Question about Kodak EASYSHARE 5100 All-In-One Printer
Printing problem with the kodak 5100
The printer prints fine on the main printer part but when I use the photo 4x6 printer the print quality is really bad. really wet, smudges all over. I cleaned it about 3 times and I just got this for christmas and nothing seems to work. I had a small easy share docket before and the print quality was excellent and the only reason I changed to the all in one is because I do alot scrapbooking. I'm not impressed with this printer at all! Please help me
Theres alot of possible reason why you're having those print out. In your case since your complaining about the ink being to wet.. check the paper that ur using is it a photo paper? is it inkjet compatible? did you use the same paper you used before? Possible that your Print Head is defective. Have you tried using the ITG(interavtice troubleshooting Guide) www.kodak.com/go/itg
If that does not work call kodak. 1-800-421-6699. :-P
Posted on Dec 31, 2008
The printer works OK but it prints two lines clearly but every third is feint almost half the writing is ommitted
Set the print quality to normal or best.
Clean the printhead
Run a calibration.
The Kodak EasyShare AiO performs a calibration every time you install or replace a printhead. However, you can run a calibration if you are seeing changes in the image quality. Calibration aligns the printheads and performs a nozzle health check to enable high-quality prints.
1 Load the main tray or photo tray with photo paper.
IMPORTANT: If you don't have any photo paper, you can use plain paper, but photo paper is highly recommended for calibrations.
2 Press and hold Photo and Cancel together to make a calibration print.
3 Follow the instructions on the calibration print to calibrate the printer.
Feb 11, 2011 | Kodak EASYSHARE 5100 All-In-One Printer
Rollers won't pick up photo paper.
Hi I would suggest you to try once again by putting the shiny side up and print it again, some time even if the pages get stick with each other than also the printer wont take paper in. so try one more time and do reply if you still have the same problem or nay other.
Naiven.
May 31, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5100 AiO When printing emails the borders
Read through some of the solutions on here and eventually removed print heads and cleaned them and printing of borders and words is now fine. Still have probs with photos being discoloured .
Apr 12, 2009 | Kodak EASYSHARE 5100 All-In-One Printer
My HP C7200 printer won't print from the photo tray
If you using a mac: After choosing the Photosmart C7200 to print your file on the print preview, change PAPER SIZE to 4x6, then lower down, change from PREVIEW to PAPER TYPE/QUALITY, more options will open underneath, on SOURCE, change from MAIN TRAY to PHOTO TRAY. You should also change the PAPER TYPE to some kind of PHOTO PAPER (whichever one your using, but the standard seems to be HP ADVANCED PHOTO PAPER)
Jan 27, 2009 | HP C7200-69016 Network Adapter
I can print 4x6 photos but not documents from my computer
Maybe your phototray is still engaged. If the green light by the photo tray is on - then it is engaged and you cannot print documents. Lift up the clear lid of the little photo tray, pull it back towards you until it clicks in place. The light will go off. Close the tray lid.
You should be able to print documents now. Make sure the document tray below the photo tray has paper in it.
If all else fails, try Kodak's Help on-line at this site www.kodak.com/go/5100aiosupport
They have an on-line survey tool to help you with your problem. Good luck.
Dec 02, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Not printing microsoft office documents, VIsta Software
Try to press the photo and copy at the same time it will print a diagnostic page
look how is the quality of the text.
if it prints very light or if it doesnt print open the access door and try to remove the ink cartridges and put it back again and make sure you hear a click sound after you put the cartridges back in and close the printer access door
try to print again a demo page press photo and copy and check if there is improvement
if no improvement open the kodak aio home center software click on the question mark(?) on the upper right corner and click on maintenance..then select printhead cleaning.After the printhead cleaning print again demo page (press photo and copy at the same time) if still no improvement on the quality of the text call the kodak hotline 1 800 421 6699..you might need a printhead replacement..
Nov 16, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Only 4x6 tray prints clearly
For this concern try pressing "copy+cancel" for media calibration then try again, make sure you have an A4 paper loaded. If this doesnt help you out try using the Kodak website www.kodak.com/go/itg and use "image quality" for class.
Oct 21, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak 5300aio printing borderless photos problem
call kodak, they have good support and you'll speak to a human quickly
Oct 09, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Kodak Easyshare 5100 Wont Print In Color Or Black
For all of those problems, you need to replace the Printhead. This is one of the most common issues among the Kodak All in One Printers, they simply stop printing text. However, it seems that Kodak is sending out some new printheads that work so much better, so you should get in contact with their support and have them replace their printheads. Call cb_transparent_l.gifus.gifspace.gifspace.gifarrow.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gifspace.gif1-800-421-6699cb_transparent_r.gif.
Jun 15, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
FD73 Photo Quality
I'm guessing, cause i own a F505 and not a FD73......but, I dont even see a use for the F505 "standard" quality setting. It will stay on "FINE" quality always. I've got a HP 882c and it prints just fine. I use HP premium photo paper and the printer setting BEST. Are you using photo paper? Regular paper will bleed the colors around. Take some pictures on FINE and print them out on photo paper w/ printer BEST and compare.
Sep 11, 2005 | Sony Mavica MVC-FD73 Digital Camera
Kodak EASYSHARE 5100 All-In-One Printer Logo
112 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
