Question about Logitech Webcam
Installing from disk not working
Says parameter is wrong
    President:
  • 2,692 Answers
GO to the maunfactures website and download the drivers that match your windows version on you computer. The parameter that they are rfering too is the wrong OS for the install disk.
Posted on Dec 28, 2008
What is RAID? Can this cause video issues? Can the Video problems be ralated to the PSU?
RAID is where you use data in stripes over many disks to improve reliability, one disk can go down and can be replaced without rebuilding machine. RAID is not appropriate for a single disk machine.
Jun 23, 2014 | Dell Dimension 8100 PC Desktop
Code Error0x0000073
found this on net
STOP: 0x00000073 (parameter, parameter, parameter, parameter) CONFIG_LIST_FAILED
Explanation: This is a Windows 2000 Executive character-mode STOP message. It indicates the system configuration link list failed. One of the core system hives is corrupted or unreadable, or some critical Registry keys and values are not present.
User Action: If this is the first time you have booted after installing new hardware, remove the hardware and boot again. Check the Microsoft Hardware Compatibility List to verify that the hardware and its drivers are compatible with Windows 2000. For information about the hardware, contact the supplier. If you are installing Windows 2000 for the first time, check the Windows 2000 system requirements, including the amount of RAM and disk space required to load the operating system. Also, check the Hardware Compatibility List to verify that the system can run Windows 2000. If Windows 2000 is loaded and no new hardware has been installed, reboot with recovery options set to create a dump file. If the message continues to appear, select the Last Known Good option when you reboot. If there is no Last Known Good configuration, try using the Emergency Repair Disk. If you do not have an Emergency Repair Disk, contact your technical support group.
Nov 19, 2013 | Computers & Internet
Windows disco non presente exception processing message c0000013 parameters 75b1bf7c 4 75b1bf7c 75b1bf7c
Wrong removable disk/media letter in My Computer.
Go to Start / Computer management / Disk management / in there check that the first partition on the hard disk is C and none of the other partitions/removable media disks have assigned the C letter. If one of them has it (or none at all) then right click on it / Change Drive Letter and Paths... / Change / select another letter / OK .
May 23, 2010 | Microsoft Windows XP Professional SP3 Full...
I have a compaque with xp media center like this and somebody else entered the wrong program and installed windows xp from 2001. This system caused it to crash and I NEED some recovery disks to replace...
I found the codes within the computer and isolated its parameters overwriting the program and separated the second brain. After doing this I had some old restore disks to preform a software transfer. In doing so my computer came out to a factory style when we first bought the computer. Reformating is what I prefored afterwards. Now it is not stuck in the boot screen anymore and i have no more problems like blue screen of death when my computer has an error or failure to complete a task.
Sep 30, 2009 | HP Compaq Presario SR2150NX PC Desktop
Problem: KERNEL_DATA_INPAGE_ERROR Technical information: ***STOP: 0x0000007A (0xC0403638, 0xC0000056, 0x4277F860, 0x806C7913) ***acpi.sys ? Address 806C7913 base at 80692000, DateStamp 49c01a37
The KERNEL_DATA_INPAGE_ERROR bug check has a value of 0x0000007A. This bug check indicates that the requested page of kernel data from the paging file could not be read into memory.
Parameters The four parameters that are listed in the message can have three possible meanings. If the first parameter is 1 or 2, or 3 and the third parameter is 0, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (1, 2, or 3) 2 The error status (usually an I/O status code) 3 If Lock Type is 1: the current process
If Lock Type is 2 or 3: 0
4 The virtual address that could not be paged into memory
If the first parameter is 3 (and the third parameter is nonzero) or 4, the parameters have the following definitions.
Parameter Description 1 The lock type that was held (3 or 4) 2 The error status (typically an I/O status code) 3 The address of the InPageSupport structure 4 The faulting address
Otherwise, the parameters have the following definitions.
