Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Bake and Broiler do not work
All burners on stove top, the clock, timer and inside light seem to work fine.
Light that indictes it is baking does not light.
Broil and bake features do not work
  • tmanta Dec 29, 2008
    I'll try that part and let you know
  • 115 Answers
It sounds like you have a bad eoc which is electronic oven control that is the only thing it could be if your top burners are open
Posted on Dec 29, 2008
Hotpoint gas oven doesn't light
What is the complete model number of your unit?
Dec 09, 2012 | Kitchen Ranges
My gas oven, Super Capacity 465 the oven nor broiler light. The stove top works fine.
Hello there
Please read the entire solution i have provided below ok
It won't bake or broil If neither the oven nor the broiler heats, but the range burners still work, the clock may be set for a timed or self-cleaning cycle. Check to be sure the clock buttons and knobs are set properly. If your clock has a knob that says "push for man(ual)," push the knob in and try heating the oven and broiler again. If they still don't work properly, you probably have a defect in the thermostat, selector switch, or common wiring. Note... If the oven doesn't have a separate bake/broil/etc. selector switch, the problem is often with the thermostat. It's not easy to check the selector switch or thermostat for proper operation. If you suspect a problem with either of these, call a qualified appliance repair technician.
Sep 28, 2010 | Whirlpool GS460 Gas Kitchen Range
Ge profile gas oven broiler works but bake wont light
The ignitor for the oven burner is bad...
Here is a tip that I wrote about that...
Mar 30, 2010 | Ovens
The oven will not light on my Whirlpool gas oven Mod SF368LEPQ 2. The stove top burners still light.
Sounds like you need an bake element ignitor if the bake doesn't work but if the broil also doesn't work, it could be the electronic clock/timer control. the part number for the bake ignitor is 8054129 .Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Whirlpool Ovens
Oven wont bake
sounds pretty simple a bake element
Oct 03, 2009 | Jenn-Air JGR8750 Gas Kitchen Range
Magic Chef oven & broiler do not work
you know i am thinking more towards a bad temp probe.
May 28, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven will not light
check the gas valve to make sure a mouse did not chew the wires.
Jan 31, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Maytag dual oven upper oven not heating
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerryrigging a bridge to wire the BAKE igniter to the BROILER controls.(Push/click plugs accessible by opening up the stove back) Testing thebroiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.)The parts and wiring are pretty simple and visual once you get thecovers off. Opening up the stove back is just a matter of removingseveral screws. UNPLUG the stove before you work. If you test as Idescribed, make all connections while UNPLUGGED and then plug it inonly for the brief test. Unplug again while disconnecting/reconnecting.Hope this helps.
Nov 25, 2008 | Maytag MGR6772BDS Gemini Gas Kitchen Range
I have a 4 yr. old Maytag stove model #PGR5715BDQ, the burners all work fine as well as the broiler. The bake ignitor glows red and after a while gas can be smelled but burner will not light. A match will...
I have a Jenn-air stove model # JGS8750BDS in the oven when I call for bake the ignitor come on and glow then the gas come on but the burner want light but I smell the gas what is the problem
Aug 26, 2008 | Kitchen Ranges
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
343 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
