Question about Philips 55PW9363 55" Rear Projection HDTV-Ready Television
Clearer HDTV picture?
5 year old tv the HDTV is not as clear as it once used to be. recently changed service from comcast to AT&T u verse. now the HDTV is not as clear.What can be done?
  • agnesl75 May 11, 2010
    Hi Slinteriors,
    Would you tell me where I can buy crt coolant & How to change it?
    my hdtv is 55pp93
    Thank you,
    Agnes
    Problem Solver:
  • 7 Answers
I second the coolant change...from expierance ;)) Helps greatly.
Posted on Apr 10, 2009
  • Philips Master
  • 8,617 Answers
Quite possible that the coolant is getting contaminated as thats a normal occurance with phillips after a few years. If the color seems dim and not focusing properly its almost certain that the CRT coolant will need changing
Posted on Dec 28, 2008
Avol ALT42FD120 - frame rate change 60-120hz?
Hi. It is entirely possible that the set is already running at 120Hz after all. The display 1080p 60Hz is merely the signal it is receiving and the earlier TV's that used to claim 100Hz/120Hz merely did so using line doubling only to give a clearer picture by filling in the blanks between scanlines. If your picture is already very clear, then I wouldn't worry about it
Mar 21, 2010 | Samsung 52 in. Flat-Panel LCD HDTV
There is sound but no picture and there is no response when using the control buttons on side of tv or the remote. I turn the tv on and change channels thru Comcast cable.
Talked to a Westinghouse tech and told to unplug for about 3-5 minutes, then re-plug. It's like having to re-boot your computer when it goes down or starts acting wacky. It worked, I got picture. Says it could happen again, maybe 1-2 times a year is o.k., if it starts to happen every few weeks, then it's something more.
Oct 14, 2009 | Westinghouse LTV-37w2 HDTV
Late in day the picture on our 5 year old set starts to drop down to where we cannot see the bottom portion of the screen. Recently installed Comcast three-way service.Comcast insists it is TV problem.
What you can actually do is on your remote or within your menu options you should be able to set your screen size to standard, fill or overscan.
Aug 04, 2009 | Televison & Video
Not a good clear picture.
I have a philips magnavox and had two problems that I recently fixed using kits from www.TvRepairKits.com. I can't say enough about their kits and help. Without them I would have never been able to fix my TV set myself.
The first problem I had was the TV was looking 3D. After doing some homework I found out that this is a convergence problem. I bought a kit, followed the instructions, and to my amazement fixed it myself.
After building my confidence with the 1st repair I decided to get their CRT fluid kit. This kit fixes the dull video,red video, or bright/halo looking video. If you have a magmavox set that is more than 5 years old your tv has this problem already. It happens on every set. As before I bought the kit, followed the instructions, and now my video looks factory new. Once again I wanted to say thanks to the team at Tv Repair Kits for putting together kits that the average joe can use.
ML
Jul 24, 2009 | Philips 43P8341 43" Rear Projection...
Hdtv picture freeze
I also have a Brand new Sony Bravia 52" LCD with Comcast Cable (motorola box).When switching between HD Channels sometimes the left side of the screen shows a smushed version of the new channel, and the right side is a frozen picture of the previous channel. I correct this by switching to a non HD channel and back. Cable or TV problem I wonder?
Jul 03, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
Vizio HDTV totally not workinig
It sounds like a problem with the power supply. I had the same thing happen on a TV that was only a couple of years old. It did the same thing that you have mentioned. Once in a great while, it would turn on, and then we'd just leave it on because we didn't know when we would be able to get it to work again. The problem was, to buy a power supply for it we could get another TV. It just wasn't worth it.
Your flatscreen might be under warranty. I would look into that.
Jun 11, 2009 | Vizio L30WGU 30 in. HD-Ready LCD...
I'm seeing a white blinking lines either on the bottom or top of the screen, depends on the channgel. I'm using At&T u-Verse service. My question is it my Plasma which is two years old or could be At&T?
If it's a horizontal line then its the TV service you are using. This also happens with cablevision and Verison FIOS services. You might be able to look into your menu settings on the TV and adjust this.
May 02, 2009 | Pioneer PDP-5020FD 50 in. Plasma HDTV
Am i getting hdtv with just cable feed?
Depending on your cable provider, some of the HD channels may be present. If so, these are ususally located in the upper channel numbers. It sounds like you are receiving some of the HD lineup. A cable box will probably allow you to view more HD channels including the premium HD channels if you subscribe to them. You should not be noticing a delay with the HD channels only. If this is what you are experiencing without a cable box, then it would be an issue with the HD tuner built into your TV set. LG customer service can let you know if there are any software updates available for yourmodel that can resolve this. Additionally, if you are getting your sound from an Home Theater system then you will notice an echo if using the TV's built in speakers at the same time. This is sometimes mistaken as an audio delay. If you are using a home theater system, be sure to disable the speakers that are built into your system.
Jan 04, 2009 | LG 37LG30 37 in. LCD HDTV
Red and blue
convergence amp ic going bad.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 30, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Philips 55PW9363 55" Rear Projection HDTV-Ready Television Logo
112 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