Parameter Description 1 The address of the page table entry (PTE) 2 The error status (usually an I/O status code) 3 The PTE contents 4 The faulting address
Cause Frequently, you can determine the cause of the KERNEL_DATA_INPAGE_ERROR bug check from the error status (Parameter 2). Some common status codes include the following:
  • 0xC000009A, or STATUS_INSUFFICIENT_RESOURCES, indicates a lack of nonpaged pool resources.
  • 0xC000009C, or STATUS_DEVICE_DATA_ERROR, typically indicates bad blocks (sectors) on the hard disk.
  • 0xC000009D, or STATUS_DEVICE_NOT_CONNECTED, indicates defective or loose cabling, termination, or that the controller does not see the hard disk.
  • 0xC000016A, or STATUS_DISK_OPERATION_FAILED, indicates bad blocks (sectors) on the hard disk.
  • 0xC0000185, or STATUS_IO_DEVICE_ERROR, indicates improper termination or defective cabling on SCSI devices or that two devices are trying to use the same IRQ.
These status codes are the most common ones that have specific causes. For more information about other possible status codes that can be returned, see the Ntstatus.h file in the Microsoft Windows Driver Kit (WDK).
Another common cause of this error message is defective hardware or failing RAM.
A virus infection can also cause this bug check.
Resolving the Problem Resolving a bad block problem: An I/O status code of 0xC000009C or 0xC000016A typically indicates that the data could not be read from the disk because of a bad block (sector). If you can restart the computer after the error, Autochk runs automatically and attempts to map the bad sector to prevent it from being used anymore.
If Autochk does not scan the hard disk for errors, you can manually start the disk scanner. Run Chkdsk /f /r on the system partition. You must restart the computer before the disk scan begins. If you cannot start the computer because of the error, use the Recovery Console and run Chkdsk /r.
Warning If your system partition is formatted with the FAT file system, the long file names that the Windows operating system uses might be damaged if you use Scandisk or another MS-DOS-based hard disk tool to verify the integrity of your hard disk from MS-DOS. Always use the version of Chkdsk that matches your version of Windows.
Resolving a defective hardware problem: If the I/O status is C0000185 and the paging file is on an SCSI disk, check the disk cabling and SCSI termination for problems.
Resolving a failing RAM problem: Run the hardware diagnostics that the system manufacturer supplies, especially the memory scanner. For more information about these procedures, see the owner's manual for your computer.
Check that all the adapter cards in the computer are properly seated. Use an ink eraser or an electrical contact treatment, available at electronics supply stores, to ensure adapter card contacts are clean.
Check the System Log in Event Viewer for additional error messages that might help identify the device that is causing the error. You can also disable memory caching of the BIOS to try to resolve this error.
Make sure that the latest Windows Service Pack is installed.
If the preceding steps do not resolve the error, take the system motherboard to a repair facility for diagnostic testing. A crack, a scratched trace, or a defective component on the motherboard can cause this error.
Resolving a virus infection: Check your computer for viruses by using any up-to-date, commercial virus scanning software that examines the Master Boot Record of the hard disk. All Windows file systems can be infected by viruses.
Jul 12, 2009 | Microsoft Windows Vista Home Premium with...
HP PSC All-In-One inkjet printer--incorrect parameters
RE CONFIGURE , REMOVE everything that has to do with the HP printer from your laptop , and RE INSTALL IT using the installation disk, hope this helps , AJ
May 18, 2009 | HP PSC 2355v All-In-One InkJet Printer
I have an incorrect parameter error when I'm booting up and can't seem to get help on how to repair it or get rid of it. I've tried everyone. Unable to logon to system. Parameters are incorrect
You may need to have your Hard Disk wiped and Windows re-installed. It sounds to me like one or more of the Operating Systems file's has become corrupted.
Apr 16, 2009 | Dell Dimension 2300 PC Desktop
The parameter is incorrect
download a software called mini tone and it will read it
Feb 06, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Fixed Disk Parameter Error - System Halted
Sounds like bad disk, although 3 beeps sometimes relates to a memory problem on some motherboard bios's. Click Start>run then type'chkdsk' and then Enter, this will run a damage segment diagnosis and repair, if capable.
Dec 20, 2006 | Compaq Armada M700 Notebook
Logitech Webcam Logo
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
