Question about Kenmore 24 in. 15142 Built-in Dishwasher
Kenmore Elite Model 77962 not running properly
We have a fairly new (2 months old) Kenmore Elite Dishwasher. Just recently I have noticed that it will run a couple cycles normally and then it has problems. Seems that it either doesn't fill with enough water for it to run or maybe the spray arms don't get rotating? It will kind of surge like it is trying to get going, then be quiet for 30 seconds or so and then surge again? I've checked the filter and it is clean. What could be the problem? THank you!
SOURCE: lower spray arm is not rotating
call sears help line thewy have mech that can help
Posted on Mar 14, 2009
SOURCE: Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Posted on Apr 21, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
  • 423 Answers
SOURCE: LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
Posted on May 14, 2009
  • 110 Answers
SOURCE: Hobart SR24H dishwasher will not spray, arm does not rotate
ck. flow press. of water , when fill solenoid opens press. should be @20 p.s.i because this is a time fill machine. this is important .not static press. flow press. also ck the screened washers in the fill hose to see if they are plugged .let me know what you find so i can futher assist. dont forget to vote tks
Posted on Jan 11, 2010
Kenmore Elite model 665.15932 motor is now very
1)check any jam on impeller(motor)
2)check whether bearing plm.(possible replace the bearing)
Mar 01, 2010 | Kenmore Dishwashers
Kenmore Elite Drawer Dishwasher leaking
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Jun 29, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
Kenmore Elite Dishwasher not cleaning well
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
45jdgyhj
Jun 16, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Water on floor after Kenmore dishwasher runs
you could fix this, however the price of repair will be 1/2 of the price of a new dishasher.  I would suggest you buy a new oneand not waste money on a six year old dishwasher.  find a good scratch and dent model.
Mar 15, 2009 | Kenmore Dishwashers
Kenmore Elite 17483 Dishwasher Caught Fire!
Had the exact same problem (Control panel burning up, sparking, and smoking during wash cycle) last night with our Kenmore Elite DW model 665.16293400 purchased Nov. 2004. I have reported it to the CPSC and www.kitchenaidfire.com and will be contacting Sears first thing tomorrow. It is outrageous that this problem is apparently so widespread with nothing being done about it! I have no doubt my kitchen would have been in flames if I had not been sitting right here to shut off power to the D/W.
Feb 04, 2009 | Kenmore 24 in. 17483 Built-in Dishwasher
Need the model number of the Kenmore Elite dishwasher 1378(2)
The model number will be something like 110.123456
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 25, 2008 | Kenmore 13789 / 13782 Dishwasher
Kenmore 24 in. 15142 Built-in Dishwasher Logo
569 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
