Question about Car Audio & Video
Cd 6006 volume control.
When driving along the volume gets louder when i go fast and gets quieter when i slow down. How do i stop this. the car is a fiesta st. Thanks Jason.
If you hold the volume button in a "volume speed" indicator will come on adjust accordingly.
Posted on Dec 28, 2008
Driving a good distance car makes a whamming sound the more Itry to accelerate the speed decreases whinning louder only stops whinning when I pull over to let the car cool down
Have your wheel bearings checked, when a wheel bearing is going bad it hums louder as you accelerate, when you stop or slow down the sound stops. A bad bearing does that, it over heats due to it not having enough grease on the bearing and will hum as you drive and get louder as you accelerate.
Jun 07, 2015 | 2011 Dodge Caliber Mainstreet
My 2001 honda civic is idling at high rpm and when I release the gas while driving the speed doesn't slow very quickly and it's harder to break than usual. It also runs louder than usual. It's also co
You need to determine what's causing the fast idle as that's what's allowing the engine to run on (dieseling) after the ignition is turned off. Most likely cause is the throttle body needs to be cleaned along with whatever Honda uses to control idle speed commonly called Idle Air Control.
Jan 09, 2014 | Vehicle Parts & Accessories
How to fix bad radio reception on my myron&davis system in my rav4 toyota also when you listen to the cds the volume gos up and down on the songs is this all one problem this is a 2nd unit installed...
You may just need a FM signal booster for your antenna. The issues with the volume going up and down, does this occur when the vehicle is sitting still? If so, yes there is still a problem. If the volume gets louder as you speed up, and quieter when you slow down, this is a function of the unit. It automatically controls the volume to compensate for road noise. Consult you owners manual regarding how to disable this function.
Sep 04, 2011 | Car Audio & Video
2000 Chevy Blazer 4x4...started making a horrible loud noise after my cruise control went out. I have recently replaced my hub and the brake pads and the CV axle. The noise comes and goes and only happens...
does it get louder above 45-60mph? and much quieter at low speeds. It could be wheel bearings, a rear differential or front differential. If its a grinding humming noise its wheel bearings, listenin to see if theyre coming from the front or rear, left or right, or both when your driving to know what wheel bearing are bad. If its a whinning noise, its probably a differential. check and listen to hear if its coming from the front or rear. Also, check for loose plastic around the wheels. Lastly check your tires for uneven or choppy wear. move your hands front to back on the top of the tire. does it feel really choppy and rough, maybe you just need new tires
May 04, 2011 | 2000 Chevrolet Blazer
I need help finding the code for my tv. i have a Philmore universal remote pm-rc13. My t.v is a white-westinghouse
Here is the code for your TV 0154 along with the advanced codes.
Advanced Codes for TV_0154TVs ------------------ <TV Group>
0154 244 ACM 165 Fine Tune Up 251 SAP 167 Surround Mute
244 Auto Chroma 244 MTC 231 Speaker In 168 Surround Vol dwn
251 Bilngual 234 PIP Location 233 Speaker Out 164 Surround Vol up
169 Fine Tune Do 228 PIP Select 247 Stereo 129 Component 2 (discrete)
TELEVISION. Uses with:
TUNER/CD/TAPE/PHONO/AMP..CDs................AUX2 088
TELEVISION...............TVs..................TV 154
VCR......................VCRs................VCR 047
VCR......................VCRs................VCR 104
On some models,
100|AM/PM|1-- may be 100/Enter;
Func|Sel may be Digicon;
Level Up|R may be Control Right, Level Up/Minute or Menu Up;
Level Dn|L may be Control Left, Level Dn/Hour or Menu Down;
Review|Qck View may be CH Recall or Quick View;
SetTime Fast may be Stereo Matrix;
SetTime Slow may be Time/Day, Set Up, Clear or Menu;
TV/Video/AV may be TV/AV, Video Mode, Input or A/V;
Wide|TV|Loud may be Stereo Matrix, Surround or Mode;
MTC|OBC|Auto may be ACM or Auto Chroma.
