Question about KDS 17S 17" Monitor
Black screen blinking green light
Lately its been taking longer and longer to come on now it wont come on at all but the light is blinking green and i still have sound coming through. I also have my my tv hooked up to my video card and its still working. I never had any problems in the last 4 years that ive had my flat screen until recently when I installed my n-vida 3d video card about 6 weeks ago, and about 3 weeks after that I noticed the screen not coming on right away and as time went by it was taking longer and longer to come until now it wont come on at all.
  • bagglaydee Jan 20, 2009
    so is the backlight fluorescent bulb something that can be replaced? My monitor is about 4-5 years old....maybe time to get a new one? The monitor would take 20 minutes to come one, now in the last 2 days it takes 45 minutes. I have a KDS RAD-5C, sticker on back says mfg in 2002.....
  • keviquin Feb 17, 2009
    There seems to be some question about the quality of the capacitors used on the main power board. Check the tops for swelling or leakage. They might be the real problem.
    I think a more elementary problem you'll find will be detting the unit apart. The front bezel seels to be attached with interior clips that aren't accessible, or easily manipulated, from outside the case.
    Any help with that?
    Genius:
  • 2,120 Answers
You have a bad backlight fluorescent bulb.
Posted on Dec 28, 2008
TV WONT COME ON AND THE LIGHT KEEPS FLASHIN RED AN GREEN ON THE STANDBY BUTTON
  1. If your Sony Wega will not turn on, the front green light blinks, you hear a faint whirring sound and the green light turns red and flashes, it probably means the lamp inside the set is no longer working. If you noticed the screen beginning to dim in the preceding days or weeks, this most likely is the cause.
  2. If the green light flashes and the picture comes on momentarily but then goes off, and the green button flashes until the set restarts, then the seal around the lamp mount is loose and needs to be refitted.
  3. If the picture on your Grand Wega cuts in and out and the green standby light flashes, both of the set's STKs need to be replaced. STKs are small chips on your television's circuit boards and are identifiable by their labels. The specific STKs used in your Grand Wega TV will be identifiable by the numbered labels on top of the STKs.
  4. When you plug in your Sony Wega and hear a loud popping sound, it's probably caused by a defect in the high-voltage circuit. Let the professionals take care of this one.
  5. If, after turning on your Sony Wega, you can hear your set but the screen is black, you most likely need to replace your projection lamp.
Read more: How to Troubleshoot a Sony Grand Wega ' eHow.com http://www.ehow.com/how_5243554_troubleshoot-sony-grand-wega.html#ixzz1EoY37gpC
Feb 23, 2011 | Sony Grand WEGA KF-42SX300 42" LCD TV
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
My Canon ip1600 wont print with new ink cartridge.
Visite the support tech and try to find a answer for you probelem:
Sep 09, 2009 | Canon PIXMA iP1600 Printer
Black screen flashing power led
This is most likely the power inverter board in the monitor - this is common in many monitors. If it started taking longer and longer to display an image, and the power light is blinking on-and-off, that's the problem. You can confirm that it's the monitor and not your computer or the cable by plugging in another monitor if you have one to try. If it's under warranty, send it back, if not, there are inverter boards for many common models of LCD monitors that are replaceable. The board can run anywhere from $50 on up. Depending on how old it is, you may find it better to just replace it with a gently used one from ebay.
May 08, 2009 | Computers & Internet
Black screen and no blinking green light when turned off
Ok do not worry this may mean two things crached hard drive or a corrupted hard drive all you have to do is turn it on but let the red ligth be on turn it on do not remove your finger from the button until it go's off again turn it on again keep your finger until it makes a sound but still do not remover your finger untill it makes two sounds after eachouther take your finger of fast nou a screen will apear say restore sestem untill your ps3 works again it take 1-6 trys and if nothing happens you must format it.HOPE I WAS USEFULL PLZZ RATE ME AND IF THERE IS ANYTHING ELS EMAIL ME TO markusmaritz@yahoo.com I DO PS1,2,3,DVD PLAYERS AND PC sorry for my spelling i am only 13 and i amafrikaans BUT PLZZZ RATE ME . . . plzz thns
Dec 30, 2008 | Sony Playstation 3 (PS3) Console
Screen remaining black after the TV is turned on
Some newer sets appear that way when there is NO signal to the set. That and my Sony looks like that when the bulb is burned out.
Dec 23, 2008 | Toshiba TheaterWide 52HM84 52" Rear...
KDS 17S 17" Monitor Logo
143 people viewed this question
Top KDS Computers & Internet Experts
Denise
RobertFonner
RobertFonner
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
