Question about LG DLE2532W Electric Dryer
My dryer went "pop"
Ok, i had someone hook up my dryer and it was done incorrectly. when i put the dryer in use, it made a really loud noise, so i immediately turned it off. soon after, a burning smell started to arise, and shortly after the dryer was disconnected by the power cord, it made a pretty obvious popping noise. i rearranged the wires correctly and reconnected the power cord, but at that point it wouldn't even turn on. it smells like burned wire, so i think i busted a circuit or something. with that part, im unsure. i just want to know what i need to do to fix the problem or if i need professional help, or a new dryer. i have an LG model # DLE2532W. any help you can offer me will be greatly appreciated. thanks, liz
    Novelist:
    Champion:
  • 244 Answers
It could be your mains filter it is situated next to your motor if that has gone it wont work you can usually get one off another dryer doesnt have to be same make but it has to have same numbering on it but most are the same mate if this does work you might find burnt wiring at the inside front of your machine which leads to your door catch if that wiring is burnt out just replace wiring and it should work fine mate let me know what you find and ill try and suggest what you can do
Posted on Aug 11, 2007
SOURCE:
Dryer is Making a really loud noise
Your drum has bearings that turn it easier. They are worn or loose.you will need to have them replaced to get rid of the noise. How old is this dryer.
Feb 22, 2013 | Dryers
Noise in operation. A loud rumbling noise when
Any noise must be identified with a good observation of the point of noise source.
This can be done with a good view with all safety precaution while the unit moves. Use good lighting and make sure that you are not putting your hands into any moving parts while the set works.
Now disconnect after observation and manually turn the drum, the motor and the rotor to fix the point of noise. this can be a faulty bearing assembly or a faulty suspension all of which will require a resetting/reassembly.
Feb 17, 2011 | Whirlpool LER4634J Electric Dryer
Dryer makes humming noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
bb
May 15, 2010 | LG DLE2512W Electric Dryer
The motor has gone bad on your dryer...
Here is a tip I wrote about your problem....
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
heatman101
Mar 28, 2010 | LG DLE2512W Electric Dryer
The Dryer vent was accidentally left out of the dryer. It almost immediately started making a really loud noise. What is wrong?
Sounds like your cloths or anthing that was in the dryer that could have went down the vent, got cought in the blower wheel. you will need to inspect the blower wheel for the obstruction.
Jan 12, 2010 | Dryers
Dryer makes a loud squeaky noise
probably a bad pulley or drum bearing
Aug 31, 2009 | GE DSXH47EGWW Electric Dryer
Dryer appears broken, heard LOUD sound from other room (broken belt?)
gjtgjtgjtgjytgfjytjytgjtgyjtgujytgujttjtytgjtjytgjtgjtyjtgjytjytjgjykykuiykyyuuxuxxudkdssyzxhclds dskhsdlhkshkchdsflfhlhsdlo
Apr 14, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer doesnt do anything besides a loud noise
What kind of loud noise??  A loud electrical noise??  A loud squealing noise??
It's possible that there is a foreign matter inside the filter chamber jamming up the blower fan.  Pull the filter screen out and look down the filter chamber area and see if there is a sock jamming the fan from turning.  If you can pull it out, that should resolve your problem.  If not, you may need to call a qualified LG technician to resolve this issue.
Mar 16, 2008 | LG DLE2532W Electric Dryer
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
LG DLE2532W Electric Dryer Logo
181 people viewed this question
Top LG Dryers Experts
jimorris77
Craig Butler
Craig Butler
Marvin
Marvin
Are you a LG Dryer Expert? Answer questions, earn points and help others
