Question about Panasonic Lumix DMC-TZ1 Digital Camera
My panasonic lumix dcm-tz1 camera will not zoom.
I can only zoom a very small amount before a message saying "please turn camera off and then on again" appears on the screen. This message stays on the screen until the camera is turned off. I can still take pictures with it as long as I do not try to zoom but that is the whole point of this camera!
  • 3,037 Answers
Hello mbradsh3
You have a gear that is getting stuck on something or it may be broken in the lens. Try bumping the camera on your palm when this happens and try it again. If that doesn't work, then either send it in if it is under warranty, or open it yourself and see if you can find the problem, or take it to a repair shop or send it to panasonic so that they can fix it.
bestdarngood
Posted on Dec 28, 2008
  • Panasonic Master
  • 13,433 Answers
Seems theres a problem in the zoom the zoom is either stuck or the motor has a problem, is your camera under warranty? if not
you can get a free repair estimate from www.advancecamera.com/repair
    Genius:
  • 1,550 Answers
The lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work
Hope this helps .
Memory card error for the Panasonic DMC-TZ1
What type and size memory cards? The DMC-TZ1 works with SD cards 2GB and smaller. It will not work with higher-capacity SDHC cards.
Mar 15, 2013 | Panasonic Lumix DMC-TZ1 Digital Camera
Error in digital cam that please turn off the camera and on again
smeone had gifted me panasonic digital cam DCM LZ8 bt when i turn it on an error accurs that please turn off ur camera and then on again
please help
Jan 01, 2010 | Panasonic Lumix DMC-LZ8K Digital Camera
I have the Panasonic dmc-tz1 it keeps saying to turn camera off then back on. I do this and still cannot take pictures or use camera!!! HELP!
You surelly drop down the camera or you have some sand inside the zoom lenses movement. You need to open the camera, opens the zoom lenns the clean the gear or replace the broken gear inside lenses
Nov 08, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Picture is not clear between no zoom and total zoom
ur zooming belt got crack dont use zoom. get it dont in service centre or sentd to us
Jun 18, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DCM-LC43
Sell it to a repairman on ebay and buy a good used, refurb or new replacement. I would ugrade to at least the wide angle 6Meg TZ3. The TZ5 is the newest TZ line.
Great cameras. I have the TZ3 and have never looked back.
May 26, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Will not zoom
its broken mine dose the same
May 19, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic DMC-TZ1
I just had this problem, too. I basically disassembled the camera by removing the back cover, front cover, and top assembly. The top assembly includes a plastic part between a circuit board and the top external metal piece that houses the button on the top of the camera. On the circuit board there is a switch for the zoom that looks like a pinball flipper. You have to make sure that it's working properly and you may have to remove the metal dust cap and remove any sand if it's lodged in the mechanism. It's pretty tough if you're not good with your hands because it's extremely small. I did this and the zoom began working like normal again, but then I got the message that the camera needs to be turned on and off every time I turn on the camera...
Sep 26, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Panasonic Lumix DMC-tz1
lens mechanism needs cleaning ( moisture ) and possible alignment ( jarred ) ; charge or replace batteries , before getting estimate ;
Jul 31, 2007 | Panasonic Lumix DMC-LC33 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
