Question about GE Spacemaker JVM1640SJ Microwave Oven
Symbol on control panel ge spacemaker microwave
I don't see any manfunction but a mysterious symbol that I'd never seen appeared on the control panel of my microwave next to time. It looks like a lightpost with a V in the light. Anybody know what this is???
  • James
    James May 11, 2010
    Can you upload a picture of the button?
5 Suggested Answers
Tulip
SOURCE: GE SpaceMaker Microwave suddenly stops while heating
I had same problem last week. My GE JVM1650 Spacemaker stopped after a few seconds of heating. Owned 16 months, manufactured Jan 2005. It was the magnetron, which was replaced yesterday. The magnetron has a 10-year warranty, but I had to pay $161.00 for labor by a GE technician. The call-out fee was waived at my request. I don't know what that amount would have been, but I can't believe the $161.00 for what was about 1/2 hour labor once diagnosed. Good Luck!
Posted on Sep 21, 2006
  • 4 Answers
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
Posted on Nov 29, 2007
  • 95 Answers
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
Posted on Jan 22, 2008
MicrowaveSvc
  • 8968 Answers
SOURCE: Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Posted on Sep 16, 2008
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
Help! GE spacemaker 2.0
I had the same problem , it was finger touch control panel, when I cleaned with spray then it worked for some days . Finally to get ride of it , I changed control panel with a new one.
May 12, 2013 | Microwave Ovens
GE Spacemaker XL1800 microwave suddenly didn't work. All buttons on the front panel except "Clock" don't work. Open the machine, shorten the thermostat, the vent fan runs automatically....
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ==-
Sep 14, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave (jvm1740dm1bb) - Control panel how much for this part
GE part number WB07X11040. Several sources came up after a search for that number. Here's one site I do business with fairly often that has it listed. Here's another source with a lower price, but I don't have experience with them.
Jul 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Where is the light that is inside the GE Spacemaker microwave?
with cord unplugged you can remove the main control panel and access to it
Aug 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE microwave oven Spacemaker Moldel / will not warm food
the most likley problem is the magnetron has gone bad.but there are a couple of thermal sensor in the cabinet that need to be checked. one of those could be bad as well.
Feb 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
Dec 15, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Ge microwave spacemaker xl1800
F-3 means shorted touch panel pad. In order to attempt clearing the code yourself, please follow the steps below:
  1. Press CLEAR/OFF or CANCEL.
  2. Program control again.
  3. If the fault code appears again, disconnect power to the microwave for 30 seconds.
  4. Program the cooking function again.
  5. IF it comes back up you should change out the panel hope that helps, good luck
Dec 12, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1400 Microwave
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Nov 27, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
158 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
D. E. Hev
 Larry
Larry
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
