Question about Brother GX-6750 Typewriter
Need to replace print wheel
I think I need to replace the print wheel. Is this something I can do myself? Where do I find directions?
    Problem Solver:
  • 20 Answers
The print (daisy) wheel has a lock lever on the right hand side, pull toward you to release, push forward to lock back in place.
Posted on May 14, 2007
Louvre space saver assembly instructions
I really thought that there would be instructions in the box..I really don't think that I should buy something than have to go out of my way to get a handy man to put it together. I am capable of doing that myself if I had the instructions. I also don't feel that I need to call someone to get the instructions...looks like it might be a problem for everyone...I don't mind looking them up on line and print them but other than that not interested...guess it will just have to go back to bed bath and beyond...
Jul 31, 2013 | Home
Power steering issues
I'm going to agree with the rack conclusion. Keep in mind I can't see it for myself.
If you take the load off the front wheels, you should be able to turn the steering wheel without effort.
If the effort changes while turning the wheel, the only things affected would be the rack and the column.
If you notice it turns ok with the engine off but not with the engine running, it could be something with the pump or one of the lines, or still something with the rack.
Jul 05, 2012 | 2004 Ford Freestar
There's an annoying creaking sound coming from around my right rear wheel on my 2005 Accord. I think I've identified it as the trailer arm. Is that something I can replace myself?
they are usually fairly easy to replace, remove the large bolt that holds the arm to the knuckle, then remove the 2 bolts that hold the arm to the sub frame. Just grunt work really, not too hard.
May 23, 2011 | 2005 Honda Accord
I am trying to print but seems to be out of ink because the labels are coming out blank. There is nothing in manual about print heads or ink. I am thinking I need to replace something and I don't know what...
LP2824 is a direct termical printer, does not use ink of any kind, it means that it requires a special paper for it to print, printhead burns the special paper in specific areas to show the pattern, if you are sure that you are using that special paper and it keeps not printing, is very posible that the printhead need to be clean up or replaced.
Mar 12, 2011 | Zebra Printhead for LP2824
I have a 2006 roadliner that needs the front tire replaced. Thought I could save a few bucks if I pulled the wheel offf myself and took it to a shop to chang the rubber out. I have the bike up on a lift...
if both wheels are off the ground then you should be ok to remove front wheel,when you take the spindle out and remove wheel from between forks put the spindle back through both forks and use a axel stand or something to prop under the spindle just to be safe so it wont tip forwards.
Jun 12, 2010 | 2006 Yamaha Roadliner Midnight
Not fully opening
This does sound like the gas spring needs replacing. This is something that the manufacturer needs to do for you though. I would suggest that you contact your retailer to get this rectified.
Hope this helps.
Mar 19, 2010 | Quinny Buzz Three Wheel Stroller
Need ball joint assembly replacement for pride celebrity 4-wheel electric scooter
give PHILLTURVEY@AOL.COM a ring,he may have what your looking for,or direct you where.im disabled myself,glad to help Colin.His mob:07897421151.
Jul 12, 2009 | Pride Celebrity X 4-Wheel Electric Scooter...
The key don't turn on and the steering wheel doesn't a try in many ways and not work I think the pins are stuck than I need fix or replace it, but I do not how take cylinder off
The steering wheel/ignition may be "locked". Try turning the steering wheel as far as possible in one direction and then try turning the ignition (key). I've had to try this a few times myself.
Apr 29, 2009 | 2004 Saturn ION
Left jog wheel on CDN *88 remote controller not working
Hi tmal004,
I don't have a technical manual for this unit, but I have worked on these before. They are fairly easy to dismantle, take care to apply even pressure when removing the jog wheel, use something like a butter knife (2 off) to slide under opposing sides of the wheel and gently prise up. Spare parts for this unit are available directly from Numark, however you can source them from elsewhere. you'll probably need to replace the transducer.
Good Luck.
Feb 13, 2009 | Numark CDN95 2-Disc CD Player
Make sure the hammer is snapped all the way back it takes a little pressure to get it to latch it then should find its home position on is own.
Nov 19, 2007 | Brother SX-4000 Typewriter
Brother GX-6750 Typewriter Logo
115 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
