the Clark Regional Emergency Services Agency (CRESA) System. Here is a link to that page in Radio Reference
http://www.radioreference.com/apps/db/?sid=106
41680 - Police Car-to-Car
41712 - Common
I hope this helps - elijam1
Here is another site for any of your other scanner needs. they sell scanners, antenns, and even programming.
http://www.scannermaster.com/?Click=37131
Dec 28, 2008 | Uniden BC72XLT Handheld Scanner
Whenever I push the orange fd/pd button it only searches through 32.00 to 46.00. Then when I push lockout it says FLO-FULL.
IT will only search the FD/PD codes range under the orange buttons. What you need to do is get a copy of your local frequencies and program them into your scanner, after that hit search.
Mar 18, 2008 | Radio Shack Pro-82 Scanner
Uniden BC72XLT Handheld Scanner Logo
51 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
