Question about Uniden BC72XLT Handheld Scanner
Pro 91... no luck on washougal pd codes
Im new to this i just want to figur out how to program washougal pd codes have tried it all i think i can get other **** but not what i want
  • 31 Answers
Here are the talk groups from Radireference.com. this is the best reference I have found on the web. The talkgroups are for the Clark Regional Emergency Services Agency (CRESA) System. Here is a link to that page in Radio Reference
http://www.radioreference.com/apps/db/?sid=106
41680 - Police Car-to-Car
41712 - Common
I hope this helps - elijam1
Here is another site for any of your other scanner needs. they sell scanners, antenns, and even programming.
http://www.scannermaster.com/?Click=37131
Posted on Jan 07, 2009
I need info on how to program radio shack pro-91 scanner
Try Googling (radio shack)(pro-91)(manual) without parens.
Sep 07, 2017 | Radio Shack Radio Communications
Converting un known audio format
No, the PD-6070 can only record to .wav format
May 07, 2008 | MyMusix PD-6070 MP3 Player
Im trying to add new numbers programmed into my pro-94 scanner. i no longer have the manual and i have been browsing the web everywhere with no luck so far.
You can download and print your scanner manual, at no cost, here:
http://support.radioshack.com/support_electronics/doc61/61172.pdf
Bill B.
Listening in since the 60's
Mar 25, 2011 | Radio Shack Pro-94 Scanner
Want to program scanner pro 91 for washougal pd
www.radioreference.com has all the frequencies for you area in the data base. just click on your state, then your county, and a list will come up of them all.
Dec 28, 2008 | Uniden BC72XLT Handheld Scanner
TW Code Starview
New New codes for tw at 17.30 4/12/08
00=co f6 61 87 91 f9 67 57
01=83 35 e5 28 40 49 b2
Dec 04, 2008 | StarTech.com StarView SV211K 2-port KVM...
Trouble codes
You might want to check for a mouse nest under the Underhood fuse block, seen them chew up wiring under there many times.
Nov 04, 2008 | 2002 Chevrolet Silverado
Whenever I push the orange fd/pd button it only searches through 32.00 to 46.00. Then when I push lockout it says FLO-FULL.
IT will only search the FD/PD codes range under the orange buttons. What you need to do is get a copy of your local frequencies and program them into your scanner, after that hit search.
Mar 18, 2008 | Radio Shack Pro-82 Scanner
How to program a remote control prostart in a jetta 91
Sounds as if the device is now out of the warrenty by now. any Devices like this are common to break down. Im surprised you got 6 years out of the bugger. the companys want you to buy new ones. you can try checking the prostart website fora replacement remote, but the cheapest way out is to goto a wall mart and get a new remote start.
Nov 10, 2007 | Computers & Internet
Remote Control code for DVD Protron PD-800
The code I used and it seems to work is 0194, but while trying to program my receiver, It changed some setting and the picture keeps looping over and over on the screen, and I can't get it to stop, I even made it worse while messing with the settings....
May 14, 2007 | Protron PD-800 DVD Player
Mbr3447 remote code for samtron vcr
Up untill a few years ago they used to make a lot of universals with a "learning" function, that you aim the thing at a certain device untill it figures out the right code for it. I read that the technology was bought since so you dont see those quite as often in the market. ok, if yours is a learning uni, here's a tutorial on how to fix it, in general terms since it varies between remotes: If you cannot get the instructions - most "universal" remotes have a "code search" feature. Usually this involves hitting the "program", "select" or "function" button, then pressing the device button ("TV", "VCR", "AUX") then repeatedly pressing the "power" or "channel up" button until the set responds. The remote will cycle through each of the codes (01, 02, 03, 04) sending the "power" command for each. When you hit the right code - the set responds. When the set responds, stop and then press the "program" or "function" button to enter it (which button varies between mfgrs). If you count the number of presses - that should be the code (12 presses is "12" or "012" - or it could be 11 if the codes start at 00). If you do not have a "program" button (it might be hidden), then you may have to instead hold the function (TV, VCR, Cable) button down for a few seconds (until the light blinks). The usual manual sequence is: 0 1 2 It might also be: 0 1 2 If no program button: 0 1 2 Some remotes use a two digit code, some use three. It'll take quite a bit of trial and error without the manual. you can try getting the codes from the manufacturer, go to their site and see if you can figure anything out there... good luck
Jan 19, 2006 | Zenith MBR3447 Remote Control
Uniden BC72XLT Handheld Scanner Logo
95 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
