Question about Canon PIXMA MP780 All-In-One InkJet Printer
Ip4500 printer will not accept refilled cartridges
HOW DO I MAKE PRINTER ACCEPT REFILLED CARTRIDGE
    Genius:
  • 2,120 Answers
DUH!
Posted on Dec 28, 2008
Hp c4150 printer won't recognize my refilled black 98 cartridge. first time it has been refilled. how do i reset the printer to accept the refilled cartridge?
Dear jiraphe102,
Welcome, and thank you for using FixYa!
Unfortunately, you have the particular brand of cartridge that cannot be refilled. The smart chip on the original cartridge has expired; and will not reset.
You can purchase refurbished Ink online (meaning they have rebuilt the entire cartridge) at the link below.
Refurbished Ink
http://www.lainks.com/.sc/ms/pml/Inkjets--Hewlett%20Packard/Photosmart%20C4150
Or buy new cartridges.
Have a great day!
Sep 05, 2011 | HP Photosmart C4150 All-In-One InkJet...
My Hp officejet 6110 printer does not want to accept a re-filled ink cartridge. Why? Can this problem be fixed? How? It only wants to accept new cartridges and I know that the stores want to sell new...
Who refilled the ink-cartridge?
If you did it, then you need to "reset" the electronics inside the ink-cartridge, to indicate to the printer that it is a "new" cartridge, and not the same "empty" cartridge.
When you say "does not accept", EXACTLY what error-message do you get?
Jul 25, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
Feb 17, 2011 | Epson Stylus TX400 Series
Printer will not accept new cartridges. Printer is new and wants original cartridges to initialize ink system. Original cartridges are not availible. Tryed reset but did not work.
HP printers will not accept refilled cartridges. Are you trying to replace your empty cartridges with refilled cartridges? There is a computer chip in the ink cartridge that tells the printer when it is out of ink. If you try and refill it yourself, the printer will not recognize that it has been refilled without replacing the computer chip in it.
I think your printer is telling you that it needs HP brand cartridges that are original and not refilled cartridges. There is no way to "reset" an hp printer to get it to use an off brand or refilled cartridge that has not had the chip changed.
You can pick up a good refilled cartridge at a professional company who knows about changing the chip for less then a third of the regular price of an HP cartridge in a department store. However, HP does not want you to use refilled cartridges and should something go wrong with your computer and they find out that you were using them they will void your warranty on your printer.
If you are not trying to replace HP brand cartridges with refilled or off brand versions, I suggest your return them to where you bought them and exchange them. They may be defective cartridges.
Hope this helps?
Nov 11, 2010 | HP C6250 InkJet Printer
Can't get HP PSC 2530 to accept re-filled catridges! Both are full but it keeps telling me to remove and check right-hand one; can't by-pass or override the message.
Hi
In order not to have error messages in your printer
You need to remove all the air bubbles from the cartridges
the best way when you do it alone is bu using refill clips
check here the right method
Hi pls vote us to keep us alive
Nov 08, 2010 | HP PSC 2350 All-In-One InkJet Printer
Installed updates now HP printer won't accept refilled ink
HP does not recommend refilling thier tanks, their print heads are built in to the cartridge so if you refilled it before resetting the tanks you will have to go to www.hp.com and run the trouble shooting tool for free to fix your issue. you may have to replace the catridge.
Mar 11, 2010 | HP PhotoSmart C3140 All-In-One InkJet...
How do i make printer accept refilled cartridge t
Maybe you did not refill and insert it very well.
follow this steps in refilling your ink
1. remove the ink cartridge from the printer
2. make a hole at the top end of the cartridge, the hole can be made under the label on the cartridge by using a sharp/hot pin.
3. if you are using a syringe and needle in refilling, make sure you did not insert it into the hole too much so that the cartridge does not get damaged in the process.
4. make sure the ink is not over-filled to avoid spillage which can cause a hell of damage on you printer as it does to my previous one.
5. Gently use the label or a masking tape to cover the hole and insert it into your printer.
Note: The printer gives a message that the cartridge is empty or non compatible, ignore the message and continue with your printing.
It is also advisable that you refill your cartridge not more than 2 times.
If this solution does not help you, contact me on holamydes@gmail.com for more assistance.
Aug 15, 2009 | HP DeskJet F4280 All In One Printer InkJet
Error 1203 cartridge error
There seems to be something wrong with the color cartridge that i had refilled. Even though the place that refills them says theres nothing wrong with it, the printer wont accept it. I just removed it :) thanks!
Feb 01, 2008 | Lexmark OfficeCenter X3350 All-in-One...
HP PSC 2355 Won't accept refilled ink cartridges
If problem is what I think it is (that is if you cleaned whole thing and it is connected proprely), you have only one option. To buy at least three cartridges...problem is due a small trick made by HP. Printer remembers at least two cartridge serial numbers, and then wont accept refilled ones. But if you first stick one, then the other, and on the end the third one(only this one should be really full) it should reset printer and it should foul it to accept it. But on some printers it needs up to five cartridges! What a waste of money :( Anyway, hope this helps...
Aug 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
Remove and check colour cartridge HP 23, HpPSC500 error
Did you trying cleaning the cartridge contacts on your machine?
Jun 23, 2007 | HP PSC 500 All-In-One Printer
Canon PIXMA MP780 All-In-One InkJet Printer Logo
old marine
old marine