181 0...............0 185 1...............1
120 ENTER...........1-- 120 ENTER...........100
183 2...............2 187 3...............3
180 4...............4 184 5...............5
182 6...............6 186 7...............7
053 8...............8 057 9...............9
185 1...............A 123 A/B.............A/V
120 ENTER...........AM/PM 059 CHANNEL DOWN....AM/PM
183 2...............B 187 3...............C
249 RECALL..........CH Recall 059 CHANNEL DOWN....Channel Down
055 CHANNEL UP......Channel Up 122 PROGRAM.........Clear
250 STOP............Control Left 246 PLAY............Control Right
250 STOP............Cursor Down 059 CHANNEL DOWN....Cursor Left
055 CHANNEL UP......Cursor Right 246 PLAY............Cursor Up
180 4...............D 055 CHANNEL UP......Day
184 5...............E 120 ENTER...........Enter
182 6...............F 121 SHIFT STOP......Fine Tune Dwn
117 SHIFT PLAY......Fine Tune Up 248 PAUSE...........Function
186 7...............G 053 8...............H
250 STOP............Hour 057 9...............I
123 A/B.............Input 181 0...............J
059 CHANNEL DOWN....K 250 STOP............Level Down
246 PLAY............Level Up 122 PROGRAM.........Menu
250 STOP............Menu Down 246 PLAY............Menu Up
246 PLAY............Minute 116 SHIFT PAUSE.....Mode
245 MUTE............Mute 230 SHIFT FFD.......PIP Freeze
235 FAST FORWAARD...PIP On/Off 232 SHIFT REW.......PIP Replace
119 POWER...........Power 052 DISPLAY.........Recall
249 RECALL..........Review 248 PAUSE...........Select
122 PROGRAM.........Set Up 118 REWIND..........SetTime Fast
122 PROGRAM.........SetTime Slow 056 SLEEP...........Sleep
116 SHIFT PAUSE.....Stereo Matrix 118 REWIND..........Stereo Matrix
116 SHIFT PAUSE.....Surround 122 PROGRAM.........Time/Day
056 SLEEP...........Timer 181 0...............Timer Set
056 SLEEP...........Timer Start 116 SHIFT PAUSE.....TV
123 A/B.............TV/AV 123 A/B.............Video Mode
058 VOLUME DOWN.....Volume Down 054 VOLUME UP.......Volume Up
116 SHIFT PAUSE.....Wide
Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 29, 2009 | Televison & Video
Noise right front wheel sounds like wheel bearing, 1998 Dodge 3500 Van
try steering the the car to the right and the left while driving down the road. listen for the noise to get louder or quieter as you steer the car. which ever direction you steer and it gets louder it will be the bearing on the other side. for example if you turn right and it gets louder its the left bearing because you have just shifted the vechical weight to the left side by turning right. and also in that same situation the bearing would get quieter because you have just unloaded the left bearing and put the weight to the right side.
Mar 16, 2009 | 1998 Dodge Ram 3500 2WD
I need a volume pedal for a SX KN6000 Technics keyboard
As there's no polarity switch on the FC7 the quick and dirty way is to cut the cable and swap the wires around.
Feb 18, 2009 | Music
Check engine on
there is a special name for this, it automatically turns the volume down when road noise is quieter, its a thing that blaupunkt use a lot of the time, yes it gets quite annoying and im not sure if there is a way to turn it off, i know that there is a wire that leads to the back of the head unit that you may be able to disconnect to stop it
Jan 24, 2009 | 2003 Cadillac CTS
Humming oven clock
You'll need a new clock motor or clock unit. Once these units begin to hum, they must be replaced. Parts are available on the web, through supply stores or Sears Parts.
May 26, 2008 | Whirlpool Ovens
Car Audio & Video Logo
98 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
