Code 22 My DVD Rom will not enable and reports a code 22, I deleted the upperfilter and lower filters, rebooted and still it does not work. I wantto upgrade my computers operating system to Vista and cannot do so tillthis error is fixed.. Any suggestions will be greatly appreciated.
  • ann70 Dec 28, 2008
    I have a Samsung 616E F509, I actually just uninstalled the DVD ROM then reinstalled it and it works now upgraded to Vista and all is well. Thank you for your quick response. :)
    Sergeant:
  • 279 Answers
Find out what kind of DVD drive you have. Then go to the website, and download a firmware update and run it.
Posted on Dec 28, 2008
  • Edward Morgan
    Edward Morgan Dec 28, 2008
    No problem. Enjoy ;-)
Hp dv6917cl - dvd drive not seen under vista 32
you can try deleting the upper and lower filter.
follow the below steps
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Aug 06, 2011 | HP Pavilion dv6917cl PC Notebook
My acer,s dvd rom dont working
Hi.
You may want to delete the upper and lower filters in your registry.In order to delete upper and lower filters you're going to have to edit the registry. The usual cautions apply. If the registry is not edited properly your whole system can crash.
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Hope this helps.
Mar 12, 2011 | Acer Aspire 5610-4648 Notebook
I use Samsung R 248. Recently my dvd drive is not working. It can't read any cd or dvd. what should I do?
Try to delete the upper and lower filters in the registry.
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
Apart from this, make sure that the driver is enabled.
Thank you!
Feb 22, 2011 | Samsung Computers & Internet
Cant install ND 6650A code 39
The issue is with the registry of the Computer. Please follow the steps to resolve the issue. Please back up the registry before performing the steps.
  • Please press "Windows+R" key to open the Run command, type regedit and then click OK.
  • Please click on File-->Export and then enter the name and select the location to backup the registry.
  • In the navigation pane, locate and then click the following registry subkey:HKEY_LOCAL_MACHINE-->SYSTEM--->CurrentControlSet-->Control-->Class-->{4D36E965-E325-11CE-BFC1-08002BE10318}
  • In the right pane, click UpperFilters.
Note You may also see an UpperFilters.bak registry entry. You do not have to remove that entry. Click UpperFilters only. If you do not see the UpperFilters registry entry, you still might have to remove the LowerFilters registry entry.
  • On the Edit menu, click Delete and select Yes to confirm.
  • In the right pane, click LowerFilters, on the Edit menu, click Delete and select Yes.
Note If you do not see the LowerFilters registry entry, exit the Registry.
  • Exit Registry Editor and restart the Computer.
This should resolve the issue.
Good Luck!
Thank you for contacting.
Jun 29, 2010 | Dell DVD-rom DVD Drive
My Dvd rom did work driver corrupted code 39
go to device manager first in control panel, check if there are any question marks , exclamation points or a red X on the dvd rom if there are try the below,
NOTE: A red X means that device is disabled or damaged/not rresponding
try goin here type regedit in the run field click the following folders
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Once you found the DVD/CD-rom on your system delete the folder Upperfilters and lower filters if you have both on the list if onlu one of the 2 still delete either one of the two filters then restart your computer this reset the DVD's wndows configurstion on the system and windows will automatically creat a new upp and lower filters on the dvd rom work most of the time unless the device dvd is really daamged and not responding
last option is reinstalling windows
Jun 04, 2010 | Microsoft Windows Vista Home Premium...
My Dell Optplex will not recognise my NEC ND-6500A drive, Tag J175G2J
You will have to delete the upper and lower filters and drive will be shoun in my computer again.
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
Mar 16, 2010 | Dell DVD-rom DVD Drive
My laptop is saying ive got a code 19 on my burner
Fixing the problem simply involves deleting the filter entries for the third-party device drivers. These entries can sometimes become damaged (which is what produces the "corrupt registry" warning or Code 19 error).
To delete the offending keys, open the Registry and navigate to HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlCl ***\{4D36E965-E325-11CE-BFC1-08002BE10318}. . Delete the keys named UpperFilters and LowerFilters and reboot.
Oct 22, 2009 | Toshiba SD R2102 CD-RW/DVD-ROM Burner
Has anyone successfully deleted ''upper filters'' to repair cd dvd drive code 39 without affecting pc?
to deleted filters follows this instruction:
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
and to repair upper filters follow these belows
right click my computer, click on properties. under hardware click device manager. look for dvd/cd rom drives if the drive is there try disabling and enable it afterwards. if nothing is listed try scanning for hardware changes if it detects the device it will install it automatically. if that does not work check your connections to that device. good luck."
Jul 01, 2009 | Computers & Internet
Code 10 no cd/dvd drive found, unable to burn cd?
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Jun 24, 2009 | Apple iTunes
TEAC DV W28ECT ATA DEVICE CODE 10
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Registry Editor
Aug 24, 2008 | Teac CD-Rewritable W28E CD-RW Burner
Computers & Internet Logo
David Payne
David Payne
